My old mans got a bare freshly honed block and some decent pistons to fit and crank to match, he would sell it as he has no real use.
He also has some other shit like high pressure and flow oil pump.
Oil hex drives
Prob a head or two, nothing special
If you want the most out of the wild cam then you need to do some port work + induction. Expect to pay at least $1000 on the head for crack testing, skim, new valves + cut, stainless inserts, some porting/clean up, new cam bearings, new oil spray bar (you really want this), & new head studs.
Rough pricing:
$1000 on twin carbs + a tune ontop of that.
$300-1500 on extractors and exhaust
$300ish for Leads, plugs, dizzy rebuild, new coil
$100 for new waterpump
$200 gaskits
$200 seals
$250 new clutch
$100 belts
$200 adjustable cam gear
$??? Labour ontop of this
If you do all this you really want some stuff balenced and a lightened and a dowled flywheel
$500-1000
So if you start looking at it this way then you might start considering an engine swap instead, all depends what you want and how far you want to go. A worked pinto is fun but dont expect anything NA over about 160hp unless paying someone who knows what they are doing to port the head which will cost $1000 alone.
For a muck around car perhaps look at just rebuilding the bottom end, get the head cleaned up and stainless inserts installed, a fr32 or similar fast road cam, extractors and 32/36 standard carb. This wouldn't cost much and would be about 115hp.
Gaz
Gaz
