yeerrp , not long now and i can move on to the Brake rebuild, engine mounts, diff seals , putting seatbelts in the back , and getting radiator repaired... ahhh the winter list, should have a good one of those next year too ...(floorpan)
front area done:) started nnerrrrgh neeerrrrgh nergh nergh neeeeeeeeeeeerrrrrrrrgh the rear;
has had prang in the rear, has 2 skin wheel arch , inner skin has origional paint on it
pick looking up at rear wheel arch inner
im pretty keen to link my chassis rails as you have done, what would the deal be as far as legalities with doing that clint? cert or frendly wof man required or is it like a standard valiant thing to do and no one bats an eye lid?
yeah if you like, pop a pic in here would be interesting to see what real panel beaters do... im just winging it and will make it work / over engineer it to be stronger than factory!
started on the sill rust , has a good productive thursday ( had the day off with no kids , grinding all morning then went to work and made some replacement panels)
few tricky bits but shouldnt be too bad.
this the bottom of the a piller, rusted out from the inside, looks bad but have a plan of how to weld new steel in
this part will be welded in to bottom of a piller, made a cut in the bottom of part( the 200x40 cut ) so i can weld from under car (inner side of the inside of A pillar) and also from the inside of the car/foot well(to weld to outer of the inside of A pillar) then will patch the cut.
