Everything posted by azzurro
did you over fill it maybe? only really need to pack the bearings (plus a bit for luck), not fill the cavity, thats just weight and wasted grease as theres no friction surfaces that need lubing in there. grease is not compressible so will force its way out under pressure, say as you tighten the nut or the car sits on its wheels for a bit and the weight seats the bearings. Sometimes can get air pockets or small areas (say between the bearing and seal...) that can get airlocked and the grease will splurge its way out. Any cleaning solvent left in there will also mix with the grease and hasten its pathway out Pop the wheel off, have a butchers, give the seals a wipe and wang it back on
Tonight Postie hand me small package from Czech Republic. Is good. Much Excite. Then Disaster. The spindle shafts want to share the same space and i need to get the throttle connection and slave arm in there too Its at least 10mm too close to avoid some form of trimming to the spindle shafts. Spindles touching its 50mm barrel to barrel on the carbs but on the manifold its only 40mm barrel to barrel I wondered if my manifold was a dud one, but nope, same set up with Dellortos on my 125. Pretty dang tight even tho the mounting holes look to have been welded and redrilled a couple mm over (not by me). Wont do anything too drastic untill the manifold studs turn up, and then i can figure the exact amount of clearance ive got with all the gubbins fitted and mount the throttle cable because mm are going to matter. Bloody thing. May end up getting it running again with the single carb first. I just want to make the noise
- 81 replies
- gottacatchemall
- fiat 125
(and 4 more)
Tagged with:
Yoeddynz and Hannah's HB Viva Wagon Discussion
azzurro replied to Willdat?'s topic in Project Discussion
"no Smoke or anything' Out of oil? (Love your work) -
I also received a big box from the mother land (ladapower.com) mostly dress up parts for the interior and exterior New (black!) door handles with locks - im hoping these will fit The windscreen had a chip that has turned into a crack and will need replacing for the next WoF (doe day after Drag day) - i have a spare screen, and now i have a new rubber and a couple of panels if the corners are a bit crusty (lol, 'if'...) The ladapower stuff is cheap, but sometimes its laughably shit. For some reason i got 3 of these winders (they were US$2 each) , each of them have different QA related faults. I also got two interior door handles, both are slightly different and look they they were cleaned up with a spinning rock before being 'chromed'. So i probalby wont use most of the stuff on the inside, but I have jammed the first bit on, black plastic gutter trims (125 ones are stainless) to replace the nothing/old adhesive backing top i assume was from some stick on chrome strips And swapped out the FSO zinc coasted door striker plates for some italian 125 chromed ones and fiddled the door adjustments too. Im jonesing to put the engine and box back in but im waiting on the clutch scenario, and i may as well wait for the carb parts to show up as well. Other jobs i could do while im waiting but dont really want to include: - install the electric fuel pump in the suitable spot under the rear tray (will probalby jury rig it 'temporarily' in the engine bay) - swap out the old leaky heater core for the lada unit i have from my last ladapower order (will ignore for now) - refresh the rear diff/brakes (need to get some toyota ae1xx rear arms to make the linkage arms adjustable to fix up the whack diff pinion angle)
- 81 replies
- 8
- gottacatchemall
- fiat 125
(and 4 more)
Tagged with:
The guy I got the seal from also had one of these Its a quality italian FAVA steering centre link that goes between the steering box and damper, and the steering tie rod ends (2x each side!) bolt onto it. So many ball joints! Meant i could now use the cheap Delphi tie rods i got from Rockauto a while back Old rubbish vs new hotness. The old tie rods were actually ok (the outers at least were replacements) , but the ball joints on the center link (that go into the steering box and damper) were stuck solid. Ive used the straight (and much much cheaper) Lada fitment inner tie rods on my 125 Sedan as well and it seems to make no difference, the 'bent' Fiat ones just have a bit more clearance from the centre link ball joints at full lock. While i was there I also test fitted the larger 132 front brakes, and figured out why my wheel bearing keeps going out of spec. The little lock tab had broken off so the washer was able to spin with the bearing and then act on the nut is there nothing a blob of weld and a flap disc cant fix? Bigger discs fitted too, turns out just the caliper carrier and disc are different from the standard 124/125 stuff, as the calipers are exactly the same. So I dont even need to bleed the brakes, post a brake upgrade, and the top hat thickness negates the need to use the factory 6mm spacers ------ The white Hammerite was chipping off the meshies, so while the fronts were off i sprayed them Actually sprayed a couple of them a few different colours until i settled on 'wheel paint : silver' in a can over a darker (previous coat of unloved bronze) base Added a bit of a mist of highlight to the inside of the mesh from the back
- 81 replies
- 9
- gottacatchemall
- fiat 125
(and 4 more)
Tagged with:
Ive been waiting for a few bits, specifically a clutch kit (may as well, 'while im in there') which seems to be unobtainium in NZ now. I guess ill be tripping over the engine and box for a bit longer until i get a clutch kit, or just decide to send it. However i did get a gearbox input shaft seal the other day so at least i could swap the bell housings over and button up the 'new' gearbox with a couple of new gaskets as well, so this is now ready to poke back in. All the other bits are standing by, the clutch release bearing is the original FSO stamped one, and is ok but getting a bit grumbly. All my spares are much worse. Pressure plate and clutch disc actually look pretty good but they were very very greasy when they came out, but they will probably be ok to use. I only really need a release bearing, and i didnt think the old one was too bad before. Will see how my fiat parts man goes chasing down a clutch, as im also waiting on some sideys parts. If the sidey bits turn up ill probably just chuck it back in as it is, just so i can hear the doorts. Flywheel and stuff are all clean and ready to go too. I had to cut the 'old' gearstick to get it out cause it wouldnt 'just pull firmly to remove', as this and the bushes that go in it are near new (ladapower). This was purchased to replace the OEM black one on the bottom that slipped off the gear box and AND and has no threads for a standard knob either. The short chrome one on the top is the only one i could find in my spares, probably from a 124 coupe that also have the box extension in a different spot Ill have to see if the shorty one feels OK, else ill be cutting and shutting the black ones together to make one good one Neighbours new car is rowdy.
- 81 replies
- 6
- gottacatchemall
- fiat 125
(and 4 more)
Tagged with:
Waiting on parts and so there is a lot of things half done. Put the face back on, and swapped the big round FSO badge out for a black an old Fiat one, matty b over the pitted chromed plastic to murder it. Tidied up a lot of the wiring, all sorts of hacks and redundant add ons removed! Drivers side wiring wrapped in self amalgamating tape, much better looking than the factory packing tape stuff. Passenger side cant wrap it yet, but - moved the coil position and wiring tidied, - window washer pump relocated and old one it was cable tied to removed - fuel pump wiring and fuel plumbing still to do, but waiting on barbs and bits This was the old exhaust manifold on the secondaries side So i went and got the exhaust manifold from my old 1608 engine from the blue car that i spent a few power file belts on This is the port to the same gasket as above This is the head side gasket to ports took a few mm here and there on the inlet side of the head just to avoid any steps, but otherwise this 'big valve' head already matches up to the gaskets and inlet manifold really well. Should go much better.
- 81 replies
- 9
- gottacatchemall
- fiat 125
(and 4 more)
Tagged with:
Yep. Take the top off and have a look. If your gonna do that may as well give it a brakleen rebuild. Get an exloded diagram. Watch a carb dissembly video. Take notes/photos and be clean and organised. No extra parts on reassembly = win
I reckon it probably will but im no @vivaspeed or @yoeddynz
Just reread your question - yes your dgv carb will fit on that manilfold
Pretty sure the bolt pattern is the same accross all the small downdraft webers so both should bolt up to the fannymould no problem. However actual choke holes may be at different ends and linkages can change around sides and rotation directions and the dcd will be taller than the newer dgv (and a different top) so more likely to have linkage and filter dramas than manifold fit problems
Painting day Not too much in the way of prep, mostly lots of Wax and grease remover and a stripper wheel for the worst/easiest accessible bits Half a roll of masking tape later... Much better, like 1000x better, should be real easy to spot oil leaks now! Just dont look too closely... in addition to the poor prep multiplied by painting outside to the power of the 'pretty hard to do a really good job' nature of an engine bay, i also had a bit of equipment failure/operator error and dribbled runs everywhere. Oh well, most of them will be covered by engine bay things soon enough and its way tidier looking than before
- 81 replies
- gottacatchemall
- fiat 125
(and 4 more)
Tagged with:
This little guy right here, And probably the gearbox seal for good measure New box needed a few bits swapped over including the bell housing, and just need to order a rear seal (28-47-8) to reassemble. Old gearbox oil pan complete with metallic sparkle flakes Then moved onto the engine and I: drained the oil took off the back plate and water basted the coolant galleries (eeeewww) I then took off the old head, old gasket was pretty compressed (sished into dome) but no blow outs Scraped the block took off the sump and straightened the dents in the base and painted it removed oil pump and cleaned it - probably need a new one the teeth are scored and the interior of the block suggests a history of lack of oil changes and probably the reason for the bearings checked the front and rear main bearings all look pretty new and good (remember to re-torque!) end float was also in spec (it had been suggested as a source for the noise + the thrust washers are right by the leaky crankseal ) Checked a big end bearing (looks new) and dropped a cylinder - the rings look newish/aftermarket in the original FIAT pistons, Cylinders look ok, no vertical scoring or lips anyway, i think they've been ball honed. Anyway, i think its had a ring and bearing job not too many kms ago so thats just fanbloodytastic by me. Painted the block Plonked the new head on it Greasy hands so no pics of all that but this is the new head on the old block. I need a few manifold bolts and some Hylomar Blue and RTV to fit new gaskets and stuff so the engine is stalled for now and its time for a beer.
- 81 replies
- 7
- gottacatchemall
- fiat 125
(and 4 more)
Tagged with:
A bit of head prep while its on the bench, much easier to set the shims and everything with the head off! Also made these restrictors for the oil feeds to the cam boxes. These are M8 grub screws with a 3.5mm hole drilled in them. they will help to - increase the effective oil pressure at the main bearings - reduce the tendency for the cam boxes to fill up with oil under sustained high rpm Drilled and tapped into the feeds in the head, the cam boxes go on top (valve is to the left) Also yanked the engine and box This is the bay after a good waterblast! I will probably give it a waft of paint while i can, and wrap the messy wiring room, and move a couple of things around, battery in the rear maybe. Sorry for the shitty pic, my hands were pretty greasy, but not as greasy as the area around the flogged out crank seal which is the actual reason to yank this all out. Nothing like a wee bit of scope creep.
- 81 replies
- gottacatchemall
- fiat 125
(and 4 more)
Tagged with:
these Weber DCOE 40 - 151's popped up at a good price I <3 DOORTSso i jumped on them straight away and picked them up from @dspec_tt131 the next night Ive already pulled them apart and checked the jetting, they are in pretty good nick and the jetting is even pretty close. (They were on a pretty hot mini http://www.themotorhood.com/themotorhood/2015/9/3/mini-mod-1976-leyland-mini ) Ive ordered a few jets that should put them in the ball park along with the missing fuel banjos and throttle levers and spacers. Got the Holley Regulator and the Innovate AFR Guage with them too, so it will be great to actually test the tune directly. I also got a couple of these low pressure fuel pumps and the K&N filers in a Rock Auto close out sale a while ago. Obviously they will need a manifold. CHECK (already in stock!) I also collected my 'big valve' head i got off trade me a couple years ago for $30 to bolt it all to i suspect something went though the inlet based on the dents in the dome and a new exhaust valve and seat in cylinder 1. It also came with reground cams that look like they've never been run, dunno if they are performanace grind or not but everything is clean and new looking so im sendin it.
- 81 replies
- gottacatchemall
- fiat 125
(and 4 more)
Tagged with:
azzurro replied to azzurro's topic in Project Discussion
@Abarth from the shelf in my shed, why? shim tool was from autoricambi.us i think, shims are collected from various spare engines and etc there is also a specially bent screwdriver with a specially sized end and a magnet on a stick for getting those slimy buggers out of the bucket can borrow if you want? Rule number one of of shim-club is: one shim in one shim out -
Yay burgers. @Shakotom reminder can you please bring that cdi?
very nice cars @Aip, your interiors look very nice, not seen a blue one before, makes me want to drive mine, do you have any more pictures or a story? -
Drove this around a bit int he last few weeks, and its going better for it. Ebay treasures Driving it showed there is still a few things to sort out and, the flippin left turning noise is back. General running, engine is a bit tappy. Checked the valve clearances, its about -0.15 tight all round so i reckon the cam box gaskets have been compressed over time. Except a couple of exhaust valves which were a bit tighter which could be recession, but probably not. Anyway, I set those 2 back to -0.15 out all round. engine runs a bit smoother and quieter. Horn stopped working, and both of these (polish made, high and low tone) tested dead on the bench replaced with a random toyota low tone from under the house untill i go to PaP again and raid another euro (they have the best horns) This 132 front brake kit showed up on trademe for cheap, slightly bigger diameter discs and calipers (with new pads) and carriers, these bolt on to 125 hubs so will suit the ute or sedan. Not decided yet. 20mm larger diameter and a bit thicker with aftermarket vented discs available There is a pretty serious oil leak from the bottom of the bell housing, and i dont want to be 'that guy' at drag day. i suspect the main seal.and the clutch is getting pretty low on adjustment and feels is a bit gummed up and grabby but slippy at the same time. I also think that the turning noise may be gearbox/clutch related even though i cant fell it in the stick and the box changes well. Specifically the spigot bearing, or the main shaft roller ball bearing in the front of the case. Ive been chasing rainbows on this one for a while and seem some shit man, so im not ruling anything out. Changing the clutch means dropping the box, so ill be able to check and fix a lot of stuff out in this area. Ive ordered a clutch kit and bearings and have most of the seals and gaskets 'in stock' So in preperation for it being a gearbox issue, I dragged this from storage and gave it a waterblast, its a low km FSO 5 speed box from a Polonez car someone stripped when it turned up at PaP. This is a copy of the 'late type' Fiat boxes and is the same as the one in my truck at the moment. Looks pretty clean on the outside now, and apart from the dirty oil, the inside looked ok too. If i do have to swap boxes the bell housing needs to swap to the fiat one in the truck already, to put the starter on the other side of the engine. This particular bell housing will be kept around as it will let me bolt one of these Colotti 5 speeds to the 2300 engine if the column change every goes bad (please dont go bad!).
- 81 replies
- 9
- gottacatchemall
- fiat 125
(and 4 more)
Tagged with:
Caffeine and gasoline at Hampton Downs
azzurro replied to Bantam's topic in Upper North Island Region
The drive from mine to Smales is 100% boring motorway too, but Hampton is like 5x as far on equally boring motorways. I assume the idea is that its up to attendees to choose which ever one is most convenient/interesting and go to that one. Choose your poison - Durrty South or Sure Things? -
How have i not seen this thread before? Top work champ
lush!
Took it for a good drive yesterday, wow, what a difference! Cant feel the engine bumping around though the pedal now, and the pedal modulation is way nicer. However some further mods needed. Pulled the pedal out for a bit more bending to put it in just the right place. should be a bit more comfortable. Added a throttle stop and not just to keep @cletus happy, its a good mod ,makes it feel more OEM. The stop is the two big nuts, one tacked to the fire wall, the other a lock nut, and the two upper two bolts secure the pedal mount. You can also see a big bent oval hole in the firewall from the old linkage, through an even bigger factory triangle hole in the arch above the steering box though to the firewall and steering column gasket etc which is all right behind the front wheel... Made an 'inner arch' from some thick plastic sheet to block the big and smaller hole both off from water and grit from the wheel. Should keep the engine bay cleaner and dryer, and made a big difference on my sedan to road noise too. Made a stiffer engine side cable mount set up, using the old 'custom' linkage mount as a base and some random channel from the 'that will come in handy one day' pile Super happy with how this all worked out, usually i have to make this stuff 2 or 3 times, but it all just fell into place. The cable mount has a spare slot that tidys up the the brake vacuum hose too, and there is a cable clip on the other cam box. Minty. The toyota throttle wheel just got tacked onto the old universal linkage. Toyota AE82 parts for the win! ---- Found these NOS indicators pretty cheap on ebay and they turned up the other day, so then I swapped out the mismatched and cracked old ones. had to change the connections that had already been hacked up, so also tidied the wiring a bit. Now the flasher goes way faster. One toyota part in, one toyota part out.
- 81 replies
- 6
- gottacatchemall
- fiat 125
(and 4 more)
Tagged with:
The throttle linkage is very shit, i think its from the (131?) donor car the twin cam came from and has been hacked in, rubs on the hood latch and rattles a lot. So very shit. Had to cut it to get it out. I was happy to make it inoperable. $18 Pile of likely looking bits from pickapart, mostly from a Toyota AE82 hatch Firewall cable mount just tucked in behind the loom hole, worked out perfect Had to bend the pedal a bit to suit the curve of the tyre well/firewall, and still could do with a bit of tweaking to get it sitting just right but stoked. Carb end worked out well too but will probably need to remake the cable mount a bit stiffer sooner rather than later but it got dark/no photos. Test drive tomorrow,
- 81 replies
- gottacatchemall
- fiat 125
(and 4 more)
Tagged with:
