Everything posted by JustHarry
@sheepers Where did you get the new carb from?
Weird
Karls - 1975 Datsun 260c of Zutututu/black smoke and rust
JustHarry replied to - i5oogt -'s topic in Projects and Build Ups
justharrys 1965 pontiac bonneville discussion
JustHarry replied to JustHarry's topic in Project Discussion
I'll get them apart and have a look first. Since they're the old shoes that have been in it for ages I'm thinking on of the linings might be lifting on the leading edge -
Been home sick from hanmer. Decided I should do a little on this. So this arvo pulled the booster and MC found the pin in the booster was to long for the MC by 3ish mm. Pulled pin out. Ground a bit of the end till it fitted without touching in the MC. No more dragging brakes for the win. Now just to work out why the rears grab so badly
- 34 replies
This ^^
The non power steering column is too short, so could you just make up a spacer to fill the gap?
For power steering you will also need the column from the power steering car aswell
Fixed the driver's side sills this evening Parts car had a rust free boot floor Ready to weld tomorrow
- 21 replies
@toy-mota the ms75 wreck I pulled the manual bits out of had a two piece driveshaft. Facelift also
So much productivity on this.......not Decided to get something done on this. Trans pan was leaking from changing the filter. Dropped the pan and lots of atf all over my arms cos no drain bung. Rip. Also pulled front calipers again cos they are dragging. Might/will probly drop off at CBC and pay them to go over them and make new again . No photos
Pitureless update. Spent a bit of time on this today. Took the front brakes and one hub off. Found the front calipers a pretty rooted. Bad pitting on the caliper pistons and the insife of the calipers is pretty manky. Could probably do with new disks as well Also front left wheel bearing is toasted so might as well do both sides.
Yea can't see them
Yea gets engine braking in low. But is pretty slow going down in low when it hooned all the way up in star
Took half a sick day today. Felt like taking the Honda for a wee Hoon round lyttleton. Went up dyres pass all in star. Brakes were a bit average on the way down though Looking lush at Cass bay Sign of the kiwi
- 13 replies
Plus manual civic is being aquired
Shouldn't be too hard. Manual swap. 1600 Accord engine
