78 lancer engine swap
Guest 78lancer
i got a 78 lancer, the shape b4 the ex lancer came out, and i was wondering if all the old mitsi shit all bolts up in2 the same mounts, like do the old 4g motors all mount in2 the original engine mounts and do all gearboxs spline in2 the any drive shaft???
  • Replies 52
All the early 4G series like the 32 33 36 etc all bolt in, basically if it came out with it, it'll fit, cos they share EVERYTHING. Like I've said, get the 4G32GS twin carb, 110hp standy, and seriously, unless your driveline is fucked you wont have any issues, home job easy as. good strong engines and easy to modify
Guest LukeNukem
Any old Astron or Astron 2 should drop in fine, not sure if you would want to go for chain or belt drive though, I've only ever had chain drives.
The engine in my Sigma dropped a piston and needed the whole engine replaced, so a week later by coincidence, a heap that had being trashed turned up outside my missus' work, left it there for a week then nabbed it before the counsel could jank it from my hands.
The engine in that was (the car was Sigma '83 wagon, engine went into '79 Sigma), a newer '82 model and dropped in perfectly, just had to change over the clutch.
If you do get an Astron engine, you might want to strip and rebuild it and replace the gaskets and piston rings + bearings and check for faults in the crank case, then it should serve you well for another 5 or so years.
....I saw a '70's lancer with a Evo engine squeezed into it in Zoom magazine once. It was a real sleeper weapon cos it looked completely standard.
I wonder if I've still got it lying around...
Oh god, please find it, cos my mates got a starion engined lancer with the VR4 head (so basically an evo engine, he tells everyone its got an evo4 engine.) and I'd like to compare power and so forth.
Guest 78lancer
so im thinkin ill source a 4g32gs but wat gear box should i run? cuz i thinkin the standrd 4 speed would b easier just 2 leave in cuz i got shit al money but would it b best 2 just get any old mitsi 5 spd or do i need 2 run a certain box??
sigma 5 speeds link up, they'd cost fuck all, not sure what would be needed though. But yeah the 4 speed would be fine and as long as you didn't treat it way too bad or modded the engine toooo much, it shouldn't give you hassles.
Guest LukeNukem
I had an old 4g63 (62?) lying round, but it had dropped a piston, just replace the piston and your away.
You can pick 'em up for 200-300 from wreckers, but thats too much in my opinion, you'de beable to get them 100-150 if you look hard enough.
Theres:
http://www.trademe.co.nz/Trade-Me-Motor ... 468135.htm
not sure if its north-south though.
or:
http://www.trade-exchange.co.nz/TEProje ... ID=6010721
Cant find much else.
Guest 78lancer
sweet as, ill keep u guys posted on wat ive done when i find a engine
Guest MOFOLO
Ur lancer be one of the easiest cars to rotor out, that is if u lot arent all anti right! driverside exhust, hydrolic clutch, big tunnel. thats just my 2c anyway.
Guest 78lancer
i took some pics of it 2day but it will b a while till i post them cuz i gotta get a hotmail adress.... but last nite when i was racing a escort, which the lancer will never lose 2 escorts, it did the most unusual thing for a escort, cough, it blew its gearbox on the launch.. bye bye 1st gear... quite funny really when i was 3 up, n he was 2up and i still beat him the first drag... good ol trusty 1200...
Heheh bring it :lol: I beat my mates midship rearwheel drive AW11 off the line piece of cake 8)
