Everything posted by 63Ragtop
foamer confirmed. It's not actually to bigger job to drill out the spot welds and re-weld them lower down. ew, more foam, were your bump stops at mang? my car a mongrel too, built from about 12 cars, all the shit left over/survived the war/50 years.
I thought there was somefin a bit funny about this car. "It's a 1200 '62 with later panels" I would say its more like a 62 floorpan under a 72(?) body, with earlier panels. windows are to big to be a early car. you should not have that gap between the body mounts like that, VW changed this when the proper IRS chassis came out. that hole with the two studs is for the factory swaybar, or Z bar. There should be just a thin, 5mm rubber pad between the pan and shell, but that spacer will be okay, no sure if it's going to like jumps! This does mean its a king and linkpin front end though right?? perfect for slamming and Baja-ing, heaps more traval than a ball joint beam.
You and me both! At this rate, you'll be finished before me. Haha.
holy smokes! I just clicked that the pics on the mags are not photoshopped, haha. well done.
sTRANGE bED FELLOWs.our cars couldn't be any more different! finished mounting the fuel line, ended up going under the throttle tube. mounted the coil on the cooler scoop, the extra weight makes the scoop flap about, might need a couple more screws to hold the scoop now fitted up the crusty old heater boxes, so I could button up the tins. valve covers will be painted dark grey at a later date.found these little RUBBER NIPPLES at pineline, that place has everything! these block the vacuum ports on the carbs, very handy for keeping you walrus protected also.test fitted the old bugpack zorst, fuck it's shite!!get in there ya wee bugger!! guess I'd better install the rear engine bay seal.ah yeah....
- 254 replies
- 18
Richy's 1991 Porsche 944 S2 - BEWARE OF SHARN.
63Ragtop replied to Snoozin's topic in Other Projects
need more photos please, engine&insides, you must know someone with a camera?? I'm not all that fussed on the blue, but man it looks mint!- 85 replies
- midlifecrisis
- notarealporsche
(and 2 more)
Tagged with:
we gonna rock down to electric avenue...please please work!spent several hours of my life making these air cleaner spacers.now looking not quite as homemade, still need holes for studs on top of the crabs.played mix and match with the fuel inlets on my old single dell, twins now both the same fittings with one side blocked off, so the line will come up though the firewall, to the left carb then over the the right hand side.got the linkage working nice and fitted the sparkplug wires.test fitting the old k&N off the single, new ones will be the taller ones I think.so close!
- 254 replies
- 18
B6HS.Hmmmmmmm.that don't look right at all.so I took it all back apart, double checked everything, took the Alternator off, put the gennie back on, still the same.I think it's been like this for years, I blame the shitty aftermarket tinwear, the Alt can move back into the stand but the shroud and everthing thats bolted to won't let it, I even leaned on it and got a mate to tighten the strap, but that juts made it crooked and out of alignment.need more beer
fan stuff.new oil cooler sealsso the fan housing could get bolted down now. thinking about mounting the coil here.on the top of the oil cooler scoop.
been focused on the engine for the last couple weeks.dirty.clean.mean!was hoping some of it's hp might rub off on my bucket.back in the cave.gave the heat exchangers a good de-grease.they're pretty much worn out, but will do a few more miles/years, until I finally give up on this fantasy of having a working heater.(its never worked)Alt stand and a very quick black paint job.if you look back a couple post, you'll notice the fan shroud had two holes for the throttle cable, neither were in the right spot.sorted.terrible paint on this thing, ran out of primer, ah fuckit!shiny!sparky!after spending a not insignificant amount of time cleaning up all the old, oil covered stainless tinwear screws,I found these new button head ones, ah well!
GIZ!
well, thats another old toyota you own that I've never seen before, well done!
thats a shame, paddock baja will be rustfucked I'm sure. Keen to see a better pic of those empi seats there shurbsbin. Also, flares on a bug? um......
not fuckin around man, on the road by the weekend!?!?
FUCK YEAH, Sweet looking machine you found there. such cool little cars!
Testing the CSP linkagejust wanted to check everything fitted and worked together as I bought carbs, manifolds, linkage separately.managed to turn the engine around and get a good look at the flywheel/clutch for the first time in nearly ten years.a bit surface rusty, should be okay??bench looks like this.car still looks like this, sort of.
- 254 replies
- 15
do it!
A small but important part to getting a car legal on the roads. Really need to be black.It's funny, this car has been a shell for so long, every time I attach another part it's like I get some kind of shock, I don't like it, it looks so cluttered! after a day or two my brain has caught up the new part look normal again. uh-oh.time for a clean and a paint.and a couple new seals, the inside of the fan shroud has a nice coating of oil.no rust at least!
Snoozin's '79 Two Point Five S (It's for SPORTY)
63Ragtop replied to Snoozin's topic in Project Discussion
Finish other red car first. -
pics so I remember how it goes back together.scored some bike wall mounts, made some room.might be able to get the car out now.suspension has settled a bit already.pics coz awesome. Cleaned up and painted the two bows for the sunroof, I have one screw I can't get out of the front part of the mech, The large part that carries the catch, trying real hard to not have to drill it out, these parts aren't easy to find I would imagine? I've got it soaking in ATF and thinners.getting close!!
- 254 replies
Yehp, all the usual things then.
- 138 replies
Well this is awesome Greg, can't wait to see what you and mrs64 do with it, Suby convertion sounds good, even a povo spec 2.0 is better most stock vw engines. Thought about the 6 cylinder suby, 3.0 ltr I think, might be simpler than a turbo?
- 138 replies
Brawr's 1984 KP61 Toyota Starlet Sprint - Discussion
63Ragtop replied to DAD's topic in Project Discussion
Jelly of you asshole with willwoods, with disc brakes actually! Keed at it mate.
