Everything posted by cletus
- 128 replies
- 33
- 128 replies
- 31
Prescott engineering in Auckland sell doubler plates ready made, otherwise any seatbelt installer should be able to get some for you Have a look at the seatbelt anchorage standard on lvvta.org.nz
I had a bad case of dickfingers over the weekend, sunday I was going to clean and paint the engine but while cleaning I found the front cover gasket looked a bit average so front cover off to fix that, so the sump gasket got messed around with again.... I fluffed around for a while deciding on what colour to paint the engine, I got some gold as I thought it would go well with the green but it was a bit light, thought about black but a lot of the accessories are black so the engine might 'disappear ' , factory colour would be red but I thought that might be too bright I guess that's why I chose this color originally.....so it got more of the same again this evening
- 128 replies
- 28
Oil stuff dramas. The dipstick tube cracked when I fitted it 8 years ago trying to bend it to fit around something else so I got a new one . When I tried to remove the cracked one it snapped off so I had no way of grabbing it so I fucked around for an hour with various drill, modified punch, and tap methods, got it out in the end. The oil filter mount plate i ordered ages ago which was hard to find didnt fit cause it was for a later model engine , luckily WAER had one left in stock for the right year so I got that, drilled some extra holes in it and fitted it. Fitted the sump, the gaskets didnt fit right so after I'd gooed it up I had to remove it again to trim some bits off the ends, put it back on and because of the slight difference with gaskets and seals it didnt fit quite the same so one of the baffles fouled the pickup and tweaked it , so swear at it some more, remove the sump again, make some clearance, set up the pickup height again and lock it in place, clean sealer off again, and reapply, put sump back on .
- 128 replies
Yeah I am more than capable of fucking things up all by myself for much less cost On a positive note I called in to the painters to have a proper look at the hoodlining and it looks like some stitching has let go so my mrs should be able to fix it good enough for now, it wasn't mint anyway so meh. @piazzanoob cheers for the heads up, the new pan clears the dipstick ok, I did have to put a hole in the baffle cause I'd already got that wrong once before on the engine in the vg @SOHC thanks but it's already at the painter, is that an indian guy around Cartwright road somewhere? I had a customer with a torana that had been painted quite cheap and it was surprisingly good
- 128 replies
- 26
Made some baffles for the sump. Remembered to make a hole for the dipstick this time... my other one has an extra short one due to making the baffle and putting the engine in , putting oil in to start it, then realizing the mistake
- 128 replies
- 15
Picked up from autoblast this morning and dropped off for engine bay paint. Looks ok apart from they painted the black parts underneath then primed the engine bay so theres primer overspray on the inner guards and in the tunnel. Which is a bummer as that was the whole reason for taking it to them because I wanted it done nicely. I mentioned it and the guy came out with a rattlecan of black paint and some rubberised underseal to throw on before the towie arrived, which I didnt want on it I didn't want to leave it there for them to fix cause I'd already had to postpone the towie and the booking at the panel shop a week, because it wasn't ready last weekend as per the booking I made 6 weeks ago. So I'll get the painter to fix it, should just need a quick blow over with some more black after hes done the green parts And the hoodlining is ripped for some reason now. Bah. Anyway, I pulled the sump off to change the oil pump and pickup back to a stock one instead of a high volume pump. Its had a couple of times in the past where it lost pressure after a prolonged period of high rpm. I was concerned it was emptying the sump faster than it could drain back, and someone i talked to about it said that on a SB mopar, a stock pickup with a high volume pump can cause cavitation issues. Someone else said a high volume pump is unnecessary anyway as once it gets to x amount of pressure the relief valve bypasses so then the oil just gets whizzed around the pump doing nothing I'll try a stock pump and see how it goes, and also add some baffles, I got a new pan cause the old one has had a few bumps and an oil drain on the wrong side now I got brave and popped a couple of bearing caps off and they looked fine
- 128 replies
- 26
Is it a spacer? Or an adapter to fit a mazda shaft onto the hunter diff via changing the pcd? It's not something that is covered by the standard, the wording sort of suggests that you wouldn't be able to do it, as technically you are lengthening the shaft via a spacer, but the wording is intended to prevent someone cutting and joining a shaft incorrectly In my opinion if it's made out of a suitable material and is not too thick and has the right bolts with lock washers etc and it spigots into the driveshaft and pinion flange then it would be safe, it's the same as a wheel spacer or adapter You might want to check with @KKtrips
This stuff is the automotive equivalent to alison holst sausage rolls, keep making the packaging forever
Good job there Peter. It must be satisfying knowing you can big block around the place for much less cost than before. Are you going to do some spark related trickery like with the vg?
Vespa. A while ago I got a aliexpress knock off carb for it which was a little bit bigger It had some casting flash and stuff like that that wasn't very good The base wasn't flat The throttle slide was sticky I fixed all that stuff and took a punt on the jet it had in it and it went ok, moved the power up the rev range enough to notice, it went better However it had issues with what I thought was the throttle sticking and pulling lots of lean sounding revs I was trying to find where the problem was, it wasn't the throttle, it was getting airflow from somewhere though, and it managed to select first gear by itself and fuck off into my toolbox, broke the brake lever off and knocked the steering out of alignment All fixed now , spare parts bike to the rescue,and I put the original carb back on. Stupid china.
- 433 replies
Matt from tin tricks did some more work for me on the inner guards and firewall so it looks much better . Today it got dropped off at autoblast for underneath and the engine bay to get blasted, primed and underneath painted with 2k epoxy
- 128 replies
- 24
There are allowances for old cars if you cant get the anchorages in the allowable area, as generally it's still safer to have a seatbelt in the wrong area than not have one at all
Pretty tricky in a EH from memory, I think the pillar is too far forward or too small ? I'd have to have a look you might have to put it below the window
Have had varying reports of owners liking and not liking air bag helper springs. Last guy I dealt with ended up taking them out and getting uprated leafs put in instead When you have a bag taking the load and the spring not doing much the axle can get a bit "floppy" as the leafs are separated they dont control axle rotation as well Also if its COF I dunno what the rules are or what wof cof rules are like over there but usually air helper springs need LVV cert I'd probably fix the springs if it was me
Would really depend on what sort of car/subframe/ area of the body you are talking, but if it's only a single layer panel like a floor or firewall section then the body would be better to modify.
Znoelli.co.nz are the only ones that have been consistently good, they are made in nz
Correct. 30mm max for adaptors Dont buy cheap ones
Do you mean thread the chassis? Or the bit in the picture? If you mean the chassis then yes you could if it was thick enough and you use the right size bolts and lock washers etc
Should be ok , theres only one place in nz that can re web belts legally at the moment, I think there was a link a couple of pages ago
