two_days_late Posted June 15, 2005 Share Posted June 15, 2005 im lookin for a diff for my esky. ideally i'd like somethin thats LSD and already has disk brakes on it, but realistically this probably wont happen. what Diffs are people runnin in their escorts. thoughts. Quote Link to comment Share on other sites More sharing options...
RT Posted June 15, 2005 Share Posted June 15, 2005 The earlier model 2wd Hilux up to 1975 is the same width as an Escort. The later would appear to be about 20 - 25mm wider.. have a read of this: http://www.classicford.mine.nu/forum/ Classic Ford Tech Section - Hilux Diffs All Forums General Forum Technical Information Toyota Hilux/Hiace Diff Conversion Capri diffs are another option.. my mate runs a MK1 1600GT diff in his but it's flared out so he can fit decent rubber in.. if you have no flares then it will need shortening. Quote Link to comment Share on other sites More sharing options...
Leebo3 Posted June 15, 2005 Share Posted June 15, 2005 I am currently running (yes my escort is now going) a 3.54 but used to have a 4.12. Both seem the same to use for me. Quote Link to comment Share on other sites More sharing options...
Gaz Posted June 18, 2005 Share Posted June 18, 2005 The earlier model 2wd Hilux up to 1975 is the same width as an Escort. The later would appear to be about 20 - 25mm wider..have a read of this: http://www.classicford.mine.nu/forum/ Classic Ford Tech Section - Hilux Diffs All Forums General Forum Technical Information Toyota Hilux/Hiace Diff Conversion Capri diffs are another option.. my mate runs a MK1 1600GT diff in his but it's flared out so he can fit decent rubber in.. if you have no flares then it will need shortening. Yes correct. Very very good luck finding one. I keept my eye out for one for years to no avail. just got the newer hilux diff instead. Mazda B2000 can also be good. Quote Link to comment Share on other sites More sharing options...
two_days_late Posted June 20, 2005 Author Share Posted June 20, 2005 hey methodz have you got any info of the process of using a newer hilux diff? was it very hard to do, did you have to get it shortened? cheers Quote Link to comment Share on other sites More sharing options...
Bistro Posted June 20, 2005 Share Posted June 20, 2005 imo the new hilux diffs are the way to go. a solid lsd and something around the price range of $1400 shortened and purchased?? it will need to be shortened, and you can have the track a little smaller if you have larger width wheels at the back, as long as it doesnt hit the tub or the leafs. which is mad score. Quote Link to comment Share on other sites More sharing options...
two_days_late Posted June 20, 2005 Author Share Posted June 20, 2005 oh yep that sounds good. do the newer hilux's have discs on the back? i was hoping to go for 4 wheel discs. and whats the story with the B2000 diffs? i was hoping to get somethin a little cheaper Quote Link to comment Share on other sites More sharing options...
Guest WESTCORT Posted June 21, 2005 Share Posted June 21, 2005 dont the new atlas diff's cost only $1500 new? i suppose hilux wud be way stronger Quote Link to comment Share on other sites More sharing options...
Guest Eddie W Posted June 21, 2005 Share Posted June 21, 2005 Well the works Eskys used to put up to 280 hp through an Atlas but they did have fully floating hubs and beefier halfshafts. I would have thought that the LSD might be hard to come by. Eddie Quote Link to comment Share on other sites More sharing options...
Jerm Posted June 22, 2005 Share Posted June 22, 2005 You can get them frompalmside but they do set you back alot of pinger. Quote Link to comment Share on other sites More sharing options...
