trouble geting flywheel out?!
Guest 82EVO
i need to get my flywheel machined before i get a new clutch in my lancer, but as anyone whoz tried befor would know the engine just turns and their tuff bolts. any tricks or ways to get it out?
cheers
i had to make a plate up that bolts to the crank pulley through the bolt holes that hold the auxillary pulley, and pick up the mount hole for the alternator, this made getting the flywheel bolts out easier, also from memory the bolts are an unusual size, and are very shallow, be very careful not to round them off.
Bend an old valve and slot it through a gearbox bolt hole, with the head of the valve slotted in between the ring gear teeth.
As said before, hitting the spanner with a hammer should give enough shock to crack the bolt.. or else a rattle gun will work real well if you can get hold of one...
