Everything posted by HumberSS
HumberSS buys complicated Mercedes 4wds so you don't have to
HumberSS replied to HumberSS's topic in Other Projects
There are things to learn before you commit, I really should update this thread properly with the gl tales. I would say if you don't mind spannering your own vehicles (you are on os clearly...) they are really coming into quite good value for money territory compared to anything suitably capable/comparable. I think this is what scares people most about owning Mercs is they hear horror stories of repair bills. But that's from people who don't know which end of a hammer to use.. Cost of parts is pretty reasonable through rockauto. I've done more than I expected to due to buying a less than mint example, had I have been a bit more patient I would have brought better with probably a bit lower KMs (brought at 210, now around 232 in 9mths) Hasn't let me down. Is a very easy car to live with, plenty of grunt and good on juice. -
There will always be tails of woe, you just have to push through. You looking at w164 or w163? -
Think I saw that too, was it in South island? Have seen more and more modded ones popping up. Seen a few daily drivers around here getting suitably abused. Its tough being a trendsetter. Some dude in FB has put 37s on one. God knows why. -
Humber SS's 4V Century V8 powered Dyna Camper
HumberSS replied to HumberSS's topic in Projects and Build Ups
Been getting a bit done, cbf smacking out a big update right now. Couple weeks ago we got the bitch fired up. Thanks to the GC @fletch for his exceptional trouble shooting abilities.And timing light. Working on water pipes now so will hopefully be on to diff next Chur https://youtube.com/shorts/loj9hqDgwQE?si=C8Xhtq75FGZGLL2j- 60 replies
- 16
Just slap a pipe out each side in front of the back wheels and call it done....quick and dirty. We need to see skids. Well done mate
above my pay grade too!
You going to put a heat exchanger between pump and tank? I'm also rebuilding my old compressor, with much less enthusiasm than you...
Always been curious of those standalone ECUs for the common rail Mercs, great to see someone using it for a conversion. @dmulally do this mate! There is one sitting at pickapart in np... Would love to know how simple these setups are if you have more details
More pics. Also, I only have 7 original plug leads and they are not flash, and one oddball. I'm really struggling to find replacements that fit and would appreciate any Intel on sourcing something suitable. Amayama list but no stock.. wondering if maybe I could butcher some 7M leads perhaps? -
Well behind on updates here. Slow progress, school hols and general business has not seen the results one ambitiously thinks will happen in the desired time frame. #projectlife. Where to start? Have now finished engine cradle including a few notches for critical engine bolts. Made a complicated pipe to move water around. Started with ally bends off aliex but ended up going with tighter ss bends I had. Have since swaged ends to help with pipe retention Next stop has been to get engine to a point where I can start it. Got a belt, made a dummy wiring rig for startup. Cunt won't start, have spark, suspect I m not pouring enough fuel down the hole, and also haven't checked if I have 8 sparks, so need to do that. Pretty sure I've got the timing bang on. It's using and early chev hei ignitor. Was hard to find definitive info on wiring but eventually got there, and spark at plug tells me I have done something right.. before doing that I used some clay to measure my seal thicknesses and ordered these, buttoned up rocker covers with fresh coat of wrinkle black, Im happy with the look. Really want to hear this bitch now. I managed to get in touch with the original engine builder, it was built about 20 years ago. It's had head work, skimmed, block decked and cam reprofiled. On cranking I was seeing about 40-50psi oil pressure which is reassuring. Other things. My mate has been doing some of the bolt on panels as he owed me a favour. I've also been partaking in my other favourite pastime of staring at other parts, using motivational herbs, and figuring out next moves. Toilet will go under drivers seat, under the D40 Navara rear bench seats I acquired some time back.- 60 replies
HumberSS's Datsun 240c coupe of irrationality
Sporadic sunday morning update. Intention with this project was to do the bare minimum and get it to functional. So that doesn't appear to be happening, shock horror. If it's worth doing, I guess it's worth doing right. Or burying myself deeply it in and selling on OS in boxes for $500... Finished tidying up and rewrapping all the loom in the front. No pics. Decided to get it up off the ground so I can make the floor all pretty, I figure with revinning I'm not going to fuck around and have them pick holes it it, the jobs just have to be done. Easiest way to do that was drop the running gear out and lift the body off on to some stands I hacked up. It was a surprisingly simple task. Might turn it into a brodozer on 37s... I haven't taken many pics, but I've scraped all the under seal off the underneath from the doors back, it's really sound and haven't revealed too many other gremlins. I've dropped the brake and fuel hoses out as these are toast. Thinking I'm gonna get a little pot sandblaster to deal to all the surface rust, then brunox/paint/under seal. Also discovered another 20hp under the bonnet. Not sure if they get picky on this shit for revin?? Meant to be L24.. I wanted to start at front and work my way back, but I need to bits to ensure I can align everything, so until such time I decided instead to attack the rear. Drilled and cut rear panel off, have started cleaning shit up and deciding how I'm going to attack the patch work. It needs new floors either side of spare wheel well, but weirdly the well itself is fine. Needs ne bottom quarters and a little bit of inner quarter and inner wheel tub work,so I'm just gonna start picking away at all that. I'm enjoying the process. Also, @ajg193 found my missing plate under one of his presses. And @ThePog found me some sweet widened Jeep rims which I'm gagging to get my mitts on- 9 replies
- 23
Hey man set of triples for a zed car here. https://www.facebook.com/marketplace/item/1419386445672831 I had a mk3 as my first car, never actually finished it but it had some cool period-correct fruit including the Geddes speed manifold running a 3L capri carb, and a floor shifter called an 'impala shifter'. It was a kit that bolted on to the side of the column shift box and stacked 1-2 above 3-4 with reverse right down the bottom and back, kinda cool. Sacked on the obligatory widened 13s and in british racing green. regrets..
77Magnum13hundy's 4age+t Magnum discussion
HumberSS replied to 77magnum13hundy's topic in Project Discussion
It's a shit job. I'm doing mine underneath car on frames which makes it even more fun! Worth it in the end though -
Cunty job. Am in the midst of floor skunge removal on the datto. Not fun! Recommend scraping all the under seal off first before blasting, will make the blasting job a bit easier. Good luck! -
HumberSS's Datsun 240c coupe of irrationality yarns
HumberSS replied to HumberSS's topic in Project Discussion
Haha. Cheers! -
@Flauski my Japanese isn't so good. How did you punch in to do the above searches? Want to do same for century parts.. -
@HighLUX I think I'm retarded. Can't work japan-parts.eu ... Need to find plug leads part number also... Hints on how to use search function or direct me part number to if you are feeling inclined.. chur
markw's 1973 Fiat 124 Sport Coupe discussion
HumberSS replied to markw's topic in Project Discussion
These are really cool cars, fond memories of a school teacher having one many years ago at high school. Good luck with the Resto, it looks pretty sound aside from the paint issues. Excited to see what your engine plans are -
Thanks bro appreciate the links! -
Been a few weeks now since I've had this thing. Started by deskunging engine bay with degreaser and waterblaster. Lucky my shed at home is so shit, as I had to waterblast it inside as the brakes are still seized. Before and after Removed a whole lot of junk out of the engine bay. Was originally a CNG car so all that shit went in the bin. Also had a/C so I pulled all that out too as I have no pump and the rest of it looked pretty unserviceable. Keeping it simple for now but would love the opportunity a/C eventually. Then set to deciphering the basket case wiring. It's like 15 year old me had been there and thought I could improve on it. Bit of work with the test light and had it all figured out. A lot of fuckery was going on but I got to the bottom of it. Had an electric pump owing to the CNG, I didn't hold much hope but shorting it sprung it into life. Next up removing many broken studs and retapping holes. All gravy. The big news today however is that after finding all the various parts that were strewn all through it (thankfully only a few bits are missing), and assembling back onto the engine with a new manifold gasket, thanks to @fletch new front pulley (had big chunk missing) and new thermostat housing. Old bitch fired up, after my comedy of errors forgetting to install rotor...woops! Thing runs mint, oil pressure around 60psi so I'm happy. I'm surprised it actually ran on the decayed plugs I cleaned up and shitty leads, but firing on 6 and sounding like she's ready for the demo derby! I'm stoked Have also cleaned and vacuumed out the rat shit from inside and pulled the old house carpet out and, whilst not mint inside is really not too bad. Door trims are a bit fucked and the seats have a few tears, as well as missing rear seat base, but otherwise good. Have assessed the rust situation and for an old Datsun it's really pretty good. The floor is mint. I mean mint. One pinhole. Engine bay also only a few pinholes, front cross member is toast though, so will remake once I get a rad support panel. A little bit on inner sills above floor, and both outer sills need replacement. One lower door needs a little bit of work, other is mint, as are the front guards, barring some dents and shit. Lower rear quarters and rear valance are toast, and boot floor either side of wheel well needs replacing. Not looking forward to finding a passenger's side rear window however... Next mish is to tidy up the bay wiring proper and perhaps get the brakes working so I can do some skids. That's why you own a Datsun. Will then work from front towards the back on the body work. This is not taking precedent over the camper, I have simply had more time to tutu with it in the school hols. Have spent a grand total of about $45 on parts so far to get it running, sold off some shit too which has offset the price of a set of widened steelies @ThePog kindly located for me in the mainland. Chur.- 9 replies
- 31
See my v8 camper build thread
fucking excellent. Thanks bro.
Phoned Repco, no listing, am hoping someone can advise part number of the thermostat for one of these? Or even the temp range and I could try get them to match something to the hole? who are the Century frothers?
Sheet metal/flat bar?
All time fave, would love one of these one day, well done
