Everything posted by Mof
I think Burny has a bunch of pictures, I'll see what I can do.
How good
Yeah I've been here for three days
Things you might think about bringing/ l usually forget, Rain jacket Camp/picnic chairs Roll of bog paper in case you get caught short in the bush Towel Torch Phone charger Decent footwear Toothbrush Extra pair of socks if your feet get wet Medications Dobros
Wheel bearings sorted. I'm already packed
Mof replied to h4nd's topic in Other Projects
I've had the front bullbar off and replaced the centre tube I bent while "gardening", found one side of the bar is bent back and tried to straighten it. Didn't fit in our press, so I put it under a stabilizer leg of a crane truck we had in the yard. Put the weight of the truck on it but it didn't straighten. I don't know what the PO hit but it must have been solid! Put it back on with some new bolts, sorted out the front hooks, relocated the solenoid box for the winch to under the bonnet, tidied up the cables for the winch, fitted pintle to the rear, lifted the spare tire up 75mm which took quite a bit of modifying the bracket, wired up the extra ciggy sockets, bought another pulley block, winch extension strap, winch dampener. These are all things I have been meaning to do for ages. Even though I got a wof recently I checked the front wheel bearings and one is shagged so I'll be doing that this week.
What's your budget?
How's your freeboard between the pedal and the master?
Longest week ever
What isn't returning? Be more specific Is the clutch engaging when you release the pedal?
Also maybe have a look at what angle the arm was in relation to the pushrod in the old setup, pedal at rest angle and brakes applied angle. My mind says they should be at right angles to each other at full brake application
Have you got enough stroke on that little lever arm?
Find a tube socket that fits over the ceramic but sits on the metal of the plug and give it a whack with a hammer. That'll squash the washer under the plug. Works for copper washers under banjo bolts
Probably a good thing it didn't happen half way down the south island
Oh yeah, happens to Toyota's and Mitsubishi's all the time...
Just skip that gear
Skinned the outside of the bathroom and made the separator wall between the kitchen and the bed. cabinets fitted cubbyhole space behind the cabinets, removable shelf floor I haven't made yet to access the water pump Benchtop with cooker and sink
That's hilarious
Wheel track width? Do you have airbags, was that the reason?
Wat And on what?
Thirsty thursday at Barts, this thursday 1-10-2020
Mof replied to RUNAMUCK's topic in South Island Region
Just got home -
Pub at least Saturday night I reckon
