Everything posted by camo_78
thatd have them,will go have a nosey on friday(day off course),cheers
i know im a few weeks behind,but XD falcons have hinged rear plates with a spring to hold them up
sorry i didnt make it,was a slack arse and didnt put the open diff back into the sport in time :/ .anyway,did anyone see any a32 cefiros at PaP??need to raid one for all the interior trim clips etc etc as im too tight to buy them new
lmao,what colour is it normally?? and mine was originally an auto,i converted it to manual using a 94 wrx box that had the rwd conversion already.will be on motor #3 when i sawp them over :/
they do,ive bolted GTB coils into GT motors and vice versa.so shizzl,i got a couple of covers up here if you want them
your gtb isnt green is it???
got that right,lmao.and nope,26 with a goatee about 5 inches long,lmao. and im not copying,MY gtb is rear wheel drive
this the spirit you dont happen to have a mk2 bonnet spare at the moment??dont give a crap if its rusty or anything,just want one to shove over the panelvans engine bay so it can sit outside under a tarp for a while
ive got a couple of subi motors lying around,do you know if GT rocker/cam covers will fit a GTB motor??this is slightly odd though as we both own cortinas and GTBs,lmao
hey Cletus,quick question as i can never get a definite answer down here bolt on flares:cert job or not?? and does it matter wether they remain just bolted or does smoothing them into body change the definition of them??
what old man Ky said,theyre nice but the steelys are better PS:when are we going to see the 13x9s on the bum of this??and update on the green beasty
i used brass adaptors to fit it into the factory hole on mine,hence it probably never worked.however i found a bung in the side of the block im going to try in the sport.will fit it tomorrow and report back
success,instantly picked up the hot water.must have had something blocking the water in my cortina from touching the bulb
am about to do said hot water trick .and its all 100% mechanical,only wires on the rear are for the light.will report back soon if it works in the hot water
bought a mechanical type water temp gauge a while ago for my cortina,now contemplating swapping it into the sport.when i had it hooked up in mine though it never worked.so what i want to know,is there any special tricks to running a mech H2O gauge??it was brand new when i installed it in my cortina
shvaaaaaaaaagen waaaaaaaaaagen??wunderbar!!! looks like a good projest seediest of Al's,1 question though:can it be slammed lower than the crown wag??lol
i suspect its the shape of the metal behind the heater box(think 1/4 pipe vert ramp for skateboarding),water runs straight down it,hits curve and gets fired straight under the heaterbox to where the gaskets are
check foam gaskets under the heaterbox in engine bay,thats where the sport leaks water in
i have a pair of 13x6 spitties that are a very similar offset to my modgies with BFG radial T/As on them in 195/60 13 sizing.can put 4 people in the sport which sits it on bumpstops(joys of compressies ) and they dont rub.admittedly i did have to roll the lip up to do so but the sidewall sits nice n flush with the guard lip .i would get a pic but its currently on axlestands after i popped an axle in the locked diff PS:hit to the head would have induced i few expletives i suspect??
have you started stocking up on valve springs yet?? looks like a good purchase though PS:TRIDENTS
+1 for straight rear,angled looks wacky against the deck boss
that was indeed me,however it was my other cortina(the sport).and you would have noticed it only did a one wheeler??its actually got a locked diff(out of this cortina),but i snapped the drivers axle as soon as i dumped the clutch at the start .the motor out of this one is going into the sport soon as this one will be getting a new motor built
hes onto it .personally id go everything in bay black except obviously the sheet metal,and just have small silver highlights(hose clamps,bolts etc)
im voting sunday the 5th,but in my case its subject to the fun topic of finances .i should be there though,will have to bring the cortina as a bluebird would look out of place,lmao
any wiring gives me a headache
