Everything posted by shizzl
i complied a convertable merc that had a 17" spare,but it had a weird pirelli tyre that you inflate with a can,so its in the boot deflated and hope the can doesnt go bad... can you buy 17" steel hoops as blanks? or are you wanting some to widen?
she moves under her own steam boys!!!!!!!
fireworks from alice springs reminds me of that indian guy off joe dirt.. batmo power= nice
fukn awesome man... do not change the exterior at all....its the shit... and what an epic roady with the boyz
yeah... i think i have solved the clutch drama...not physically but mentally... i yelled at it... no, in the pics below i didnt take into account what happens to the housing when the piston moves,it goes backwards,and there was nothing stopping it...so ill go and get some bolts for the input snout that are 10mm longer, and put nuts onto them to use as a spacer,this will stop the housing moving back... and the piston should push the bearing into the pressure plate....
got the brakes done...pedal feels good.. all im needing now is the thermo fan set up and p/s belt tensioner a shifter fitted and sort out the bloody clutch throw out bearing again... the clutch issue has always bugged me... this is what they look like stripped..and the bottom pic is one complete...
picked it up today... got it for $2800 unseen... drives fukn great.. slow= yes.. thirsty= yes but not as bad as our 4l falcon. well its not too slow but it has no power curve to speak of just a gentle puuurrrr... handles mint,brakes good... it has a warranty too for the head work.. has a new head,reco radiator,waterpump and shit.. wanna find out if i can put a sc14 blower or similar on the side of it.. cant think of any good/easy diesel engines to drop in it..
im picking one up tomorrow... sold the mu tonight.. may look at dropping in a MPV v6 later if the g6 cans out.. found out that the G6 is a mazda version of the mitsy G52.. factory they have puss bucket head castings, lots of weak points. however a good old kiwi cunt made new heads with more material in the weak points. so if anyone is gonna buy one,try to find one that has had the head replaced with a new one,like the one were getting... may also look into putting a blower or hairdryer on it...
http://specs.amayama.com/specs-mazda-pr ... ril/15152/
where did you get them from? not all shocks do rebound by themselves, some do require the assistance of a spring.. ive bought 6 new shocks for the stockcar this year and only 1 pair actually extend back out, and very slowly.....
O Hai... has anyone had much experiance with mazda g6 engines? theyr the 2600cc found in proceeds and b2600s.. from some info i found that was very fukn minimal it said the power was 88kw...240nm torque and 8.4 compression ratio. does this sound right? my thoughts is that it has low comp....? can it be turboed/supercharged?? ive been looking at buying a proceed cos theyr big enough for the whole family plus some hot swedish hitchikers, plus tools and towing the stocky....but not really common in Diesel power.... thoughts?
fukn math geeks.
Drive shaft - Changing conections and shortening
shizzl replied to My name is Russell's topic in Tech Talk
ive used ADL (automotive drive line) in manakau in the past for rotorvans and ute conversions. I just measured from the end of the gearbox housing to the diff flange and they got er done.. just make sure the car is sitting where it should when its measured.. 2 days ago i got my stockcar driveshaft made up from a bighorn slip shaft i think it was the front driveshaft.. they just redrilled the flange and milled it down to fit in the diff flange. and changed the front flange over cos the UJ was fukt...cost me $50.. -
was just gonna say 25:1 till i read blackys post...^^^
do those but twins and facing each other so they look like theyr talking to each other... epic LOL
fuk yeah, score +1 to me...LOL
another possibility is a leaky carby... or gremlins.....
my thoughts would be running abit too rich? or fuel filter...
yup,heavy passenger... did you say grease them up?didnt see it... but yeah,love having the brake rollers at work.. used them to check the loaded weight of my trailer with the stockcar on it...
free up ya caliper slides if its disc rear.. clean them up and rub some rubber grease on them so they slide in and out real nice.. this will solve it.... and brake inbalance should allow up to 30%. but if it spikes above that at all its a fail... thats with heavys anyway,not 100% sure on light private vehicles... we have a brake machine at work, my rears pulled in a 42% on the rears= fail, so i took it to a shop with no brake roller= pass.. have since freed up caliper slides.....mint
fired the bitch up today fellas!!!!!!!!!! mass erections all round.. got all the wiring done apart from the alt, oil pressure light, fans and oil temp sender. need to figure out where ill put the sender. my alt and other bits arrive tomorrow including my shifter. my driveshaft is away getting machined. will get it in a drivable state this weekend. although ill still need the brakes done, need front pads and rear disc/caliper/brake lines.. if anyone can help out with parts this is what i need: front pads fdor xe/xf falcon any falcon rear disc and caliper (or any 5x114 with a deep hat) radiator fans (i have a vl commy rad,so i think skylines etc will work) plastic backed mirrors like what trucks etc use. for my spares bundle i need: hilux axles diff heads 3speed HQ boxes 253 v8 clutch plate 14"x3" air filters early bighorn driveshafts wheels- 15x7s or whatever tyres tyres tyres...
also isuzu mu calipers are usable...has the handbrake on the caliper..
heres the newest pics... didnt realise they were out of focus... next on the to do list: put the gearbox in when its ready rear brakes driveshaft radiator piping thermostat housing alternator p/steer pump bracket waterpump pulley wiring bolt it all together ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D
