Everything posted by Unclejake
I measured my rims once and they were something like 4mm out so I dunno that you've found it sorry Phlex. I can't remember if you have borrowed a gearbox of not yet. That's a fairly simple and cheap thing to try if someone's got a good one. Once upon a time I'd have lent you three at a time!
Thanks all.
I'm keen to play music from my smart phone through my car stereo. There's a few options available, but I really want a reliable unit that will interface with my factory dash and steering wheel controls. In my case it's a 2007 Lexus GS430, but if you know of a brand of Bluetooth adapter that's very reliable it'd be great to hear about it. My car has the 330 watt ten speaker Mark Levinson stereo (a $4.5k option when new) so it'd be good to keep as much sound quality as possible over bluetooth I do not want to use the aftermarket handsfree calling if I can avoid it. The Lexus does that thing perfectly adequately. I'm just after a music source (whilst preserving the factory handsfree function). There's no auxiliary input for the Lexus stereo BTW I'm tending towards the Vais brand SL3b-L bluetooth adapter, but there's heaps of others like Grom, iSimple, GTA and Crux Any recommendations? http://www.vaistech.com/product/sl3b-l/ http://gromaudio.com/store/bt3_adapters/toyota_lexus_scion_98-11_aux-in_mp3_bluetooth_ipod_iphone_adapter.html https://www.sonicelectronix.com/cat_i1903_lexus-bluetooth.html
If you want to borrow a dial gauge on a stand (to measure how out of round things are) then holla at me. I've had quite a bit of Cortina experience, but sadly have very little time to offer hands on help this month.
PHLEX, you've given a great description of the symptoms and what you've tried. That always makes it easier to diagnose. Nice work. These are simple light cars that drive well. I have had my old 1500cc Mk1 Cortina at ~ 200kmph on several occasions with no vibrations. You've largely eliminated the rotating mass of the fan through to the clutch pressure plate as the cause... but if you didn't put the correct I/D pilot bearing in for the gearbox input shaft (there is more than one diameter and and at least two input shaft nose lengths) then 'perhaps' that could be the fault??? Normally that would be a problem at revs rather than speed though Otherwise; it sounds like your driveline isn't in straight. Perhaps run a tape measure between the front and rear wheels on both sides of the car, and then check that the gearbox and engine are located in the centreline of the chassis rails. Worn gearbox bearings (including the white metal bearing the driveshaft locates in) can cause your symptoms, as can a dodgy diff-head (which I believe you've replaced) or an out of balance (or out of phase) driveshaft. It couldn't hurt to rotate the driveshaft one bolt hole to see what happens (although most likely nothing will) One other thing that can catch folks out is wheels with a larger center bore than the hub location flange. That one is hard to detect Good luck!
Anything happening in Welly next weekend? (27-28)
Unclejake replied to Raizer's topic in Lower North Island Region
Good stuff. I'm not free that weekend, but may have had a cheapish accommodation option for you, but it turns out that it's not available anyway. Sorry -
There's you, the wife and just one child needing Wellington accommodation? -
As idle is off perhaps check all the heater controls are working, and if not check for a vacuum leak There's various hoses that can fail, including one between the back of the head and the firewall.
I don't recall using a ballast resistor with an electronic distributor (and it doesn't make sense to use one to me) but if it ran wired up like that before then you wouldn't want to change it. Electronic distributors (with a spinning soft iron star shaped thing inside them (a reluctor?)) will only spark if you have the polarity around the right way. IIRC the Subaru ones we used on Cortina motors spun anticlockwise like the Honda units, and the black wire didn't go to earth. The black wire from the dizzy went to somewhere else .... I think the + ve post on the coil, but it was 2007 when I last touched one so I can't remember sorry The only other thing I can think of is that you have the distributor out of phase (so when the spark triggers the rotor is between two distributor cap posts)
The Surgery did thousands of dollars of sill work (all documented with nice colour photos of the rust and finished painted area attached to the invoices) on the Mercedes I bought, but strangely no photos during the repair process. When I pulled it apart one of the sills was riveted together (using several strips of roughly cut metal about as wide as my thumb) under bog. Utter. Crooks.
I may have just messed up these calculations, but right now in theory you have an available 1,385 mm2 of air pass through area in your single twin throat carb, but you are heading to 3,216 mm2 (assuming you're going to 4x32mm carbs).
Unclejake replied to KKtrips's topic in Lower North Island Region
For the avoidance of doubt: Had your wonderful Area Rep taken up my offer of an evening on my luscious and well appointed deck at home... I can guarantee that you would all be utterly fucking miserable as it's 432 shades of grot here on the south coast tonight.... so respect to the volunteers that make the hard calls. Sometimes they get it wrong, most times they get it right, and all times they do it with the absolute best of intentions. Kisses -
If in doubt with carbs ALWAYS go smaller. Unless you spend 99% of your time at 100% throttle and at near to top speed - air speed is your friend. Small = Better.
I LOLed -
LOL. If'n I was up on my new hill I'd be able to spy on youse all But SRSly, should you wish to alter arrangements I'm happy for you all to use my existing deck, BBQs (one even operates on burning solid fuels) and outdoor kitchen. There's plenty of parking, outdoor lighting, toilets (if I leave you a key) and an outdoor table that seats 20. I'm likely to show up myself at some point, but don't let that put you off. A couple of spare rooms exist too should those already known to me make prior arrangements to get inebriated EDIT: But no matter the weather it wont be sunny at that time of day on my deck - which can be frustrating if it's epic sun across the road on the beach.... but of course one can walk across the road to the beach in that case -
Ha. Thanks for that but the issue was not timber runners. It was the prospect of chiselling out another cubic metre of rock to form the main entrance way. I decided on an indirect nature walk instead. It'll be delightful. I have a couple of other sets of stairs to build once the pavers are down, but they will use native runners and treads as I have some demo timber to use up
I decided against the stairs, mainly because CBF. Next there's some paving to do, and after that I better actually build the cabin I guess.
- 199 replies
- 22
Keeen -
^ don't forget that absolutely everything (except for water, but including electricity) needs to travel on my back for 4 minutes of steep, muddy and slippery climb. Concrete is one of the least pleasant things to carry (even in nice dry bags), but I get what you mean. I'll chisel at the rock a bit later. I've got enough to do to keep me busy until December without starting on the stairs
It's fractured grey wacke so probably hard enough to be a PITA but too crumbly to be of any use
It's been a month where I felt like I tried really hard, but got almost nothing done. Things got done for certain, but they're hard to see. What you probably can see now is the rocky face that I'm going to chisel into stairs. I have no idea how that particular endeavour is going to work out.... but I'd wager badly. Very badly. Oh well. At least it'll be really hard and a waste of time.
A weekend kneeling and screwing isn't as much fun as one may think, but it's still August and the underground deck is pretty much finished! I'm happy.
- 199 replies
- 15
The deck was an afterthought TBH, and had I put it on the other side of the cabin I'd need to cut down a bunch of trees... which would have mean't that the cabin was visible from the road below... which I'm not keen on. I want it to stay hidden. The 'underground' deck is very sheltered from the wind!
It's taken a while... but the deck frame is almost finished. One more weekend and it'll be ready to accept the decking timber, which will give me enough room to start on the cabin wall frames It's all good fun but bloody hard work! I have 2.8 tons of pavers that need to be carried up to the cabin if anyone is bored...
