Everything posted by Roman
Haha! Yeah it is awesome, thanks for the suggestion. My laptop cant charge from the car so no worries there.
Ahhh so I bought a cheap GM style wideband knock sensor. However it needs a PITA plug (not included, damn you) that you can only find on a late model LS2 or something, bugger. Just going to epoxy some crimped ends in and run a remote plug end on it. However I bodge wired it up to a Mic jack into the laptop, then as suggested used Audacity to crank it up a bit and output to Headphones. Works brilliantly! It's even better than just using knock sensor > amplifier > headphones, because this way I can record the whole lot as a WAV file and compare notes with the datalogging timestamps once I've filtered the results for the knock frequency. Tapping the knock sensor with a fork outputs a really clear sounding sound of... Well, a fork. So it shouldnt be too much interpretation required to figure out when it's knocking.
Awww damn could be keen for a pre nats shakedown at Meremere as well! Details, giz ze details!
The main thing to consider, is can you get away with widening your front track. If yes, then convert to discs running over the front face of the hub, like the bluebird ones. This will make your life sooo much easier as it adds the thickness of the top hat to the amount of room you have to fit everything. And there's a wider variety of potential matches for a disc that suits, like the bluebird ones. I've got some spare facelift SW20 calipers here if you want to test fit them. Although these are the bigger brakes compared to non facelift, it might suit you better getting the earlier / smaller / more common calipers.
You can get some nice small Wilwoods though. I'm running smallest of the Nissan 4 pots and it really limits my wheel choice because of spoke clearance. Bit of a pain.
Slightly different car, but I've had a few different brake setups in the front of my car. -Factory AA63 Celica struts/discs/calipers (Vented disc + single pot) -Same struts with SW20 twin pots and a thicker disc -Same struts with Nissan 4 pots and same disc After all that, my opinion... Look at the price and availability of consumables, and how easy it will be to maintain your car as the primary factors. Going to a wilwood 4 pot or Nissan 4 pot gives you HEAPS of brakepad options, they're about half the weight of cast steel twin pots, and are a zillion times quicker and easier to change brake pads on. It also gave a much more progressive braking feel, the single pot or twin pots gave a comparitively on/off sort of feel. On paper going to something like AE86 struts or Cressida struts with factory vented discs etc seems like an easy option but it can be difficult to get consumables for. It's a struggle to get GX61 front discs anymore I think. SW20 calipers are a bit better for consumables, can get some decent pad options. But dont expect people to have things readily in stock at the drop of a hat, if you need some new pads at the 11th hour... Like you can with most of the popular 4 pot options. Depending on your wheel choice, a Wilwood or similar 4 pot is probably the best option for a variety of reasons. But expensive too. Basically you need to decide, in this order: -Which strut you are going to run (Starlet size, AE86 size, Cressida size. All have pros and cons) -Which caliper you are going to run (Pick this first, make a bracket for it and then find a disc that fits available space) -Either way, you'll need to make a caliper bracket to fit anything decent... So if it's 90% the same amount of work to fit any of the options then you might as well start with something good I reckon, that will pay dividends in the long run with pad availability / choices / etc. Pretty hard to go past Wilwood or the likes.
Thanks Glenn! Good to know, my basemap looks to be 2-3 degrees advance behind all of that. Once I've got my knock monitoring stuff I'll set it to those figures and see how it goes.
Okay cool thanks, I'm guessing that minimal ignition timing at WOT happens at 6000rpm or there abouts (looks to be peak torque) and then tapers off a bit either side of that? One thing I dont get is that ignition timing doesnt seem to advance relative to rpm by very much. For example 6000rpm doesnt have twice as much advance as 3000rpm, so it's only got half of the time to ignite etc.
Got any pics of what the decepticon front end looks like on a finished car? Not overly sold at this point / holy scope creep batman / get 'er done
Oooohhh aahhhh EDIT: Ahh shitballs I just remembered I'm going to Coro for the weekend. 1st world problems
Ahhh okay thanks Glenn. Yeah I've got 8 injector drivers. What do you mean by ignition test advance? You mean ignition advance at full throttle? Mine is currently 22 degrees across the board from 3500rpm up, because I dont have a good way to monitor knock yet (some stuff is on the way)
I dont actually know to be honest. I did a bit of reading up previously which suggested that a single pintle design generally has a very narrow spray pattern compared to other designs (which is crappy for when you've got them right by the head, but good for things like this) However yeah, perhaps I need to bench test them and actually have a look. Might be that the spray pattern is way wider than expected. Come to the Nats trackday KPR!!
So I got all that finished, wired it all up and took it for a spin. After an extended amount of fluffing around it just doesnt quite seem to run right. When I reverted to the previous fuel map using just the main injectors, it ran a hell of a lot better instantly. It's possible that it's flowing unevenly between cylinders, or that I need to spend more time tweaking the injector ratios / timing to get it working as best as it can. Or I just need to figure out a tune using 100% outboard ones for starters and then work on blending them together. But I dont think I can really get this right without a dyno, and having a way to check individual cylinders for running rich/lean. Not too keen to blow up a cylinder just before Nats / trackday so I'm going to go back to the standard setup for the moment. A bit dissapointing, but I'll give it another try in another month or two when I've sorted out a few other niggles. Also, since I no longer need the MAF, and the MAP sensor was showing a 2KPA pressure drop from 6000rpm onwards, indicating a restriction. I experimented with fitting a velocity stack straight on the plenum, with and without a pod filter on top of it. Doing this reduced the pressure drop to 1KPA, which initially seemed like a good thing. But I had to pull fuel out right across the board, because even though there's less of a pressure drop it's consuming hot air which is less dense, and less air in total. Haha lame! Just goes to show how much of a difference cold air actually seems to make, even when you've removed the entirety of pre throttle body restriction.
Got my 2nd lot of injectors fitted and all sorted with no leaks - hoorah! A fuel line from a 20v 4age was the right length for between the rails. I've set it so the second injectors only activate at 4500rpm onwards, and for starters set it to 90% using outside set of injectors. Took it for a quick run and bodged some numbers around so it was 13:1 AFR across the board... But then my fuel map looks whack! I think the peaks and troughs are because there are resonances pushing some of the fuel back out of the runners at those rpms. So I had a look at the injector timing. It was setup so that the end of the injection event is 400 degrees before TDC combustion, for everything. The first problem with having this set statically is that the intake cam advances or retards 45 degrees, so depending on the VVTI it would make sense that this number should be up to another 45 degrees advanced to match the closing of intake valve. This doesnt matter too much with low cc injectors close to the head, because they're spraying most of the time on closed valves anyway. But for this it needs to match the injector spraying with the induction event. so I setup an rpm vs map injection timing table, and added more advance for when the cam advances. This looks to have smoothed out the peaks and troughs with the fuelling back to normal, so that was probably the issue. Jury's out though on whether these extra injectors will actually help make any more power. There's no point in tuning it any further until my IAT sensor arrives though, it falls off tune each time I drive it currently. They're a 1000cc single pintle and make a racket when they are running so it sounds pretty cool. Hah.
When I had the OBD 2 meter there were two types of reading. Instant values - Your fuel economy at that instant, so it changes all over the show. And averaged over a minute, or accumulating over your trip. So one thing to consider is that if you're using the same amount of fuel but going faster, you get better liters per km. So for instantaneous feedback it would be injector pulsewidth / vehicle speed So something like (injector pulsewidth average over trip) / vehicle speed would show you the fuel economy over the span of the trip. Would give you a number that you could bodge into Litres per km or whatever.
Yeah you just need three pins connected to obd reader. 12V earth and the SIL pin. Engines of that era may not be completely obd2 spec though so sometimes needs a custom start up command to work.
- 3 replies
- 1UZ-FE
- LEXUS LS400
(and 2 more)
Tagged with:
Aahh so I found that if I changed the fuel modelling from 'traditional' (which doesnt care about injector size etc) to 'modelled' then it works out fuel based on engine size, injector size, fuel pressure, blah blah. Which is what I need to do in order to access the Litres per Hour figures and other similar measures of fuel consumption. (Even though Effective pulse width is same same I guess) However it's a kick in the balls because all of the fuel values on my existing map need to drop down by like 95% for it to work. So I think I'll put that one on hold until I get my proper IAT in and configured, and map sensor calibrated properly. I'm thinking that once I've got gear detection setup, I can just filter the log files to only show values for 6th gear, TPS at say 10-20% and then have an Engine RPM vs Litres per Hour graph to compare between runs. Irony noted of using lots of gas to make car use less gas.
Yeah fuel pressure will be constant, my FPR doesnt reference manifold pressure. Yes initially I was thinking that logging injector pulse width makes sense. But then for some reason that now slips my mind it seemed like it wouldnt be accurate based on info that I had. However, I've just noticed if I change my fuel calculations from "traditional" to "modelled" it allows you to enter engine size, injector size, fuel pressure etc... Once you've filled in these things it gives you some better information about fuel consumption, estimated air/fuel consumed, etc etc. Hoorah! Either way, as per the Honda article it looks like advancing the cam 15-20 degrees and advancing timing to 35-40 degrees and 15:1 or there abouts will be the best starting point. There's not much point trying to tune any further at the moment though until my new IAT sensor turns up and I get my MAP sensor calibrated properly. Because I tune it up nice one night, then the next day its all over the show again. Needs some more accurate info to get the compensation tables working correctly I think.
Hey guys I'm trying to think of the best way to tune for cruising / fuel economy. I was thinking same stretch of flat straight road, do a run aiming for a constant 80kph on GPS. Datalog all the things. Adjust a variable (ignition timing, VVTI, or fuel) But then what would be the best measure of economy? A lower average throttle angle perhaps? More bang out of less air. The factory ECU seemed to want to run right to the limit of detonation, so perhaps slamming in timing right up to that point is best for this motor. Some people say running leaner is a better idea, but then others say you end up needing more throttle angle to keep the same speed if you do so. EDIT: Aahh! This article is pretty awesome on the topic. http://www.superstreetonline.com/how-to/engine/0510ht-fuel-economy-tuning/
Got the new alternator fitted, so far so good. I got called out in the fab disasters thread for some terrible wiring for the fan relay. So now have the ECU triggering a different relay and the ugly one gone. Woot! The speedo signal now works but need to setup gear detection so I can have a gear dependent rpm for the shift light. Bought some more bits to setup datalogging with: 3 fast response IAT sensors (One for intake, one for engine bay temp, third for... dunno yet) A 3 axis accellerometer that outputs x y Z axes as 0-5v each (Measure cornering speed / accelleration for tuning) A wideband knock sensor and an amplifier for tuning ignition safely with headphones. Some bits for a revised intake. Currently the intake pipe from the air filter is 2.75" but the throttle body entrance is 3". So I'm going to upsize this and see if that removes the pressure drop at 6k rpm onwards. Also with some awesome help from Dave Sentra we've started on a spare manifold for some outboard midboard injectors Still needs a bit of work and some $$$ for hoses and things, so probably wont be done before Nats trackday. But should be fun to see if it helps make any more power phasing them in at high rpm. (Helps mix the air and fuel better, apparently!) The main concern though is that it might hit the bonnet when the engine moves. So plenty of things to keep me entertained for the next while when all of this stuff turns up. The car's running really well with the new ECU, but I still need to calibrate the MAP sensor and temp sensors properly so that temperature compensation etc works properly. Everything's open loop at the moment but once I've got the map looking good I'll set it to closed loop below 4000rpm at low/mid load so it can adjust fuel as need be for good cruising economy.
Yeah to be honest I might end up going MAP anyway in the long run because I want to take some restriction out of the intake. As currently between the air filter and the throttle body it's 1/4 inch smaller pipe than the throttle body inlet pipe size. (2.75" vs 3") And the MAP sensor shows a pressure drop above 6k rpm, probably because of this. But it's been interesting seeing the difference with this, and getting a better understanding of both. The main things that suck about MAF are that an air leak ANYWHERE ruins your day, and if you change one single thing in your intake it throws its toys out of the cot. But if a 3" or 3.25" pipe with MAF bodged in works well enough after being calibrated I might stick with that because my brain can make sense of the tables a little easier. Turns out my tables can have 20 rows of resolution so it's not really an issue running out either way. Good fun though! Cant wait for next trackday.
Hmmmm so I setup the MAF with a calibration table and tuned fuel only on it today. So first thing I notice... Rather than random peaks and troughs in my fuel map, it's much smoother. Although there are pressure spikes or troughs because of resonance or whatever, the airflow is reasonably constant by comparison. On my MAP map I had to increase resolution around the 45000rpm mark to tune around a big dip. Also it ran like a sack of crap at first, and I was thinking about throwing the towel in and going back to MAP. But with some persistence it's running really nice. Still I was still using the MAP sensor for ignition I datalogged it all and then manually translated that into a MAF ignition table. Either way the car is driving really awesome now, feels and cruises along like a factory car which is awesome. Another problem I had with the MAP sensor is that it was reading 100kpa while cranking because it doesnt generate vaccum yet, so it was dumping in heaps of fuel and I had to turn off all of the enrichments etc to get it to start. Where as the MAF just shows 3.5g/s which is accurate right from the start. I just need to finish an audio output / knock sensor setup then I'll start having a play with the ignition timing while cruising and lean it out a bit.
Hmmmm so I've got MAP and MAF sensors wired into my car, I still think MAF looks to be more accurate / easier to interpret changes. As per VVTI changes. I like to know that at WOT I'm getting XYZ grams/sec of air rather than just 100kpa across the board or whatever. At the moment though I've just got the MAF logging as a 0-5 volts because I havent calibrated it, I need to know grams/second vs voltage. I've got two sets of data I can mash together to make it work I guess, going off some of the datalogging from factory ECU previously. But just thinking about how the two compare to tune with. With MAF, at low rpms you never hit the peak airflow readings, at WOT through the rev range you work diagonally through the map: But so that means the whole bottom row goes to waste except for 1 cell value, because you only reach 180 grams/sec at peak power rpm. Then as your revs go down you lose resolution in your table because at peak power you've got say 10 rows to work with, but at 2000rpm you've only got 3 or 4 rows that you ever reach. Soooooo does the extra accuracy of the sensor offset the lack of table resolution? It probably still does, since most factory cars use MAF these days. I guess it comes down to how well your ECU can interpolate between rows and how sensitive it is to voltage changes. Onnnn the other hand. With MAP, your WOT is pretty much just working with the 100kpa row and you've got full resolution at each rpm down to peak vaccum. So you end up using the full table as WOT is the bottom row: But the sensor itself seems less senstive to change / less accurate. So the toss up is to whether I would prefer to have high senstivity in the sensor but low resolution to tune with. Or vice versa. Since it doesnt cost me anything but time, I think I'll calibrate the MAF sensor and then put a full tune on both. I suspect that the MAF tune will 'hold' better with changing conditions compared to the MAP sensor which I guess is a lot more reliant on the IAT sensor being super accurate and other constants being... constant. For example if you've got a ram air type thing going on, if you're going faster and there's more air stuffed in then the MAF reads it fine. But MAP doesnt necessarily know how to account for the VE change unless you have barometric compensation setup, from the area where your inlet is. I think I'm going to get one of the stick style MAF sensors, and bung it in a 3" or bigger pipe and roll with that / datalog both / maps for both / decide later / more scope for rambling / coupe life EDIT: Just thinking about it, I could setup a second fuel/ignition map that it switches to below say 25% or 50% throttle. Then use this as a high resolution map for the low airflow area of the MAF sensor at lower rpm. Get dat good economy, hnnnnggg
Yeah some factory manifolds look pretty dreadful! But still do the job well enough.
