Everything posted by azzurro
ugh, solex. Get a weber owl. I think the sucking inlet is to the base of the air filter (there is a big (crank breather) and small (this) flange on the base of the filter housing) 3 adjustment screws or two? 1 should be idle mix screw, the other should be throttle stop. third one? IDK Step 1 adjust idle mix screw till you get it halfway between the fastest idle just before it drops revs when you screw it in a bit more (leanest fastest idle) and when idle speed drops when you wind it out a bit more (richest fastest idle) Step 2 adjust throttle stop screw for appropriate revs (my feeling is this is the one doing the sucking noise as the vacuum increases/bypasses some restriction or orifice) repeat steps 1 and 2 ad infinitum in ever finer adjustments untill you dial in the leanest point (mix) it will idle at your spec engine speed or untill you reach your bothered threshold. (also step zero, ignition timing - i find these engines like a bit more than factory advance but no more than 36deg all in, and they run way better warm (warm = fan cycled at least twice)
if a barry modifies a car in the woods, is it still a lash up?
azzurro's 1966 FIAT Duamilatrecento Familiare (2300 Wagon)
azzurro replied to azzurro's topic in Projects and Build Ups
The 130 alloys are 14"x6" and with 205/60 tyres the rears rub on the inside of the outer guard, and are quite low geared compared to the factory 175/80 or 85 series tyres. I do like the look of them tho! So had a set of 14"x4.5" factory steelies blasted by @Mr Vapour and they turned out pretty good. as collected from Burger Fule meet, good ol Mr V rattle can primed to stop flashing i ran a strip disc over the tyre sealing area and then primered them And then top coated. I used the light grey that i did the floor and engine bay with with a bit more roof white in it (not quite enough grey left!) I didnt sand them at all, but it turned out ok and they have had way more attention than they deserve already. I have some 185R14C tyres that ive been saving for this since getting them from @kiwi808 when he moved down sarf that have a thin whitewall on them to install when the paint is dry, as well as trim rings and dog dishes. Presidentiale! Should mean i can drop the front a bit to even out the nose high stance and still steer, as presently the front is wound up as high as it goes.- 108 replies
- unicorn poop
- rust
- (and 8 more)
Since getting back from nats Ive been poking away at the inevitable list of (small) jobs on this. When we got home, this was sitting on the step. I love a bargain, I got this lot for $20 + shipping (which was only another $22!) in typical fashion I could have used a few of these bits (starter pinion, alternator end cap with bushes, diff seals, radiator hoses, tie rod ends, exhaust hanger, brake hoses) a while ago, but ho hum, spares are good. WINDSCREEN LEAK Windscreen has a pretty bad leak. It is worse when its sitting. (meaning its not coming up off the wheels) Bit gutted i didnt check it and poo it up properly before i put the surrounds on as the trim clips are a serious pain to get off and i did not what to crack the screen again. 3/4 of a tube of windcreeen sealer in and around it havnt quite got it drip free, but good enough now on the inside. However, the outside now looks gak KEYS Car also only came with a (replacement) ignition key so the doors and boot (from another car, also no key) couldnt be fully locked (or unlocked!). Door handles were also a bit loose and it all needed a clean up. I did find that my trusty old Club lock fitted into the key way, so removed the locked and rearranged the lock pins till this happened: Yay! Can actually lock the bugger. And best of all FREE! Also tidied and lubed up all the mechanisms and reinstalled the handles including the boot with some sealant behind the gaskets, and adjusted all the doors and they are way better.- 108 replies
- unicorn poop
- rust
- (and 8 more)
Nice work man! Looks snuggly. Like living in a sub box.
- 43 replies
- chevrolet express
- awd
(and 1 more)
Tagged with:
Reminds me, head bolts are in the mail. True story!
Oldschool Auckland Monthly Meet - 19th April 2017
azzurro replied to Threeonthetree's topic in Upper North Island Region
Please wipe it up before driving it to BF tonight, its a family show!- 27 replies
- burger fuel
- petroleum fuel
(and 3 more)
Tagged with:
nom for burgers and parts xchange so excited for new project bikes and freshly blasted reyums- 27 replies
- burger fuel
- petroleum fuel
(and 3 more)
Tagged with:
Nice. I have a spare solex carb you can have if you want it plus loads of random bits and pieces that are probably crapper than the bits you already have on that minter. But if you need any non consumable bits let me know.
tis all a permitted activity now as far as planning goes*. Im sure there is some building code shizz re fire rating between adjacent tenancies but that aint no thing. *(ahh, yeah your welcome i guess, unless you are sheepers neighbour then soz) (not soz) seriously tho, is that a cross lease? You probably know already but you will need a resurvey if so, and all this work - its to your neighbours place that you lease off them (and they off you hence the cross) , so yeah, just fee simple that pig (if your neighbours ok it...)
azzurro replied to azzurro's topic in Project Discussion
lol, yes, near new tyres half worn already. I didnt quite get onto it before we left for nats they were 6deg toe out? each side (were even tho so it drove straight, just was funky in the corners) and the wheel alignment pulled them back to 2deg toe in? (cant recall but the opposite way to what it was) each side so 8deg out each wheel or 16deg total. Im blaming this for lack of placing in Grasskhana. (i coulda been a contender!) Caster (2deg) and Camber (0 to slightly negative) were pretty good. With the rain on the way back it was pretty sketchy driving, so made the call to stop and get er done. -
Day 4 & 5 The long Drive Home Passing though the Mrs hometown. Stopped off at the FILs place in the 'Ding for the night on the way back. The Mrs put her name on the next project, its been in the FILs shed for 20 years, runs the engine with 4 on the floor and buckets from the Torana her brother rolled when he was 16 . Jim Currie Reserve just out of Tokoroa (reccomended!) Waikato River south of Huntly- 108 replies
- 23
- unicorn poop
- rust
- (and 8 more)
Day 3 - Scavenger Hunt etc Austin Farina Traveller, a brother from another mother. To the beach! Beach! Prize Giving + Fancy Dress Party was later that night, the first Photo i took after prize giving :drunk: , Best Wagon and People Choice- 108 replies
- unicorn poop
- rust
- (and 8 more)
Day 2 - Grasskhana Low Life Only mechanical failure of the trip. Thanks to Goat and Mr Goat for the use of his Jag House welder and bolts bin to sort it out. Super Leggera + sounded way faster! My most Favourite Photo Thanks Tumeke- 108 replies
- unicorn poop
- rust
- (and 8 more)
Super mission to OldSchool Nats over the last weekend plus a couple of days either side. Over 1500km (Auckland to Featherston a lot of driving around then return) including grass skids and only lost the rear muffler (easy fix), used ~15l/100km until getting a wheel alignment on the way back in Taupo which dropped it to ~12l/100km. Used about 500ml of oil and no water. Came back with a couple of very unexpected trophies, and only a small list of minor tweaks, so very very happy with how it went. Anyway, pics or it didnt happen! CONVOY! Cruising though the Central Plateau Sillouette Split off from the convoy at Vinegar Hill, had some errands in Palmhole and took the Pahiatua Track Finally arrived at the camp around 7.30, so, to the pub!- 108 replies
- unicorn poop
- rust
- (and 8 more)
Catch Up post: Shake Down Run to Oldschool.co.nz burgers meet in town last night, where it was pretty well received Car went great, feeling pretty confident about the tip to Featherston next week (JINX!) Photo Credit to: Dorian (DCG Photography) https://www.facebook.com/pg/DCGPhotographyNZ/photos/?tab=album&album_id=505248416265912 Guy With Aviators https://www.flickr.com/photos/45457939@N08/sets/72157678363759483/with/33428289802- 108 replies
- 7
- unicorn poop
- rust
- (and 8 more)
OS Convoy To Nationals. Leaving 7AM DRURY BP
azzurro replied to piazzanoob's topic in Upper North Island Region
Locked and loaded. Ready to blow! -
Auckland Monthly Meet - Wednesday 22nd March
azzurro replied to Shakotom's topic in Upper North Island Region
Good Meet indeed, and thanks all for the positive feedback! Great photos too everyone. Ok to steal (with credit) photos for threads? Cops were pretty GCs, i think they just wanted to see what was up with reports of a 'car enthusiasts' meeting. They may have just been hanging out when people started showing up and decided to hang around, dunno? A good attitude* goes a long way Anyway, they left laughing, and pretty sure without issuing any tickets, tho im sure they could have if they wanted to (self included) They were poking at the camber/tridents combo on Richies trump for a while but i think ol Snoozin barry-sharned them senseless (i overheard talk of certain camber degrees stock and trailing arms when i glazed over...) . Anyway, A+ sharns! (*as in, getting a bunch of 'howzit, sweet bike mang', instead of 'fuck off pigs' probably made a difference) -
Sexellent. Synchronizing watches... -
Lucky gas Is cheap over there! With the low roof/big stove I reckon kitchen at the back then so you can stand at the stove, instead of kneel. You could still have bed at the back (I like being able to jump into the side door and get changed and hang out and stuff in the lounge in car parks, its abit less obvious and requires less room) just make the kitchen 'slide' out from under the bed, and/or make a section at the end fold up as a splash back/stop crap going in the bedding - you wont be frying and driving or cooking and sleeping atht same time! You may be able to rig something to hand the bikes above the bed? Just don't sit up in the middle of the night! You might need to get the sketchup going. Also do this:
- 43 replies
- chevrolet express
- awd
(and 1 more)
Tagged with:
Can you get swiveling captains chairs for these? If so bed at the back for sure!
- 43 replies
- chevrolet express
- awd
(and 1 more)
Tagged with:
Sweet van, sweet base vehicle. RE the bed location, i reckon it depends on how you intend to use the space, and how much room gets taken by the mattress. In my preferred van layout (LWB Nissan Caravan) the (queen) bed takes the rear length (*snarf) to the sliding door, with the space in front of the bed/behind the seats for getting changed etc, with a side awning/tarp as the main outside. Your van looks a bit shorter and the barn doors suggest to me that the 'lounge/kitchen' space at the rear would be better. Setting up a tarp that accordions out when you opened the doors might make it more usable (stand outside when cooking)? Are you planning on making the bed convertible to seats? (this wastes a lot of space imo, and compromises the comfort of the bed, and i prefer sitting/cooking outside. With your temps this might not be ideal! RE storage, i reckon you want to make as much use of the roof as you can, big racks (doubles as a roof deck?) and all the wet/muddy toy storage up there (bike box?)? If you are super worried about it make the bed a bit higher so it can slip underneath (make the bed height to suit your chosen storage box), but the roof looks pretty low so IDK? 8 months in a van means i would want to prioritise making the interior space as comfortable as possible.
- 43 replies
- chevrolet express
- awd
(and 1 more)
Tagged with:
Cheers duders, I have a model of it already, blue with white roof, red interior, and black wheels Pretty keen on the 124, but ill see what the boss says about it first! If i do get it I wont be getting onto it for a while - the 125 needs some loving first. I generally like to apply 'if fitted then must work rule' to parts on my cars, and i thought they needed to work along with wipers - might be a vehicle age thing? They didnt check them in the end, but i like to have them and they are now electric. -
Booked this in for a WoF today. Didnt quite make it all the way. (run out of gas) Lucky i had someone who thought it was flippin hilarious driving the support vehicle Looks pretty cool even busted on the side of the road, but "get the fuel sender working" is now at the top of the list! Ive put about 30l of gas in it since i put the tank back in, and ive driven it maybe 3km, so not sure where it all went! Cruising in traffic. Goes pretty good, but i think i will get the radiator swapped out for a newer one that doesnt leak and maybe a couple of pusher fans. Dash guage reads near the top of normal when its sitting, but the mechanical one reads normal (~90degC), but thats in the lower hose. Up on the hoist. Nice to see the underside from more than a foot away! Guys were pretty happy with it. !!!WOF AQUIRED!!! After that popped around to Mr and Mrs Grants to show off, and went to Burger Fuel for lunch in it, gets lots of looks and thumbs up, and 'what is its?' Swung by the beach for a surf check on the way home No surf, so then made a start on the post-WoF list of things to sort! - Fuel sender - wheel alignment - radiator + fans - door & boot locks (no key for any of them) - more driving!- 108 replies
- 35
- unicorn poop
- rust
- (and 8 more)
Keen on early start to convoy and many stops along the way. What is the preferred route? (Id like to swing via palmy and pop over pahiatua track but thats for my own selfish reasons and that way other than the track is a bit boring) Safety in numbers. Between all of us there will be sufficient tools, knowledge and parts to strip and rebuild a diff to correct lash, or diagnose and refresh all electrical parts on at least 3 points ignition systems, but no 5mm allen keys. Cant wait.
