Jerm Posted April 19, 2005 Share Posted April 19, 2005 Small prob with the eskie i think its the alternator... Battery keeps going dead.. at first i thought it was just my battery dieing... cos i charged it and it still seemed weak... and the battery charge light on the dash started to flicker as i was driving.. but i have just changed the battery to another charged one... havn't driven it but i started it and it seemed good but the charge light is still flickering.. this mean the bat is not gettign charge right? which would mean my alternator needs replacing? which sucks cos i won't haev time to do it till the weekend and i ned to get to work! gonnahvae to park on alot of hills. One questioni had was even if my bat is dead and my alternator is fucked how doe sthe car still run if you push start it? where does it get power for the spark? Eskie alternators are gay to get off.. that dumb bracket with bolts that are to long... the nuts and bolts hit each other! Quote Link to comment Share on other sites More sharing options...
kyteler Posted April 19, 2005 Share Posted April 19, 2005 Yes, it will be your alternator. Escort alternators are a piece of piss to get on and off, stop your whining In regards to your other query, the battery will still have enough charge to maintain a spark for a while, but not necesarily enough to engage the starter motor, hence push starts working, also, depending how fucked your alternator is, it might have enough go to keep the battery constant but not to charge it. Don't worry, they can be both fucked enough to not let you push start, you know you're in trouble when you turn the lights on, or the indicators and the car dies Quote Link to comment Share on other sites More sharing options...
RT Posted April 19, 2005 Share Posted April 19, 2005 Get your alternator recond. or get a beefer one and mod it to fit. I don't know whats available for the scort but for the pinto there's 3 different grades. black red and blue rated in that order for grunt. I used to have problems cos of my grunty stereo keept flattening my battrey. I found this massive alternator my 70yr old neighbour said was off a sierra. Well, I don't know what sort of sierra he was referring too cos I've never seen one like it. But it's German made and I got it tested and it's super grunty! fitted straight on too. ...sorry i bet none of that helped Quote Link to comment Share on other sites More sharing options...
kyteler Posted April 19, 2005 Share Posted April 19, 2005 Yeah, if you're running lots of auxillary units, Stereo, subs, speakers.. you'll want something with at least 50A Quote Link to comment Share on other sites More sharing options...
Snoozin Posted April 19, 2005 Share Posted April 19, 2005 Get your alternator recond. or get a beefer one and mod it to fit. I don't know whats available for the scort but for the pinto there's 3 different grades. black red and blue rated in that order for grunt.I used to have problems cos of my grunty stereo keept flattening my battrey. I found this massive alternator my 70yr old neighbour said was off a sierra. Well, I don't know what sort of sierra he was referring too cos I've never seen one like it. But it's German made and I got it tested and it's super grunty! fitted straight on too. ...sorry i bet none of that helped Hahahhahaaaa nice use of the word GRUNTY. Quote Link to comment Share on other sites More sharing options...
mkcortina Posted April 19, 2005 Share Posted April 19, 2005 Eskie alternators are gay to get off.. that dumb bracket with bolts that are to long... the nuts and bolts hit each other! Do you mean the bolts that bolt the bracket to the block or the bolts from the altermator to the bracket? This is what i have done i replaced the 2 bolts from the alternator to the bracket with 1 long bolt this makes it easier to remove the alternator and i leave the bracket connected to the block. Quote Link to comment Share on other sites More sharing options...
Jerm Posted April 19, 2005 Author Share Posted April 19, 2005 Eskie alternators are gay to get off.. that dumb bracket with bolts that are to long... the nuts and bolts hit each other! Do you mean the bolts that bolt the bracket to the block or the bolts from the altermator to the bracket? This is what i have done i replaced the 2 bolts from the alternator to the bracket with 1 long bolt this makes it easier to remove the alternator and i leave the bracket connected to the block. Yes that is a brilliant brilliant idea! Hows the cort coming along? does your bro still wnat to sell the cort? Does it have any rust? run well? reliable? does it use heaps of gas? I might be keen aye.. need a car to get around in Quote Link to comment Share on other sites More sharing options...
Guest WESTCORT Posted April 20, 2005 Share Posted April 20, 2005 my alternator just died so i ripped it apart and rebuilt the bastard with 3 others i had lieing in my garage. the battery would be flat all the time and id have to push start it every time like u sed ....when i pulled it apart i could see what the problem was and fixed it piece of piss, saved myself whatever a new one costs Quote Link to comment Share on other sites More sharing options...
Guest escort_boy Posted April 20, 2005 Share Posted April 20, 2005 a new one is $90 with a 6month warrenty, well that was a cortina alterantor Quote Link to comment Share on other sites More sharing options...
