Everything posted by HighLUX
Kmart selectable voltage charger might do the job. Depends what the charging plug type is
Not yet/price on something suitable and can you source the adaptor too? Think it was on Ebay I saw the Malossi ones
When you have a midlife crisis you buy a Harley and ride off into the sunset with the wind in your hair but when you have a quarter life crisis you buy something that makes you feel young again that also fits your budget/requirements. BEHOLD 49cc of Suzuki 2 stroke fury in the form of a late 90s TS50 Its basically brand new as the odo on the super optimistic speedo shows Old owner tried to register it but had a mare of time so gave up and its just been sat in the shed for a few years. Needs the carb cleaned out as it wont idle and Im hoping that helps the already lacklustre performance too. Plans are fit a few dress up bits like less ugly indicators and brake light. LED bulb for the headlight to help see through walls and some prettier/more agressive tyres, so some suggestions on tyres and Ali spec lights would be good. Once I take in my correctly filled out MR2B form and gain a number plate I will collect the bits required to swap on a 70cc barrel kit, spanny and muffler plus upgrade to a 24mm carb with Malossi adaptor because the current carb is a tiny 19mm thing and a CDI thats not so lazy/advance the timing a few degrees. Gives me a good excuse to buy a dremel kit too so will port match everything/shave and smooth castings as well.
- 140 replies
- 15
'Oh man if I needed a tinder profile pic this would be it
IRS R200 viscous LSD from a nissan drift chassis thing should work. Just swap the LSD unit into the van center
Also the more I see fingers for scale comparison im like wholey fuck is that throttle butterfly like the size of a 20c piece
All I see is EFI supercharged briggs running off a speeduino or something
Yeah mine had cut coon springs in the rear or something similar. Iv stil got some beefy 90s supercustom superlows that are same diameter as 80s ones that are ripe for makita adjustment
Pics of teeny tiny fuel injector from one of these plz
https://www.facebook.com/events/1691549797587783/ Come along for hypothermia, mud and junk Paradise Valley Speedway 105 Paradise Valley Road 38th Annual Central North Island Swap Meet and Car Show. Old cars, vintage, veteran, commercials, hot rods, classic cars, motorbikes, model cars and trains. Parts, accessories and memorabilia.Sellers: $10 vehicle and driver per sitePublic entry: $5, accompanied children freeSite enquiries: Neville Harper p: 027 494 7249 daharpers@gmail.comCar show enquiries: Bob Mackay p: 07 332 3849 bob.mackay@clear.net.co.nz
HighLUX replied to johnnyfive's topic in Upper North Island Region
Those are bropeds not mopeds -
Hmmmm theres a $200 supercub on trademe at the moment. Wonder if its just not running because the fuel pump is fuuuu’d
A+ This will do good blackflips with the big block swap
Think of that farm bike reliability
Big single and 6 speed box. You need a tf125 drivetrain m8
Jamies 86 Hilux Sr5 bargain basment build with added boat anchor
HighLUX replied to HighLUX's topic in Projects and Build Ups
Progress? Went to pickapart last weekend to get fuel lines off an LN65 which are different to the 3Y ones because they cross the trans tunnel and come up into the engine bay on the passengers side to suit the 1GGZE plus the main feed is alot bigger so shouldn't run into fuel supply issues. Time to get the tray off so I can sort out fitting the baffled EFI fuel tank I have from a later 3RZ hilux- 58 replies
- 18
Ouch
Theres also a motorcamp 5 mins over the hill in Te Aroroa if you dont wanna sleep on the floor at the hicks bay bach -
Not quite brushed stainless pannier cases but close enough -
Looks like its clutched so must be a m62
Im hoping its a m62 like meowzer says. Will have a hoon on getting it off the merc tomorrow then hopefully it will only cost me $55 if the lady in the booth believes its a air con compressor
1G-GZE. Keen to hold on to it and keep it as an option for swapping out the sc14 at some point.
C230 sedan. Yeah I was thinking they would be more efficient than an SC14 so can make boosts with less heat/more boosts. Getting it off the Merc looks real fun
