durty Posted September 21, 2005 Share Posted September 21, 2005 yeah, it may be cheap. but i still cant afford it. me = mega poor Quote Link to comment Share on other sites More sharing options...
SYKOV6 Posted September 22, 2005 Share Posted September 22, 2005 yeah. i know. costs a shitload so im just gonna put off doing it till i have blown all my normal diffs just weld the fucker up dude will last heaps longer Quote Link to comment Share on other sites More sharing options...
Guest kris Posted September 22, 2005 Share Posted September 22, 2005 Hard to park with a welded diff. Quote Link to comment Share on other sites More sharing options...
SYKOV6 Posted September 22, 2005 Share Posted September 22, 2005 i was allways told that too. i have a mini spool in the corty and have found no probs in any slow speed driving. its a little noisier and more harsh bump wise but no harder to manouver. and its great for qik u turns just point and plant Quote Link to comment Share on other sites More sharing options...
durty Posted September 22, 2005 Share Posted September 22, 2005 yeah. already got one welded in the garage. blow up the one i got first. need to do suspension first anyway. so much for leaving it standard Quote Link to comment Share on other sites More sharing options...
Gaz Posted September 22, 2005 Author Share Posted September 22, 2005 average price for a hilux drum to drum lsd setup would be around the $300 to $500, non lsd you can get for about 200.ratios depend on the type of racing etc, but a 4.3:1 or a 4.1:1 are the most common. as i said earlier, Hiace van diffs are exactly the same, yet alot of people decide to pay more for one out of a hilux. pick a part usually has a few hiace lsd's, but i never have money when they are there Where do i find one of these. I have been looking at just the heads and they are all around the $500 mark Quote Link to comment Share on other sites More sharing options...
Ned Posted September 22, 2005 Share Posted September 22, 2005 sleep with a wreckers wife or daughter. or was that what not to do ? Quote Link to comment Share on other sites More sharing options...
darrin@premierauto.co.nz Posted September 28, 2005 Share Posted September 28, 2005 We can do a disk rear set up cheap as as well, rotors, calipers, cable handbrake n all. Bolts to diff housing and with modification cable hand brake works mint. Quote Link to comment Share on other sites More sharing options...
Gaz Posted September 28, 2005 Author Share Posted September 28, 2005 We can do a disk rear set up cheap as as well, rotors, calipers, cable handbrake n all. Bolts to diff housing and with modification cable hand brake works mint. Since im broke at the mo itd have to be pretty cheap. As in 5 bucks. Kidding whats the price tag on all that and what size disks, stud patern, diff etc. Are you talking the hilux diff? Quote Link to comment Share on other sites More sharing options...
darrin@premierauto.co.nz Posted September 28, 2005 Share Posted September 28, 2005 depends, with hunting you could find it all at pick a part, we use new rotors, reco'd calipers etc, but at a guess under $300 with a bit of work to do yourself or about $600-$700 if we did it for you its five stud toyota/falcon/mitzy/TX5 telstar not sure of PCD sorry Quote Link to comment Share on other sites More sharing options...
Gaz Posted September 28, 2005 Author Share Posted September 28, 2005 Supose the shortening is the hardest part. Have heard they(hilux) are a bastard to cut down as the axles are shaped like a cylinder, making it harder to line up when a peice is cut out, is this right or b/s? Quote Link to comment Share on other sites More sharing options...
Nominal Posted September 29, 2005 Share Posted September 29, 2005 I've found the cheapest source is rusted-out Hiace vans. These are the same basic diff but are unlikely to be LSD. I think I've got an LSD centre here that I plan to use, but the crownwheel/pinion are rust pitted. Here's a pic of the splined end of a Hilux axle. It would need to be cut down into the thick area for re-splining. There seem to be shorter and longer axles, but some are 6 stud so watch out. I decided it was easier to widen the bodywork than narrow the axle. Here's a couple of pics of my disc-setup-in-progress. Discs are rears from a GD (?) Telstar that have the same stud pattern. Had to get the outer flange of the axles trimmed a little to fit inside the bisc hat. Calipers are S14 silvia rears that include a handbrake mechanism. Mounts are cut from 8mm plate. I still need to get spacers machined and welded to the mount plates. Quote Link to comment Share on other sites More sharing options...
Gaz Posted September 29, 2005 Author Share Posted September 29, 2005 Helpfull. Whats the difference with the axle in the 6stud one? I have a 6stud housing drums and axles that i was intending to shorten with a LSD head. Am I on the right track? Also what car you got above Nominal and where ya from? Quote Link to comment Share on other sites More sharing options...
Nominal Posted September 29, 2005 Share Posted September 29, 2005 Helpfull. Whats the difference with the axle in the 6stud one? I have a 6stud housing drums and axles that i was intending to shorten with a LSD head. Am I on the right track?Also what car you got above Nominal and where ya from? The one 6 stud axle I've got is about 40mm shorter than the 5 stud. Also one of the housings has an offset centre by about 10mm. I'm guessing that a 4WD hilux might have 6 studs, and an offset centre to work with a transfer box. This would mean 1 shorter and 1 longer axle. If so you could get two short axles and narrow 1 side of the diff only. You could gain a bit by shaving the inner end of the axle off and inserting it further onto the splines. I had this done with a TE51 diff a few years ago, but it was fairly pricey. Best get your tape measure out. Here's a pic of my project that has the hiace diff: SR20DET, etc. I live near sunny Otaki. Quote Link to comment Share on other sites More sharing options...
Guest escort_boy Posted September 29, 2005 Share Posted September 29, 2005 fuk thats nuts!! can we see more pics Quote Link to comment Share on other sites More sharing options...
SYKOV6 Posted September 29, 2005 Share Posted September 29, 2005 OH YEAH good stuff dude. a guy i used to work with had a rover v8 in a morry van yours looks sik Quote Link to comment Share on other sites More sharing options...
atropine Posted September 29, 2005 Share Posted September 29, 2005 yes more more!! Quote Link to comment Share on other sites More sharing options...
durty Posted September 29, 2005 Share Posted September 29, 2005 MORE! Quote Link to comment Share on other sites More sharing options...
Nominal Posted September 29, 2005 Share Posted September 29, 2005 OK, here are some more pics. Apologies for the crappy quality. I've been buying parts instead of a digital camera. SR20DET red-top + 5 speed, all standard so far. Hilux diff, LSD, just checked centre & its a 4 spider! All custom suspension. Front is lotus-7 clone style with fabricated A-arms, coilovers, cortina uprights and discs, and escort rack. Rear is 5 link with coilovers. Chassis and suspension is pro-built by Graham Berry Race Cars. HR31 Skyline steering column. Underfloor brake and clutch. Body is cut-down Morrie van, roadster pickup style. 5 years and counting on this project. Currently getting driveshaft built, and AFM/intercooler piping organised. Current headache - fuel tank. Chassis/front suspension: Rear set-up: Side view with lowered bumper: Quote Link to comment Share on other sites More sharing options...
Gaz Posted September 29, 2005 Author Share Posted September 29, 2005 Looking very good. Am using the same engine in my escort someday in the near future. What ya going to do to the engine? whats the use of the car going to be? Quote Link to comment Share on other sites More sharing options...
