Everything posted by Flauski
PALMY SWAPMEAT 2025: 1-3 AUGUST (20 Year Anniversary!!!)
Flauski replied to Bistro's topic in Upcoming OS Events
Potentially could do mine however my driveway to shed is a F**king mess in winter. I doubt you will want to drive on my drive, your car will get very muddy. -
Flauski replied to yoeddynz's topic in Other Projects
Hey @yoeddynz question, when you swapped from a Mitsi distributor to a Hitachi, did you have to change any of the wiring? I have tried the same swap and it won't start on a Hitachi. Any idea what part numbers the distributors you used are? Looks like the one you used epoxy on might be a 22100-72B00? I have only established my original one is a Mitsi clone (no part numbers) and the Hitachi is 22100-AN200 and it has a massively different trigger wheel. Cheers -
The old MVR (Motor Vehicle Register) is absolutely riddled with errors from clueless people doing data entry with no knowledge of cars in the 60s-90s. I looked into a snapshot of Datsun 1600 (510) records for a particular year and found no fewer than about 20% errors in chassis numbers, name of the vehicle and engine numbers. Like Bart, I have had 3 vehicles with wrong details. The records are incredibly poor and I have even seen a bunch of 70-90s cars registered with 'sports car' in the name.....which is never the name of any model of car. I have been down this path before with an incorrectly registered Suzuki GT250. It was re-registered and when that was done, it was registered as a 1991 instead of a 1981. I tried to change it due to it being close to eligible for the 40 year rego cost difference (close to 1k rego vs 60 per year.) Basically I had to prove and apply (using the alternative documents path that Goat talks about.) I got a letter from Suzuki saying they never made that bike in 1991 and the frame number was from 1981. So through the 'alternative documents' process I paid $200+ to only 'apply' to Land Transport. This does not mean it is a given and there was no guarantee that they would agree. In the end they did but remember it was their data entry fuck up in the first place...... There are a ton of people working for Land Transport that have no knowledge of classic cars and no care either. You really do have to hope you get someone decent sometimes. If I was you, I would get an aficionado Pantera foamer (from a club in the USA most likely) explaining the chassis number as you have above, the car's chassis number is correct, original and unmodified which demonstrates the registration record is wrong. A photo of it back in the day would work wonders too, or trying to find a previous owner as mentioned. Good luck, totally worth it, looks awesome!
HumberSS's Datsun 240c coupe of irrationality
Flauski replied to HumberSS's topic in Projects and Build Ups
Just the L26 engine. If I didn't already have 3 project cars I would consider the whole shebang.... -
If @sheepers doesn't want the engine @HumberSS , I'd be into it. -
HumberSS's Datsun 240c coupe of irrationality yarns
Flauski replied to HumberSS's topic in Project Discussion
Yeah buyee is easier, usually a chassis number works well in searches because they crossover in English and Japanese. -
Isn't the white/blue ignition? Are you saying tap off that for the relay power as well? Yellow wire gives the 12V only while engine is running right? white/blue is ignition and will power relay but also provide the source to auto choke when ignition is on? I will check the voltage at the yellow wire.
I can only imagine how hard finding the coupe specific bits will be so its great to be mostly complete. Yahoo search tailored for such a look; Nissan 230 - https://auctions.yahoo.co.jp/search/search?p=230&auccat=26322&va=230&istatus=2&exflg=1&b=1&n=50&mode=1&brand_id=115840 230 Cedric - https://auctions.yahoo.co.jp/search/search?p=230+セドリック&auccat=26322&va=230+セドリック&is_postage_mode=1&dest_pref_code=13&exflg=1&b=301&n=50&mode=1 230 Gloria - https://auctions.yahoo.co.jp/search/search?va=230+グロリア&is_postage_mode=1&dest_pref_code=13&exflg=1&b=1&n=50&mode=1&auccat=26322&tab_ex=commerce&ei=utf-8&aq=-1&oq=&sc_i=&exflg=1&p=230+グロリア&x=0&y=0 Great start, look forward to following this. Also kicked the tyres on Marketplace. -
Oooof, always wanted one of them. You've got all the cool toys.
Yes, the screenshot above of a factory manual is indeed the factory manual I drew colours on to highlight. Yes, the auto choke relay is not even shown but can confirm it directly feeds off the yellow wire going into regulator. The voltage raises to an acceptable level (about 14.5v) when car is started so alt must be working. Still can't work out why dash light it on, every thing I have read suggests if light is on, alt is not working and won't be charging.
Did that today ^ Light stays on but no solid click of relays engaging when connecting battery with key off. Some things are not getting powered, I know the auto choke relay is one for sure. Had to google the factory part number to work out what it was and as you can see, it does not exist on the wiring diagram?!
Have now tried swapping to same as you @kicker, connecting 5 - WB to 3 - WR and diode facing the same way - it has made no difference. Still charging, charge lamp stays on, loud click from relays heard when car is off and battery connected. The alternator is a Mitsubishi AQ2250? 50 or 60A IC. Can see from the pic I just took that it is wired correctly to S and L.
Yep that's what I've done, per the first pic of two plugs inc a diode. The issue is around the extra relays etc in the same circuit. For late model Z it is a seat belt warning / fuel pump, for me it appears to be ignition accessories and auto choke. I know changing the wires linked by diode may solve the lamp issue but potentially not the rest (triggering relays when car off causing draw on battery.)
Have a 1977 Nissan Laurel KHC230 and the wiring has me a bit stumped. I know there are some OS experts in this field. I don't want my car to catch on fire / melt wires but I don't want to have to disconnect the battery every time it is off too! Must be some of the last cars to have external regulators. I have replaced my alternator with an IR one. I have tried following Nissan / Datsun instructions online which are a little conflicting but the wiring colours seem to match. It all seems to depend on whether other relays are in the same circuit. 1. Alternator S (signal) (Y) 2. 12v from fusable link (W) 3. 12v acc? (WR) 4. Ground (not needed) (B) 5. Alternator L (lamp) (WB) 6. +12v but shares same colour wire to a lot of other relays etc? (WL) This is what I used; After following those above instructions I can confirm - Alternator appears to be working / charging, however there are some issues - 1. warning lamp for charging stays on 2. There is draw on the battery when the car is off, relay(s) can be heard click on when positive connected. It appears that the ignition accessory relay / intermittent wiper box are powered up. Will I fix it by following these instructions instead? This shows 5 white with black stripe + 3 white with red stripe connected instead of 5 + 6 connected. Out of shot of the wiring diagram for my car it would appear that the white/red (WR) ends at the actual charge lamp on the dash? Wiring diagram for my car; Any ideas? Is changing the wiring as indicated going to stop power being fed to other devices when car is off? Or am I going to have to do something more drastic with regard to sourcing power from somewhere else?
Thanks. I have since found someone bringing in 225/40/14s but only in real limited numbers.
How good! So stoked for you it's getting closer to being fully complete. Cheers for the hoons. Wish I could afford the bags, ride comfort was unreal and unexpected (never been in a car with modern bags and its awesome.) All the: Comfort of standard height with no body roll Ride height of cut springs without the spine jarring over bumps. Shout out to Ace Auto Wreckers for hooking us up that alternator. Legends.
No luck chief?
Should have read this thread too. It's relevant to my 14x8 tyre options post. Could be keen on a full set of said tyres....though are they suitable for an 8" rim? I see some old talk on this forum inc a link to a letter from Falken saying the Z912 pattern is OK for 8“ (but 195/45 is not on LVVTA list.) Only other option I have heard of is the Toyo 225/40s but allegedly not sold here any longer, could possibly get (indent for months.)
Long time, thought I would dredge this up. I need some wider than 185/55/14s on my Star shark 14 x 8s. Tyres look too small on a big car, plus not certable. Is there anything still available? Cheers!
You wanna hear it though right?
Voila Had to buzz down an edge on the kick start after kicking it once and it ever so slightly dinged the exhaust. Then I proceeded to take a ton of photos. Don't have any of the other side of the bike because it's all about the exhaust baby! I managed to track down some replica OEM Suzuki stickers for oil tank and side cover and applied. That about finished it off. Don't have anything more to do to it. Took it to DGR Wellington in May and it ran like a boss.
Wowzee thats some custom mods! I considered doing the same. I tried clocking the lever around as far as possible first. It worked but meant kick starting was a challenge, had to stand at the front of the bike holding the handle bars and just push my leg forward. It worked but was way too awkward
