Guest jwee Posted May 30, 2005 Share Posted May 30, 2005 Can anyone tell me if a sierra 5speed goes into a mk2 transmission tunnel without cutting it.Its being attachted to a 2litre already in the car. Quote Link to comment Share on other sites More sharing options...
Leebo3 Posted May 30, 2005 Share Posted May 30, 2005 You will need to make a new hole for the gear stick, that is for 1600 though i guess it is the same for a 2litre Quote Link to comment Share on other sites More sharing options...
Guest WESTCORT Posted May 30, 2005 Share Posted May 30, 2005 yes it does, but like rscort says a new hole is needed in the floor for the stick Quote Link to comment Share on other sites More sharing options...
Toucan Posted May 30, 2005 Share Posted May 30, 2005 If the car was originally an auto, it will fit as the autos have a bigger trans tunnel, if it was a manual, then you will need to cut the trans tunnel a bit bigger, look around in past threads, this has been covered about a 100 times now Quote Link to comment Share on other sites More sharing options...
esky boi Posted May 30, 2005 Share Posted May 30, 2005 Yea a new hole about 2-3 inches further back and a shorter driveshaft... one from an auto escort does the job, also half a Sierra one and half an Escort one joined together will do it. Not too sure which half of which tho. You also need a different speedo cable (I think) Green_mk2_Escort will be able to tell you more.... Quote Link to comment Share on other sites More sharing options...
Mr.Mk1 Posted May 30, 2005 Share Posted May 30, 2005 I didnt have to cut shit other than the new Stick hole. Quote Link to comment Share on other sites More sharing options...
Draizuh Posted May 30, 2005 Share Posted May 30, 2005 use a sledge hammer Quote Link to comment Share on other sites More sharing options...
RT Posted May 30, 2005 Share Posted May 30, 2005 nothing that a hammer massage can't fix. Mainly around the top of the bulk-head where sometimes you can get a bad vibration but thats all. You just need to cut a retangle with the gearstick hole at one end and turn it around and weld it back on. So that the hole is around 7-8cm back. Use a standard length shifter so it doesn't hit your handbrake or cut your handbrake handle shorter. Quote Link to comment Share on other sites More sharing options...
