Everything posted by AE25
12th New Year Jap Oldschool Meet, 20 Jan 2019
AE25 replied to AE25's topic in Upper North Island Region
That weather aye... -
Westgate meet point edited to starbucks -
12th New Year Jap oldschool meet. 20th January 2019, 11am - 2pm Massey Uni, University Ave, Albany Auckland, tier carpark outside 'the ferguson'. This is an annual event held on the 3rd sunday of January. It happens to also be Kumeu Hot Rod show weekend. Loosely based on classic Japanese and Euro oldschool cars . pre 90's preferably.. But that is not strict at all. Bring your car, have a yarn, and wear sunscreen coz she's usually a scorcher! Cruise to event, meeting at either Greenlane McD's or old Westgate outside starbucks 10am ish, depart 10.30am. Those in attendance make the call when to depart. No booze, burnouts or stupidity please. Facebook event here https://www.facebook.com/events/343090929864368/ map of carpark https://maps.google.co.nz/maps?ll=-36.733106,174.703518&spn=0.000955,0.002064&t=h&z=20 Past events here http://jap-olds.nz/ Hope to see yas there!
Id suggest option 2 on the rear arch patch. easier to hide the weld when it's on the arch and flat panels are more likely to warp when welding (would pretty much guarantee it will). Dab each stitch weld with a damp rag to cool it and weld in different areas to let the previous weld cool. otherwise that panel will buckle.
11th New Year Classic Jap & Oldschool Car Meet
Looking forward to tomorrow! Might even be an icecream truck -
https://www.facebook.com/events/192124088008602/ When: Sunday 21st January 2018. 11am - 2pm. (starts thinning out by 1pm usually) Where: University Ave, Massey Uni Campus, Auckland. middle tier carpark outside 'The Ferguson' bar. Cruise meetup points at the usual places... Greenlane McD's and Westgate outside ASB, 10.15am, depart 10.30ish. Someone in attendance gather those there and make call to depart. For previous meet galleries and FB posts.. www.jap-olds.nz
Re chain tensioner... just checking that you know it is adjustable? rattle upon startup can often be cured with a tighten. 5kg of force on the spring loaded piston in the end of it should move it 0.5mm. (after rotating the crank clockwise to put the chain slack on the tensioner side). also the tensioner are cast iron and break easy so no tapping or leaning on it. Do you has 18rg workshop manual?
10th New Year Nostalgic Jap & Oldschool Meet 2017
sweeet meet guys n gals. cheers! and even the weather turned out well considering the carnage the preceeding night eh. ps.. alistair your 20 fricken rules! -
Accuweather saying 55% shower at 1pm so good to go. -
1 week to go -
fixed! apparently can't change a private event to public. lesson learnt. -
facebook page up https://www.facebook.com/events/215537258907263/ -
Yeap. it works well there. Just awaiting confirmation. I'm too busy with life things to organise more.. but maybe an autumn meet if peeps are keen for it. -
Heads up. The usual late notice but, this is happening More details in thread once confirmed. https://www.facebook.com/events/215537258907263/ Date: Sunday 22nd January 2017. 11am - 2pm. (starts thinning out by 1pm usually) Where: University Ave, Massey Uni Campus, Auckland. lower tier carpark outside 'the ferguson' bar. Cruise meetup points at the usual places Greenlate McD's and Westgate outside ASB 10.15am, depart 10.30ish. Someone in attendance gather those there and make call to depart. For previous meet galleries and FB posts.. www.jap-olds.nz
great stuff. maraetai beach packs out on a sunny day tho aye.
- 49 replies
- fish and chips
- family friendly
(and 1 more)
Tagged with:
Annual nostalgic Jap meet this year?
AE25 replied to ae85 fiend's topic in Upper North Island Region
yup. typically last minute organisation When: Sunday 22nd Jan 2017 Where.. TBA- 1 reply
ke10 and early ke2 with leaf front spring i believe had a 3 bolt steering knuckle. would be same ball joint as a KP. dont have vented disk tho. EDit: and they look totally different with ball joint sitting outside of the 3 bolts. So its not corolla knuckles.
1g-eu manual says: Use API grade SC, SD, SE, SF or better and recommended viscosity oil. Gives a chart for recommended viscosity vs atmospheric temperture. mega frozen balls to 10'C use 5W-30. but dont. -22'C up to 30'C you could use 10-30W. 10W-40, 10W-50 starts at -22'C ish up above 38'C 15W-40, 20W-40, 20W-50 starts at -12'C ish up above 38'C. seems 15W-40 is about the sweet spot for NZ temps. oil pressure (warm) at idle speed .. more than 0.3kg/cm2 4.3psi 29kPa at 3000rpm ... 2.5 - 5.0 kg/cm2 36 - 71psi 245 - 490kPa says when bleeding lifters, dont pull them apart. gives leak down test specs.. 20kg takes 2 -7 seconds/1mm after the first 2mm.
I wouldn't say it a big difference in power. less weight in the ae82 so be faster than your ae101. 20v needs the revs to make power. be curious to race a std fxgt! I would've gone blacktop if i had a choice but picked up a complete ae101 for dirt cheap and had the setup sitting there waiting for a chassis. Its a relatively simple conversion except for wiring which not everyone's cuppa tea. flat spot... maybe check tps position, map sensor and fpr hoses have no splits, put some injector cleaner in the tank. um, check water temp (green) sensor is plugged in nicely.
admit to having soft spot for ae82's. learnt to drive in dads old fxgt. not much original in the one i have now. 20v ST, using ae92 superlows from memory in a mix/mash ae92/101 brakes n suspensions. rear upper spring cap needs ae92 version to fit coz different diameter. plenty 82 nutters on ae82.net yeh nz new didn't have the oxy sensor. see if you can track down the toyota yellow book for ae82 and the 1983 4age blue manual. heaps of info in them. should be able to download too.
naw, got the hots for david eh! yeah defo do an autumn meet Ed. It usually has to conflict with another event that time of year tho. also been suggested to do a premeet and cruise to caffeine n classics. kinda makes sense since they've taken every 4th sunday off the available dates. might have to start a pole on it
Massey Uni Albany confirmed. lower tier carpark outside The Ferguson bar (gymnasium building). left at the uni round about and first left into parking area. Cruise: If people want to cruise together to the event. The usual spots to meet are 10.15am at Greenlane Mc'D's carpark or westgate shopping center outside the ASB. leaving 10.30am which is dictated on the day by the people in attendance. (Gather yourselves together and make the call). Cheers
