L0WMK2 Posted October 23, 2005 Share Posted October 23, 2005 brought some reversing lights for my cortina how do you wire them up so they come on with reversing? Quote Link to comment Share on other sites More sharing options...
kyteler Posted October 23, 2005 Share Posted October 23, 2005 Wire them into the switch/wires that come from the gearbox, unless you've got a dork-a-matic in which case you can probably wire it into the selector. Quote Link to comment Share on other sites More sharing options...
Toucan Posted October 23, 2005 Share Posted October 23, 2005 Theres a 99% chance the wire kyteler speaks of is broken and no long protrudes from the gearbox. Its just below the shifter on the drivers side. Quote Link to comment Share on other sites More sharing options...
L0WMK2 Posted October 23, 2005 Author Share Posted October 23, 2005 it a four speed manual would i have to drop the box out to see the wires Quote Link to comment Share on other sites More sharing options...
kyteler Posted October 23, 2005 Share Posted October 23, 2005 Only if you're too fat to fit under the car. Seriously though, I shouldn't think so, but if you're having issues just remove the shifter boot and have a nosey through the hole from the top, should be fairly easy to see. Quote Link to comment Share on other sites More sharing options...
mkcortina Posted October 23, 2005 Share Posted October 23, 2005 Your gearbox may not have a reverse switch on it. my mk1 doesn't have 1. Quote Link to comment Share on other sites More sharing options...
L0WMK2 Posted October 23, 2005 Author Share Posted October 23, 2005 i looked but couldnt see any wires jacked it up because im a big boy and its low it would also have been a column change converted to floor Quote Link to comment Share on other sites More sharing options...
oldrx7 Posted October 23, 2005 Share Posted October 23, 2005 just a question, why would you want to put reverse lights on a car that didnt come with them? is it a wof requirement now? Quote Link to comment Share on other sites More sharing options...
WDE_BDY Posted October 23, 2005 Share Posted October 23, 2005 DELETED Quote Link to comment Share on other sites More sharing options...
L0WMK2 Posted October 24, 2005 Author Share Posted October 24, 2005 came across them dont need them but theyre for old fords, some had them as extras i think? Quote Link to comment Share on other sites More sharing options...
Guest WESTCORT Posted October 24, 2005 Share Posted October 24, 2005 theres the switch on my box, mine is missing that part that clipsonto the brass button looking thing there and lugs into the conector. sussed it now though Quote Link to comment Share on other sites More sharing options...
