Everything posted by Unclejake
Plus 1 for Frost Motorsport
Who is good with French automatic repairs in Wellington?
Unclejake replied to Unclejake's topic in Lower North Island Region
Thanks team. It's a PITA fo sho -
Peugeot ZF 4 speed auto gearbox 4HP20 making a terrible noise and not providing any drive as soon as there's any warmth in the box. It's from a 2004 Peugeot 607 2.2A (petrol) with around 120,000kms I think. Service history unknown. Fluid colour unknown. Is there a trusted Peugeot skilled transmission specialist in Wellington? Ta, P.S. It's not my car but I'm motivated to help if I can
WTB: Underbody Steamcleaning Wellington
Thanks TGB. They are doing the job this afternoon -
I can't find anyone who can steam clean a ute chassis and engine bay. The ute is complete so a hoist would be best. Can anyone suggest a company or individual who can help? I had to sell my steam cleaner when we moved workshops. Thanks team
I finally found some time to make some bench seats and get it all home. We had 20 people sitting at it for lunch on Saturday. It was awesome
- 26 replies
- 34
I can do it one afternoon this weekend (depending on how thick it is) if you can wait that long. My shed is near Owhiro Bay My gear will only cut 91mm deep on a single pass and needs one straight edge to use as a ripping guide. Alternatively, I have access to a rail saw that'll do laser straight cuts on timber with a wonky edge, but that will only cut 48mm deep, and I'll need to borrow it from its owner. Both options require the timber to be nail and screw free (I only just got the table saw back from having it rebuilt after hitting nails)
you will be able to get parts from burton power in the uk they sell all sort of stuff like that you can also probably be a gasket and bearing kit from your local gearbox rebuilders ive done that in the past with the four speed boxes but rebuilding them is a bit tricky so i wont do it again good luck mate
Agreed, especially given that it's going into a pre-airflow two door
Yeah/nah/I dunno. I almost gave him a ring last week but work/failed land deals have left me with almost zero free time. I shall call him soon. He only has two doors though. I need to get him two more
Unclejake replied to KKtrips's topic in Lower North Island Region
Lame UJ. I should have read this earlier. It's hardly a great distance to travel for me. Lame UJ. The dork. -
20% negative camber? I don't understand
Unclejake replied to sr2's topic in Project Discussion
'Coughs' -
If your coil -ve is wired to earth then what you are seeing at the spark plug makes sense. Good luck I'm not sure what would have caused the coil to die despite you cranking the motor over with no rotor. The points should have been opening and closing regardless. A coil will die if you leave the ignition on for an extended period of time with the points closed, so if there's anything else that happened prior to you trying to start the engine with no rotor let us know so we can help your diagnostics. It seems odd.
This is correct, but if modifying the wiring back to have the coil -ve post hooked up to the dizzy doesn't solve your problem then check your method of testing the coil before spending any more money. They have a lot of resistance in them by design I wouldn't be keen on changing to an electronic distributor while you still have an unknown fault Also: Are you saying it has no spark as the engine won't run, or have you had the plugs out (and earthed) when you are cranking the motor?
If you want a roll cage in Wellington...
He's totally capable of that. Totally. https://www.facebook.com/FrostMotorsport?fref=ts -
I have a friend who has a race car fabrication business, but he's hoping to be a bit busier than he is. His work is top notch, but I have no idea about pricing If you need stuff made, especially roll cages - give Steve a holla on 021 680 899 Mods, please move or delete this as you see fit. I'm not sure it complies with the rules or not so I'll leave you to judge
I did think about that, but to look right the gaps would have needed to be on each side of every redwood fillet. The fillets are only 25mm wide, so they are glued and screwed to the edge of each elm board (rather than glued and screwed down from beneath - as the elm is) Making the 25mm wide fillets 'stand alone' seemed unlikely to end well after a year or two outside (they're taller than they are wide).
I think the smartest thing to do is to leave a 2 or 3mm gap between each of the top boards to allow water to fall through and not get trapped. That had been my plan until I chose to fillet between the elm boards with redwood strips. I couldn't work out a way to have drainage gaps and still make it look good, so the new plan is to oil the top heavily with an oil based timber preservative, and repeat that every six months or so. The trick is finding an oil that has good UV properties as the oil I've been using for the last couple of years has been breaking down, turning black and is able to be scraped off with a fingernail after less than a year. I'm a bit lucky as the air at home is heavily laden with salt - which is a timber preservative. Once this table settles a bit I expect to find water pooling on it somewhere, so I'll drill some discreet holes in that location to help it drain. I haven't oiled the side edges of the boards as I've glued them on the bottom and both sides. An oil based polyurethane is the best barrier to water ingress, but it's a PITA to sand off when it starts to fail - which is why I'm going to use oil for the top
Thank you for the encouragement everyone. Here's tonight's glueing and screwing efforts. There's lots of sanding still to come as I've made a few mistakes, but it's still better than watching TV
- 26 replies
The whole thing is glued and screwed, and the frame is all rebated. I trust mechanical fastenings more than chemicals, and dove tails wouldn't have been useful. Yup, but not until after 8pm./ I'll be screwing in screws, but if that's a PITA for you I can do it another time? Thanks for the kind words everyone. It's been a therapeutic project
All of the fasteners (except for the timber dowels) are 316 SS, and all are hidden. The big rafter screws I've used are expensive! (~$1 each) The elm came from a windfallen tree on a farm near Masteron. It's quite nice.
I took the longest bits of elm and made them a pretty shape. Now that this 'picture framing' is done I just have to finish cutting up the rest of the elm to make a top. Perhaps in May Most of the rest of it looks shit, but if you squint a bit this corner looks OK
- 26 replies
- 18
A table needs leg, which is what the LVL was for, but I was dumb and ordered LVL so big I couldn't cut it with any of my saws properly so I chopped it up into bits and took it to a mate who has access to a big mother planer. I gave him a drawing which my dear friend Mathers helped me with, and here's a leg. I like it. After the legs was done it was time to cut up some rails and dummy assemble the table base. Ummm, yeah. It's pretty big. Ooops
