I got some advice, take your time when your putting on the main oil seals and sump gasket I was pretty damm careful and its been sweet for 3-4 months however long I've had my 1600 in, but yesterday, oil has started seaping out and I'm getting a small drop under my engine each day. GRRR
Box shouldnt be more than $250 at a guess? There may be other ways of doing it, cause that guide seems real complex and all the people who have done it wouldnt of gone to that much trouble I'm sure of it But yea its a great guide so you cant go wrong. I would do it but I'm sposed to be saving for Uni next year...
I like the 3.89:1 thats in my escort. With the old 1300 it wasnt enough power to get any good accelleration out of it but now that Ive got the 1600, I can take off real quick and cruising at 100kms well... you get used to it.
Also I meant to ask, what kind of air filter are you using on it? If you have just a standard air filter, I highly suggest jimmying up a open style holder thing for it (dont know the name) like I did. Its a bit rangi but you can make it look good and its definately worth it for the sound alone Awesome induction noise compared to a standard air filter unit
http://img26.exs.cx/img26/948/Engine.jpg
Webers are easier than alot of other carbs to tune so consider yourself lucky Do what you can to let it warm up so that it idles with the choke in. Wind up the stop for the accellerator if you need to. Now just tune the needle screw valve thing until it runs smoothly. When its running smoothly, wind down the stop for the accellerator untill it sits at a lower rpm. It takes a bit of fiddling to get it perfect.
Hope you let it warm up before you revved it to 6
Mine stays on till i rev past about 1800. Check all the main power connections and things, look for lose wires; battery, voltage regulator, coil, fuses, alternator, starter?
Im keen to know more about cost etc, and what is BNT? My old 1300 mounts looked a bit tired when I put them in with the 1600, would be nice to get them re-made with urethane
They did come with webers, although these were assembled by ford and labeled as weber and therefore are supposedly not worth as much. Not sure if that is the one, I have one downstairs so I'll check the number later on.
I removed the entire back seat, two little plastic clips, the C pillar covers and theres still these three unknown hinge/weird things. they extend into the shell, looking from inside the boot you can see three evenly spaced indents about an inch long, I'm assuming they go into these but I got no freakin idea how so yea I gave up. Thanks anyway guys.
Kyteler - Your more than welcome to fly yourself up
