Everything posted by bmxnz11
bmxnz11 replied to h4nd's topic in Other Projects
Wrong thread -
More sanding and prep work. Picked up some rebuilt princess 4pot calipers and fiesta side mirrors. I was originally going to run chrome bullet mirrors but these provide a greater surface area and will match all the black trim. Painted behind the grill black and painted the calipers and brake parts. Is there any performance advantage to ditching the brake booster?
- 104 replies
bmxnz11 replied to KKtrips's topic in Lower North Island Region
Keen keen -
I'm still working on this. Havent had as much time as others, as I've been working from home during lockdown. I sanded back all the guide coat and spot printed areas where I hit metal. Will give this a final sand and then its onto color. Pretty keen to get this done. Well and truly over block sanding.
- 104 replies
- 21
Looks right. I got mine to suit a viscous fan. Part number F -17A. GMB. Bought it off a trademe me dealer. On my step within 3days during lockdown.
That sounds really sharp and responsive! Well done on sticking to it. I just replaced the water pump on my escort, was about $ 70 for a new one delivered, but it didnt come with a new fitting, I had to salvage the old.
Cleaned up some engine parts, brake booster, battery tray, rejetted the idle jets, new gasket for the oil pump, removed and cleaned up the swaybar mounts. I assembled and put the new waterpump on the engine but forgot to put the alternator tensioner on! Removed the assembly and in doing so I had to destroy the new gasket. Happy to know the vnt copper gasket spray works very well. All put back together and assembled the rest of the motor for a start up. Unfortunately it wouldn't catch on any cylinders and a couple of back fires through the carbs. The only thing that has changed is I've leaned out the pilot jets from a 35 to a 32 and adjusted the fuel screws. Will check these and any potential vaccum leaks tomorrow. Have since cleaned up a few more cables. Good old British workmanship. Bonnet stay/post should have been centered.
- 37 replies
Bike carbs having been running ok. Have just been fiddling with them with a length of hose and a color tune. They make a glorious noise when opened up Was searching for ages for a particular rev counter. I wasnt keen on mounting it on the pillar, steering column or bonnet. Had always wanted to put one in place of the drivers air vent, which is out of the way and looks subtle. I finally found one at a swap meet and it slotted straight in. Just made a bracket on the back and mounted the original vent below (picture was before I mounted it). For some reason it reads 500rpm too low? I've double checked it's set to the 4cyl. Cant complain for $10. Bonus 'escort' brand. I pulled the rear leaf springs and air shocks to use on my other van, and replaced them with standard parts plus a couple of 2inch blocks. Cheers @Beaver for the u bolts, matches the shocks! Drove it through summer. Had no problems hauling bikes, hauling parts and a couple of camping trips including the maiden wagnats trip. The van ran fine, really needs an extra gear though. Had an awesome time, definitely keen for that one again. Went to start the van the other day and noticed a rather large puddle of coolant on the ground which ended up in this. Ive taken the opportunity to take more out than necessary to clean up the engine bay and change a few gaskets. I've adjusted the tappets and ordered a new water pump, which I'll install after repairing a small leak in the radiator. I've noticed its started getting a bit fumey out the oil cap once its warmed up. The only thing I have changed is the venting. The pvc valve now goes into a small filter, instead of back into the manifold. Would this be a factor? Compression checked a few months ago which was 160-180 across all four. It also has the magic '37' stamp which I believe is a gt head.
- 37 replies
Looks really good. What was the structure/folded edge like behind the guard?
I'll go straight from work. Since Terry's out, anyone else able to give me a ride to the CBD after? -
I'll head straight from work if anyone is able to give me a ride to the train station/cbd afterwards? -
I cant make it out tonight sorry guys -
Finally getting back into this after a few months away. Have decided to paint the outside in two sections which hopefully makes it a bit more manageable. The obvious way was to section off the roof. The other reason for doing it this way is to ensure there is plenty of paint in the gutters which are prone to rust. By sectioning it off, it gets painted when the roof is done, and again when the sides get done. This ensures maximum paint without making a mess. Have been sanding for the last couple weeks. My weak little office arms really struggled with painting the roof today but I'm pretty happy with the outcome.
- 104 replies
- 30
Are you flaring the rear quarters as well?
Anyone able to take up a couple of wheels and tyres to wagnats for bistro? Theres a set of four but I doubt I'll have room to take them all. Can bring them tonight. -
I'm away for this one soz -
Will be there -
Got this a wof in august. Needed to replace a few things like steering rack, engine mounts and a brake cylinder. Kind of put it on the back burner while working on the orange van and house. I played around with the jets in the bike carbs and felt I got them a bit better. Still seems to run rich at idle, pilot/fuel screw screwed in quite far, and doesn't have the pick up at mid range when I put the foot down. Yet to investigate too much. Have started to make an air filter housing for the carbs. Using a cut down filter from a Hyundai pony? It was cheap at a swap meet so I built the housing around that. Carved up a wooden template and used the press to make the initial swage in the lid. Folded and cleaned up the edges before pressing and drilling holes for the thread studs to hold it all together. Will probably just clearcoat it. Next step is to actually tune the carbs better.
Have sprayed a few more items. Battery tray, all door jams, bonnet and had redone the engine bay 'bubble' because it was easier to do the whole thing then to fix a couple of runs. Couple of areas had to be touched up as I didnt wait long enough between coats and had solvent boil. Aligned the rear doors for final assembly before paint. Will put some seam sealer around the hinges to lock out any water. Put in the new door pins on the drivers door and sealed in the drivers guard. The sealer is a soft material that will provide protection from the wheel well but wont 'glue' the guard on permanently. Originally the guards are welded on but I've decided to reattach it with sealant and bolts. Will align the passenger door with new pins then I can start prepping the body for paint. Also made up a new base plate for the subframe and welded that on.
- 104 replies
- 25
Count me in
