coltspeed Posted December 10, 2004 Author Share Posted December 10, 2004 I'll be using my gearbox from the colt as it bolts straight up. I'll be using the clutch from a 4g63. I'm checking out what flywheel i'll be using today as i'm not sure if the FWD or RWD 4g63 is the right one to use. A friend of mine is doing a trial fitting of his SOHC 4g63 today into his GTO, so we will be looking at the flywheel/starter motor combo today. Quote Link to comment Share on other sites More sharing options...
coltspeed Posted December 10, 2004 Author Share Posted December 10, 2004 I'll give my insurance company a ring today and see what they say, although i don't see it making any difference to them as all they see is engine capacity of 2.0L come up on their computer screens! I was hoping to get away without needing a cert as there is no chopping of anything and the cc rating stays the same, but as you said they definately didn't come out fuel injected, but they did come out twin cam. Quote Link to comment Share on other sites More sharing options...
Defective Posted December 10, 2004 Share Posted December 10, 2004 if you want more info on converting a fwd 4G63 to a rwd body log on to http://www.austarion.com there is heaps of good threads explaining exactly what you need to do plus theres a couple of guys that have done it always online. Quote Link to comment Share on other sites More sharing options...
coltspeed Posted December 11, 2004 Author Share Posted December 11, 2004 me and a friend did a trial fitting of a FWD SOHC 4g63 enginge yesterday into his colt and here is the verdict so far... RWD 4g63 mounts are required, but only the mount that actually bolts to the block(as they have a wider spacing) the rest is left as std and bolts straight up. the sigma/galant geabox bolts straight up(excellent!!!) to the block and also the gearbox crossmember still bolts into the original place. Lowlancer I noticed that on my car there are two mounting points for the gearbox crossmember, you might want to take your xmember off and see if this is the same(i bet it is). i think that one set is for the shorter 4 speed box and the other is for the longer 5 speed box. considering your car is basically the same as mine you will have no problem putting a 5speed in your car so long as you get a driveshaft from the 5 speed model, and these are plentiful and cheap! defective i had a look at austarion and there was some good info...cheers mate. i'm still a little concerned with the crank angle sensor, i don't know where to go to get it changed to fire off the front, anyone know? apart from that, this is turning out to be a really easy conversion. cheers shirwan. Quote Link to comment Share on other sites More sharing options...
lowlancer Posted December 12, 2004 Share Posted December 12, 2004 Hey Cheers for that info, I posted the same question on mmc forums and someone said it'll fit, so it's all good. Now I just gotta save the bling up! Cheers Quote Link to comment Share on other sites More sharing options...
coltspeed Posted December 12, 2004 Author Share Posted December 12, 2004 I did a bit of measuring today of the crank/cam angle sensor on the DOHC engine and it protrudes 35mm from the back of the head (i have 50mm), now if my calculations are correct (and i'm syre they are) i wont have to remove it! This means i don't need an aftermarket computer, so i will be running the factory ecu (saving money). It looks as though the only mods i will be making are the throttle body and water outlet off the back of the head, custom extractors and various hoses(radiator,heater etc...). Quote Link to comment Share on other sites More sharing options...
lowlancer Posted December 13, 2004 Share Posted December 13, 2004 And this is the non turbo 4G63? Why not turbo if you're going to all this trouble? Just curious! Quote Link to comment Share on other sites More sharing options...
Guest 78lancer Posted December 13, 2004 Share Posted December 13, 2004 in un related maters i have just taken the cheap option and have just rebuilt my 4g36 in my 78 4 door lancer, is now primered and lowered, exhaust is half way there with a 4" dytech dumpy sitting in the shed and a 1 3/4 inch strait thru with no mufflers, just the dumpy.. and lowlancer i got a new grill with park lites in it and new light surrounds Quote Link to comment Share on other sites More sharing options...
coltspeed Posted December 14, 2004 Author Share Posted December 14, 2004 why all this trouble for a non turbo? quite a few reasons really...I don't want any hassles with insurance, turbo motors are way to expensive(have you seen the asking price for a 15yr old vr4 engine, it's ludicris). i wouldn't pay more than $500 for an engine that old! i don't want to have the car off the road for the amount of time it would take to do brakes, suspension etc for the cert. but if anyone is willing to sponsor(read pay) for a 4g63t conversion i'm more than willing to listen. Quote Link to comment Share on other sites More sharing options...
Guest FUKD50 Posted December 14, 2004 Share Posted December 14, 2004 If i was a millionair i would sponsor you for sure. im doing a vr4 engine conversion in my other car. top secret but it will be sik Quote Link to comment Share on other sites More sharing options...
kyteler Posted December 14, 2004 Share Posted December 14, 2004 but if anyone is willing to sponsor(read pay) for a 4g63t conversion i'm more than willing to listen. Tell ya what... I'll sponsor your 4G63T conversion if you sponsor my RB26DETT conversion. Quote Link to comment Share on other sites More sharing options...
lowlancer Posted December 14, 2004 Share Posted December 14, 2004 Yeah fair enough And 78lancer, throw me some pics of your lancer sometime... Quote Link to comment Share on other sites More sharing options...
