EvoBilly
Everything posted by EvoBilly
can some one please tell me do i need window washers on a 79 corolla for a wof coz when it was painted the holes for them got filled so theres no trace of them any were i do plan on fitting a nice chrome on on the bonnet when im game enough to drill a hole in the new paint also is a custom made dash going to be any issue come wof time?
so im in a mad panic trying to get this sr done in time for nats ive been on a good roll up to this point i opened the box with all the wire loom for the whole car front to rear ive worked out what part goes roughly were engine bay part under dash part and to rear loom now ive found a heap of cut wires in the engine bay loom and under dash loom i would like to tidy this all up but i need to know what the wires are for so i can fix the ones i need and remove the ones i don't need so im hoping someone knows of a link for online book to wire up the car
Redwood Tavern 15th Feb @ 7pm - meeting to discuss OS Nats
EvoBilly replied to Chris.QCR's topic in South Island Region
paid for boat good to go all i need now is a car thats going times running out -
We could squeeze someone into viva between blenheim and picton. i should have room in my car but i wont really know till i know what car im taking and how much car parts i need to fit to drop off up there -
just to add to this idea if you need some were safe to leave ya car can park it up the back of my house in blenheim then im sure there will be some way to get ya to picton -
help wanted with mk2 escort engine<not running right
EvoBilly replied to Horse25's topic in South Island Region
hahaha i just put a 1300 in mine and its got the same issue gonna have a play around tonite on mine what things have you tired on yours? new plugs? new leads? timing? points? condenser? another coil? dizzy cap and rotor? setting the rockers? -
Bike pick up in marlborough? Problem solved. Thanks.
EvoBilly replied to Valiant's topic in South Island Region
yep i can do something pick up and hold for ya pm me details -
there must be more to slam it out lol remove bumpstops and notch
truimph2500s steels are 15s didn't look to bad
dosn't look as low as the red one was? or is it just the angle of the photos
have you had the drive shaft out? changed ya wheels? what sort of angle are the axles on?
yea i used saw dust to soak it up when it happend i'll try some thinners on it once the weather comes right again hopfully mother nature removes some of it
its rough old concrete if i had money i would smash it up and re-do with new so it was level and smooth for now would just like to clean it the main issue is my 15 month old runs round on it and ends up black on his cloths then the yelling starts lol
as the title says had a old man moment and forgot to drain the oil from gearbox before pullin the axles out end result was bout 3ltrs of oil on the drive leaving a good stain ive got a work area were i can spill oil on but its got a work in progress car there so i was working in the drive the other half is now REALLY pissed off ive tried to scrub it away with degresser and water just thined it out and made it bigger there must be a pro trick to remove it mods if this is the wrong section please move to were it should be
^^^^ what he said just give them a good clean in most cases you can see some impact stress marks in the alloy a spin on a balance machine will show if there tru and round still if there not then i would be worried
yeah ive got my sounds sitting in the shed once car is running i'll chuck them in also who will have uhf talky walky's so we can talk shit between cars well traveling -
The shifter has a big plastic nut that screws into the top of the box, you need to bend up the locking tabs around it then just undo it and the shifter lifts out. Don't cross thread it when putting it back in or it will likely develop the amusing habit of popping out of the box when you change gear lol /\ fancy aftermarket short shift, but gives you an idea of the tabs etc. SWEET
if i come into some money it sure will be the issue is fuel it uses due to poor gear ratio 100km is just over 4000rpm = alot of fuel use options are 1978 ke35 - main choice 1979 ke30 1979 mk2 esky - at this stage backup 1979 eb3 civic 1955 ford ranchwagon otherwise its new school jap which is not a option and anyone that wants to come to blenheim a bit early or night before i have parking space and tent space between cars thats if ya not all at alexs olds (which is just around the corner) -
Go gray or black to be a sheep or be different or extreme images of idea's just to make the choice harder doesn't really matter what color ya go they look good full stop
can anyone tell me how the gear leaver comes out of the manual tranz or do i leave it in when taking the motor and box out and in the car? going to plan this car should be running on the road by the end of this weekend
i to would like to know were to pay for ferry and when it just me (billy) in i hope to be in my ke35 rolla if not my back up car is the same age and size and im booked to tent at low n slows just confirmed -
sounds like the 2nd hand one you brought is stuffed too
chip/ retune the factory one or aftermarket ecu in saying that it will run on a stock ecu will just lean out on boost
this dosn't answer ya question but ke70 rails do not fit a ke30 or 35/36 or 20/25/26 they all seem to be the same width and same style of mounting just the distance between front and rear hole is different if kp rails don't match ke70 im keen to know if they fit ke35
fuel guage is all fixed found 1 wire had a lil nibble out of it
