cletus
Moderators
Everything posted by cletus
  1. That is different to the info I was thinking of, but that is more relevant as it mentions having serrations to locate the joint , when there is a single nut holding the joint in place so the certifier may be reading it wrong or as KY said, ass covering I've certed a few of that style arms from various manufacturers, if they fail it's usually for other reasons, like Car is low, has too much camber Camber arms fitted to correct camber Camber arm is longer to allow top ball joint to come out further Body does not allow space for full travel of the ball joint when its further out Ball joint hits body Have to raise suspension to remedy fouling Dont need camber arms now because camber isn't a problem any more =A circle of money spending and fucking around is complete
  2. Theres nothing recently that has changed, I cant find where it is now but there was a thing about having something to lock the arms on a mustang 2 top arm camber adjustment, maybe the certifier is applying that to everything I cant think of any of that adjustment type that has anything to lock it from moving, apart from the bolts
  3. Depends on the car. Because the load of the vehicle weight is put on a different part of the car, ie the shock mount, often it needs strengthening where the shock is mounted top and bottom Probably less work to stick to separate spring shock setup Some vehicles LVVTA requires FEA testing to prove that the hub assembly can carry the weight, this affects cars like 350z etc where the coilover attaches to the hub
  4. 616 plus driveline losses is like 700 at the engine?! Goodness me David, you are going to foul your underwear if you depress the accelerator fully!
  5. Last time I bought some , the most economical way was to get them from super cheap But yes, snug fit in the holes, and not longer in the shank than the wheel is thickness wise And steel washers. Also if you are getting close to bottoming out the nut, make sure the wheel stud doesn't taper out at the bottom. I've seen that happen and the nut got stretched bigger at the shank end, making it very difficult to get back out of the wheel...
  6. Driveshaft - russell at driveshaft specialists, andromeda cres east tamaki Hes a good sort
  7. Shit all my cars have bad safety and emissions I'll be calling zebra to come get them all and crush them so I can ride the bus I wouldn't want to sell them to some poor unsuspecting person
  8. My daughters 10th birthday is on the 14th, I hadn't really thought about it that much, when I mentioned it to her, the look on her face made me realise I wont be attending....
  9. Apart from answering the phone a million times to explain the difference between heavy and light certification, and hear all about their camper van and how long they have had it and how many cofs it's already had and how ridiculous the rules are here in nz blah blah blah No, thankfully I dont have to deal with it
  10. Steering column shortened, painted everything, got a clamp type u joint. now have steering again which I find useful
  11. I bought a set of new 14" ones about 10 years ago and I think they were $250 each or thereabouts But 13" ones were not remade as far as I know and are now super rare so I guess you could ask whatever you like? If someone wanted to do a period correct car with 13s they would be a key ingredient
  12. @NickJ I wouldn't think those ex roll bar mounts would be an issue, maybe put some bolts in the holes
  13. Depends on how much movement there is in the engine mounts but I'd aim for at least 30mm at a minimum, more if you can, to allow enough room for a heat shield and air gap and nothing being able to touch
  14. Oh man Every. Single. Time. It's like the first mod when you google "mods to do on subarus " is remove and throw away the heat shield
  15. Emission standard https://lvvta.org.nz/documents/standards/LVVTA_STD_Exhaust_Gas_Emissions.pdf There are frontal impact requirements for a new scratch built vehicle but they are very basic and easy to meet Its covered by doing things like leaving the front chassis rails unboxed forward of the suspension mounts, or putting holes in the rails , or using a smaller section material, etc etc
  16. Cut your losses, remake it so it has clearance You need enough clearance for engine movement on the mounts, and it's going to move closer to the booster with engine torque Also need enough room for an effective heat shield with an air gap between both parts
  17. Yes , definitely required.
  18. I just used that on a job Do I get a chocolate starfish for being first? *edit* some feedback, the size I'm looking at was not on the old sheet, but is covered on the new one so that's good
  19. Cool, was going to suggest them, they do a lot of older more interesting vehicles. Hamish who owns the place is a good sort
  20. Congrats on the new arrival! Where are you taking it for compliance?
  21. My interpretation would be if it bolts to existing points ie the shock mounts then no cert required, but if you have to drill holes= cert
  22. Is that the type of pump Americans get all fizzed up over for cummins engines ? https://cppdiesel.com/cpp-benched-p7100-hot-street-pump-12mm/
  23. I realise this is pretty high levels of barrying, but these things are so handy for small parts , brackets, suspension parts, etc etc, but they definitely benefit from some tricks to make them work better Share them here 1. Vacuum is a definite must have to suck the dust out and take it outside the environment. My next mod will be a 20l container to help separate the dust before it gets into the vac, as you have to stop and clean the filter regularly 2. I put a water trap on the cabinet, this stops 90% of the water getting blown onto your blasted part . This worked much better at the cabinet end of the air hose 3. The lamp they come with sucks and any lamp you put inside gets munted from the sand quickly so I just got a $20 bunnings led work lamp and put it on the outside of the window 4. Dust sticks to the window pretty quickly so you have to stop and clean it all the time. I started to use meguiars quick detailer spray wax stuff and that stops the shit sticking to the window, I hardly have to clean it any more 5. You need a decent compressor, I got a twin cyl belt drive one that is 190lpm and it keeps up fine
  24. Land transport rule doesn't mention a minimum height for the rear of a mudguard for single wheels, only width
