Guest escort_boy Posted August 14, 2005 Share Posted August 14, 2005 Have any of you eskie owners mounted Honda seats in there car ? if so how did you do it because i got a set of mint honda seats and just trying to work the best way to mount them Quote Link to comment Share on other sites More sharing options...
two_days_late Posted August 14, 2005 Share Posted August 14, 2005 havent done honda ones specificly man but would be pretty much the same with any japa seats. just get some boxing from industrial supplies, think of how to bolt the seat to the boxing and then bolt the boxing straight to the floor. heres a pic of how i did mine Quote Link to comment Share on other sites More sharing options...
Guest escort_boy Posted August 14, 2005 Share Posted August 14, 2005 yeah thats pretty muuch how i was going to do mine what about for warrents? you would have to get this certed aye? Quote Link to comment Share on other sites More sharing options...
two_days_late Posted August 14, 2005 Share Posted August 14, 2005 im not sure if you'd need to get it certed, mines not on the road yet so i dunno. as long as the warrant guy could see it was safe, bolted to the floor and welded properly you might be ok? Quote Link to comment Share on other sites More sharing options...
Guest escort_boy Posted August 14, 2005 Share Posted August 14, 2005 p yeah mean as.... did you make a thread in the floor or bolt on the under side? Quote Link to comment Share on other sites More sharing options...
two_days_late Posted August 14, 2005 Share Posted August 14, 2005 put some square steel plates under the floor and both up through from the underside, just get some roughly 6cm by 6cm plates and bolt through them too so it doesnt rip through the floor if you crash. cheers Matt Quote Link to comment Share on other sites More sharing options...
drftnmaz Posted August 14, 2005 Share Posted August 14, 2005 normally u dont have to cert if you use the factory mounting points. Quote Link to comment Share on other sites More sharing options...
Guest escort_boy Posted August 14, 2005 Share Posted August 14, 2005 ahh yeah ok cheers for that 2 days late so if i was to use where the eskie ones mounted ( the holes in the floor) i wouldnt have to cert them? Quote Link to comment Share on other sites More sharing options...
two_days_late Posted August 14, 2005 Share Posted August 14, 2005 sweet as. im not sure about certing them at all. i was gona try and use the escort mounts and bolt them back where they were origonally but it was gona imposible and no where near worth it, its kinda annoying coz in the floor of the escort the front is raised up where the 2 front bolts for the seat go in, so if you do it the way i showed in the pic you have to put some more spacing to raise the back up to the same level. cheers matt Quote Link to comment Share on other sites More sharing options...
kyteler Posted August 14, 2005 Share Posted August 14, 2005 normally u dont have to cert if you use the factory mounting points. Exactly. If it bolts into the exact same place as the factory mount then you're fine, if you have to alter or add something in order to bolt it in, you NEED cert. Quote Link to comment Share on other sites More sharing options...
TygerTung Posted August 15, 2005 Share Posted August 15, 2005 I just got the factory rails, and bolted them to the bottom of the seat I was putting in. Was pretty easy. Quote Link to comment Share on other sites More sharing options...
davidian Posted August 15, 2005 Share Posted August 15, 2005 logan= honda fan Quote Link to comment Share on other sites More sharing options...
