Everything posted by 77magnum13hundy
77Magnum13hundy's 4age+t Magnum discussion
77magnum13hundy replied to 77magnum13hundy's topic in Project Discussion
yep, parts of an 1800 havent really sorted out whats what yet... mean score tho -
So got another parts car, Got her home with this Has a few bits i need to get my one in ship shape, and its always good to have a few spares. Big thanks to Anthony for the hookups and sorting it out. OSGC -
77Magnum13hundy's 1977 Vauxhall Magnum
77magnum13hundy replied to 77magnum13hundy's topic in Projects and Build Ups
tidy up of the engine bay. sussed the radiator out, has fan attached which runs off the link via a relay, still need to get the OG temp sensor working for the dash cluster. also blow-off valve needed a vacuum link so ran one off the top of the throttle body seems to be much better. moved igniter and relays into one corner and the catch can moved to a suitable place. Few holes to weld up and the engine bay will be complete.Seats are attached properly now Starts and runs fine now now need to work towards getting the driveline and brakes sorted still heaps to do... -
Keen for a bus house, one of them old yellow buses from back in the day. This is totally awesome.
2tgeu start and run for a few seconds then die
77magnum13hundy replied to hillman1's topic in Tech Talk
Tps needs the correct values sent 5 v in and then ones an earth that and the third is the one sending values back... If its got 4 wires ones an idle sense. Multimeter and feeler gauges to set resistance at particular stages of its rev cycle... is throttle body and tps all Og? -
oh my that engine... was wondering when this would happen as i was reading through the thread... nice one
new feet 215 50 13... get to keep the ol wheels... motivation levels are at all time high -
dunno if this works but here https://www.facebook.com/photo.php?v=10151973027480957 -
kinda have to get some other wheels made to fit as whats on offer in the 13inch range isnt that great. 15 inch range however would be better for availability something like some 19555's should be good as i cant run stretch tyres with this setup in the legal sense. Will always have the 8 inch wide 13's though cos they are slick but not yet *cough cough... looking at 15x8 and we'd be legal. -
no wheels yet, need to sell one of the dailys to buy some 15's then get them re-drilled to 4" x 4" and then skids... -
Coil pack replaced with a newer better mitsi coil pack and resistors for injectors wired in, and yes folks we have running motor. Found there was an earth wire from the engine to shell which was getting warm when i was cranking so need to find a suitably larger earth to the shell... Pretty quiet too when idle. Stoked as. Choice. -
Hey y'all running wasted spark but one of the coils seems dickered (crack down the side of it, has dropped on the ground and shit oops), can i set it up to run individual coils if the 1+4 and 2+3 get the same feeds/pulses or is there more to it then that? What would PIckeys have that i could pilfer for this? particular makes models suitable? Setup is g1 link with link ignitor running wasted spark on my 16v 4age, (running 4agze CAS) Cheers rob
PM'd ya
77magnum13hundy replied to yoeddynz's topic in Other Projects
speedy work as always you guys... last time i checked it was only a steel frame... now this. -
yeah if they dont have them they can make them, or so what ive been told by the autolign fellows bout 70 a pop, surely theres a GC out there who can find a match based on similar dimensions...
how much you want for the bottom end / gearbox?
Anyone know a good place for vehicle revin?
77magnum13hundy replied to Seedy Al's topic in Lower North Island Region
I got a mitsi galant revinned in palmerston north once, near the bridge as you drive in from bulls way, they pinged me for the windscreen having too many stone chips in it, but i did manage to get the thing legal and drove it home with new plates. They were old jokers and did it first thing in the morning, maybe better chance (if they haven't had a shit day) to do it as early as possible? gotta sit back and leave them to it. unsure about the gbox tho, id play dumb about it. any pics of the patch work? -
Advokit's AE85 Trueno Notch Jap Style Build
77magnum13hundy replied to advokit's topic in Project Discussion
nice build and good to see you going down the 6 speed route. I like changing gears and 6 is awesome maybe il go for that when the t50 i got decides its time. How do they fair strength wise when compared to the w series? -
have added relays for the coil packs and the injectors and have found that my old battery isnt holding enough to crank and goes below 7v and the spark dies off. Also went and saw Stu and found out the injectors im running need a different setup so ive ordered some new ballasts and should get them wired in this weekend. Battery on the shopping list too. Ooh-sah -
the wedding/honeymoon is over and done with and garage time is well induced rite now... went out and tidied the wiring up and made power go to switches and things. One power trace to see if the coils had voltage going to them and then i decided to give her a crank, so we have spark... will see exactly where its sparking when i get my timing light back and then hook up the fuel pump to the relay. BUt yeah quite stoked its got spark and that the fancy push button starter thingy works too... -
what a beast, this is fully sweet man...
drag/push up the hill with a bully? CAT D10 ftw, any decent trees to winch off up the top? / i duno
Another viva update innit So between doing the landscaping out the back, working on the 3 daily drivers and this fine specimen of rusty steel i can say i havent given it much love in the last month or so. Oh yeh and doing my bit for organising the wedding stuff in feb. BIg news was the exhaust is finished... all of it, mounted and everything got a muffler from STA and reused an old nissan muffler. This just means i can start the car up and have it tolerable, not thats its ready to start yet.... I can say tho that all them little jobs that are awaiting me are slowly getting sorted... Massive gains had in the engine bay with the heater now bolted in meaning the water system is all done. Fuel system got a flush and the amount of crap that came out of the fuel lines from just siting there was appalling. So attached all of that now to the fuel rail and fitted the filter aswell. So here is a new cluster i made, its the mark 1 version, pretty much just holding the stuff in place so i can attach wires without it getting shit all over it, pretty lights are cool, and the link is now in place.... And we now have a semi organised area. Ive got to the stage where the wiring is ready to roll... Going to use the old cluster to house the wiring. Pretty much its simple and i can use the old fuses (4 circuits BATT, IGN, ACC and LIGHTS) Got a dip switch to install for down by the footwell and also add some relays for the headlights, fan, fuel pump and something else. So yeah lets get this done this year ... and get to driving it around FFSakes -
yep your right no.4 is on the rock, got them mixed up
If you know where TDC is on the motor (screw driver down cylinder 1 plug hole) maybe take the rocker cover off to see what the valves are doing. number 3 4 cylinder should be on the rock between the exhaust valve coming up and the inlet valve going down. no 1 should be doing nothing cos thats the compression stroke and the spark should happen then. with the dizzy in the correct guessed place... and the dizzy cap off... the rotor on the dizzy and the no.1 plug spot on the cap should match up once the cap is put back in place.... this is only if you dont have any marks to go off. This is how i do it and not necessarily the correct way but yeh...if it aint in the right place move it a notch either back or forward and then try it... dial it in with a timing light too... oh and silly question... it has got a spark yeh?
