GregT
Everything posted by GregT
  1. Ettore knew what he was doing. Even if most of his stuff is fiendishly difficult to reproduce. The chassis forgings where tube meets rail are state of the art for the period. Welding at the time wasn't trusted - with good reason. Looking forward to seeing the clutch parts done. The Bugatti clutch is a clever semi-centrifugal device. Keep up the good work.
  2. I saw the run of JAP's for 500cc cars. Before assembly. Dark brown chromate on the crankcase satings. Wasn't told who did it.
  3. As you're in Auckland I'd give Ken MacIntosh a ring. A large proportion of Manx Norton engine castings are Magnesium so he'd know who's got chromate in the area. I've seen bits come out of Auto Restorations here in ChCh which have been chromate treated so it's available. Some years back I was trying to do a restoration on castings which had been done with a greenish chromate. Much investigation revealed it was an obsolete NATO treatment. Black/brown seem to be all that's available.
  4. Remembered a problem which cropped up with mine. Unless yours has been modded or is a CF2, you'll have drum brakes all round. I found that even well balanced fronts showed signs of being out of balance. Narrowed the problem down to the drums. The worst one had the OD 5mm off center from the drum inner. Very poor castings. Used a mates big lathe to machine the od concentric and never had a problem again. I was told the accepted fix was to go to a place which could balance wheels in place on the vehicle. in the 80's there was one place in ChCh. No idea if any still do it.
  5. Mine was short w/b. I'm not sure a PC diff is what you'd want now. From memory it was about 3.5:1 which really did limit me to 13in wheels. 14's or 15's are a much better size now - 15's in particular as there are a lot of Jap vans on that size. See what it's got in it now, get it running well and make the decision on diff ratios based on what you've got in front of you.
  6. Vin plate on mine was stamped Waterloo diesels. That company doesn't exist now. Possibly went out of business mid/late 90's
  7. Have you found the compliance plate yet ? Curious if it's another one of Waterloo Diesels jobs.
  8. Interesting. The cam blanks I was told have a very low reject rate. Maybe a specialist foundry.
  9. Some time back, talking to my local camshaft regrinder - who has a contract with Cosworth USA for "import" cams - I was told that 90% of the cast iron blanks come from Turkey. I'm wondering if the fairly recent quakes there have affected the supply to the point where manufacturers are now using alternatives to CI.
  10. I bought mine as a 2l petrol converted to a camper. Ripped out the bunks etc but kept the lining and the PC Cresta diff. After one extremely expensive trip to Teretonga where we had a headwind all the way and had blown our fuel budget by Gore it got the LD28 conversion. An outfit in Waterloo Rd ChCh did it. They were doing one LD conversion a week at that time. When I went to pick it up I was met by a mate from speedway who'd already driven it and raved about how quick it was compared to the others they'd done. Told them what the diff was. It would cruise at 115k with two bikes on board. Never did find out absolute top whack as over 120k it was still accelerating - but very slowly. Went to most NZ race circuits in the following 5 years Puke to Teretonga. Had to keep it on 13in rims as 14's would have geared it too tall. Bit hard on rear tyres - rolled one off the rim running fast and empty once. Rust killed it ultimately. Far as i know it's now a mobile shed on a farm around Waddington. The wife loved it. She dragged off a Porsche once. Nail it hard and the left front got very light. From my experience I'd look hard at a taller diff than standard. But also fit bigger rims. They've got enough torque to pull something taller.
  11. Sprint car and midget full width axles simply have a shrunk on flange for the final drive. It'd be easy enough to scotch key your setup if you wanted belt and braces.
  12. Exhaust box....An empty tube - say 4inOD 1.6mm wall. Across the back of the car. Your two sides discharging into it straight in 90deg to CL. Discharge pipes from each end. 1 1/2in OD. Length inside box to be perf tube same 1 1/2in OD. Close/blank off the inner ends of this and make them overlap with a figure 8 support in the center of the box. 90 deg bends outside the main tube for the discharge pipes to point them out the back. This will work - and not be too noisy.
  13. Yeah. Looks like it may be the bolt on the end of the crank which fails. That's judging by the pics as i can't open the parts fische. In my experience those are usually a dry loctite coated HT bolt which is often put in on the line using a pneumatic tool. Very easy to overtorque I'd think. I once had a GS1000 in the shop which had never been opened from new. I finished up using a 2ft long bar with another 3ft piece of tube over that to get the alternator retaining bolt on the crank end undone. 12mm fine thread and way overtightened. I'd doubt if there's any offset on the bores. Very rare on flat engines.
  14. Talk to WWS about respoking in a heavier gauge spoke. If you're going to do more of this riding.
  15. There's an old trick for endurance races/runs where you wire each pair of spokes together where they cross. If you do break one it's not going to get caught up in anything and do damage.
  16. Changing the cams direction of rotation is only the start - and probably the easiest bit. Plus it's probably one of the ones affected by the recall. Honda haven't come up with a fix for the bolt breaking yet. The head gets stuck in the gearbox and locks everything up solid - which can and often does break the cases.
  17. You appear to have dodged a bullet. 2018 and later goldwing engines have developed a fault and there's a recall. Two faults actually. Late fuel pump rotor disintegrates/swells up and seizes. And a LH thread torque to yeild bolt in the gearbox breaks and locks everything solid. Late 6 speed and semi auto boxes. Info on the goldwing forum.
  18. You've opened Pandora's box here. Once you get into 2 stroke tuning you can go down some serious wormholes. Find A Graham Bell's 2 stroke tuning on line - there are free sites with it. Download it and read it. It's basic by current standards but it'll do you. Rebore as small as possible. Leaves some life in the barrel - and you aren't moving port edges very much.
  19. While you're faffing around in the passenger side, lube the bloody cables to the bonnet and boot releases. they were so stiff on ours it was a right pain. And i believe the next owner actually broke one of the levers. Like the door catch, shit die cast pot metal.
  20. There's a few sheet metal places in ChCh who would roll them up for you. Might even be worth asking the metal spinners too.
  21. As promised. I'd think the pressure plate spacers would be the thickness of the extra friction plate plus the plain steel plus maybe .020-.040in. It'd be a case of mocking it up on the bench to see if the release mech fits or if the bellhousing needs spacing.
  22. I've got quite a good drawing of how it's done in one of Phil Irving's books. I'll photograph it and post it tomorrow. Basically you space the pressure plate out about half an inch or less and fit a second friction plate - with the bosses thinned on both. And a plain steel plate driven by the pressure plate spacers goes in between. i was told that a circular saw blade is a good starting point for the plain plate.
  23. If you're limited for space and a better pressure plate, what about twin-plating it ? Same pressure more torque capacity.
  24. How'd the body hold up Sam ?
  25. Put it on farm reg and stay within a 50km radius of home. Or not.
