Everything posted by mjrstar
I brought the front up 15mm before the track day which has helped with the front end feel. The rear is all factory arms which as you guys mention above would be a good place to start looking to improve. The 33 year old rubbers have probably done thier dash. Sorry no video which is a shame as it does sound pretty decent.
I have used one of these on slightly lighter stuff and did not have any issues with doing some fairly tight bends, are you running the seam of the pipe on the outwards radius?
Track day was a success, looks like it leaks a bit of fuel out the filler when it's full.... I have ordered a 40L fuel cell so stay tuned for the progress on that.. Some minor brake shudder which I reckon could be down to my driving style as it seem to get better once I started working the brakes a bit harder... still struggling for rear end grip at 120-130kph, probably should have played with / at least checked tyre pressures, but happy all the same as i did around 90 laps of the short track with no issues... Didn't even need to open the tool box..
pretty sure this is the PDF I have.. http://www.supra.co.nz/1g/1GGEService.pdf Section A9 onwards...
I have some stuff in PDF form which might do the trick, PM me your e-mail address if you like.. Also this probably needs to go into tech help if a helpful moderator comes along....
I have one similar you can borrow for a bit if you want... (I'll have to make sure I know where it is though)
I think the traction issue is 2 fold, firstly there is not enough weight in the rear, and secondly it's running some semi slicks which are past their best before date.. It tends to hook up a little bit better at the track once it gets some heat into the tyres... although it's still not great.. on the looks front, it's ok from a distance, but my back-yarder panel / paint skills let it down a bit when you are closer than about 20ft away..
cheers guys, fingers crossed it doesn't decide to part company, the wing on my evo is held on by 15 (yes Fifteen) bolts, whereas the one on the hatch of this thing is only held on by 7...
I got the injector wiring sorted out with some new crimp terminals from NZEFI, also wired in the new alternator... and fixed a minor oil leak (i hope) and a fuel weep from one of the fuel pump outlets... The road was dry so I took it for a burn up the road, the boost flutter seems to go away at full throttle, but is there at around 60-80% , problem is that on boost is not normally the best place to be using copious amounts of throttle. Had a minor moment at around 3500rpm in 5th going up a bit of a hill when it decided traction is for fags..... I decided it was time for the car to go back in the shed.... Proof it actually went outside: It's eaten an exhaust gasket but luckily is just the down pipe one so it's a easy/simple fix..
Well that fully sux, I assume that's then exit of the hairpin at Pukekohe? For some inspiration this is my mates Evo which he injured at Puke, after finding some donor bits from a libero it's back to full health. Before After:
FYI just in case anyone else ends up needing some I ended up getting a handful off NZEFI for $1 each, so that was a win!
I used some M5 riv-nuts... they seemed to have done the trick...
looking good, I would anticipate a possible issue with burning of the driveshaft output seals if they are no subjected to the occasional dose of oil.. i reckon a simple pump/squirter setup might be worth looking into as Mr notch eluded to above the major splash lube for a FWD gearbox will tend to be from the CW & P.. also I am sure you would have already anticipated blocking off the factory breather location and fitting something at the new top of the gearbox.. but how will you go about draining the oil out? it could be worth looking into a suction tube with a fitting on it to drag the oil out like a lot of big machinery has? Once again I am impressed with the lenghts you are going to in the pursuit of maximum low..
this 200A machine.. http://www.esseti.co.nz/xamig200cmts-mu ... -p-98.html The plan was to get a spool gun for very occasional tinkering with the likes of inter cooler / radiator mounts, inlet manifolds etc.. The added plan with the spool gun was being able to swap out for a mini spool of stainless wire without having to stuff around with a 5kg roll - if the need for burning some holes in stainless was to arise.
I did a bit of a youtube search and there seems to be a method of basically stacking a whole bunch of tack welds in close proximity which seemed to leave a resonable result.. I guess I could get one and give it a hoon, even if it was just used for tacking suff up and then i can take it to a mate of mine to give it the Tig treatment..
This is a great conversation topic, what i found going to a taller ratio (from 4.3 to 3.9) in my starlet was that the car worked well with the increased load and actually made the car a fair bit quicker, the issue i had is that it would not make full boost in 1st or second gear as it would simply rev out too quick. Giving it longer legs was a great upgrade. This would be an isolated occurence and was probably based predomanantly around the current power to weight factor. you could pretty muh ignore this arguement on a N/A car. Ideally rather than just changing final drives the best thing to do is get a decent gear set, normall comprising of a taller 1st gear and then tighter spaced gears between 2nd and 5th. This provides all the benifits mentioned above, but probably the biggest improvement will be the time it takes to shift. Clutch mass and speed difference in the shafts are probably the 2 biggest limiting factors for how quick you gearbox will accept a gearchange. (other than general mechanical condition) I noticed a huge difference in my mini when I changed to a close ratio setup, you could feel the synchros were not having to work so hard to "speed Match" the gear selection. it will no swap cogs as fast as you dare wrench on the lever. Pretty sure most will TL:DR this but Meh..
My new mig is set up to be able to run a spool gun, I have been considering getting one to see if it's of any use. I was just wondering if anyone has had success welding aluminim and if so down to what thickness and what gas did you use. At this stage I can't justify splashing out on a Tig and the idea of the spool gun is for the occasional 1 off aluminium job, with the possibility of gluing up a bit of stainless from time to time as well. If they are a waste of time / no good i will just spend the money on beer... My assumption was that if aluminium mig was totally awesome/quick/easy then everything you get from China/everywhere else would be migged not tigged, but the majority of stuff you see (such as radiators intercoolers and catch cans appear to be tigged) Cheers Matt
the other thing to think about is moisture/foriegn bodies making thier way in, some form of breather system is a better cleaner way to prevent "stuff" getting in. I am not a great fan of plumbing the vents to the intake due to un-necessaray oiling of the intake pipes etc.. (the idea above using the exhaust looks interesting) but if it was me i would vent to a filtered "catch can" but not worry about giving it too much in the way of vaccum to assist with the ventialtion.
10 5 will be all over this, i bet he is planning on running the chain in a criss cross / figure 8 configuration to make it drive the correct way and not get his balls meted by the exhaust. He is probably just devising the vertical chain deflector as we speak.
Sweet, good to know. I will need to devise a plan to attach in a strong enough manner so it doesn't part company at 240kph.. I was thinking either some M6 nut inserts or possibly welding some short bits of m6 threaded rod onto the hatch.. either way would get some decent load spreading material strips of steel/thick aluminium over the mounting holes to prevent cracking.
In an attempt to help high speed rear end grip I have decided to try a bit of a wing on the car.. I have no idea if these actually do anything, i did a bit of research and was unable to come up with any solid answers.. But given the shape/area compared to the one on my evo (which apparently does have quite an affect) I decided it was worth a shot, and the purists will already be anti my car as it has other bits of fibreglass hanging off it.. Wing - (Wrong colour) Still the wrong colour. Attempting to make it the right colour (this was probably a tad ambitious given today's weather and the minimal amount of 4+ year old paint I had left.. I was resigned to the fact if it turned out to be fail burger it'd make a decent high fill and hit it with a dual action sander to cover any minor imperfections in the fibreglass.. The finish wasn't too bad, so i will probably give it a whack with some 1200 once it's hardened off a bit and make a decision from there.. That is all.
the engine bay is looking nice and tidy - much better than the busy mess under the bonnet of my kp. good work
^^ keen to see the pics man.. i think i might just buy 6 complete plugs and just re-do that portion of the loom...although 2 individual crimp terminals would get me up and running..
Ducting? Can you improve the in/out airflow in such a way to prevent air wanting to escape around the sides/top/botom of the radiator? The oil cooler sounds like a good option although it may not make a huuggee difference to coolant temps.
^^ yeah also mid 90's mitsi magnas I believe..
