krazy
Everything posted by krazy
Hey man if you need pics and dimensions of sr badges I've got a set
- 90 replies
- CorollaCoupe
- SR
- (and 5 more)
I've heard of nail polish for mountain bike forks with scratches in the staunchions
Are u sure it's the right clutch fork? I personally wouldn't cut the hole bigger
Sick wee car man is that a te27 gauge cluster?
{\rtf1\ansi\ansicpg1252 {\fonttbl\f0\fswiss\fcharset0 Helvetica;} {\colortbl;\red255\green255\blue255;\red0\green0\blue0;\red255\green255\blue255;} \deftab720 \pard\pardeftab720\sa320\qc\partightenfactor0 \f0\fs22 \cf2 \cb3 \expnd0\expndtw0\kerning0 \outl0\strokewidth0 \strokec2 \ \ } had a spend up lately and got myself some Christmas presents
A couple of hours and a lot of swearing later me and my brother managed to get this setting in the engine bay {\rtf1\ansi\ansicpg1252 {\fonttbl\f0\fswiss\fcharset0 Helvetica;} {\colortbl;\red255\green255\blue255;\red0\green0\blue0;\red255\green255\blue255;} \deftab720 \pard\pardeftab720\sa320\qc\partightenfactor0 \f0\fs22 \cf2 \cb3 \expnd0\expndtw0\kerning0 \outl0\strokewidth0 \strokec2 \ \ \ }
Thanks for that I have a y series bell housing on the way soon hopefully
i know the autos are 10.5:1 compression ratio have stainless valves instead of titanium and less aggressive cams, the ecu shouldn't be to bad as long as it sees that the inhibitor switch is in park or neutral and an altezza pod filter set up will take care of the afm air box scenario.
I bought the engine as an auto conversion but ditched the auto so I have to buy a clutch and flywheel anyway so no point going for a dual mass did you use factory loom and ecu or did you use an aftermarket computer? thanks for all the great advice and sorry if im asking to many question
im not to worried cost wise most of the work I can get done cheap through work, do it myself
I was planning on using a w55 or w57 with a y series bell housing which should fit with out modification or very little and is the factory ecu that hard to use as have read they need a speedo input which shouldn't be that hard to overcome also a throttle switch on the foot pedal for the electronic throttle body, did you have problems with the height of the engine thanks
hey guy im looking at doing a 3sge swap into my ke25 I already have the motor got it cheap but im just wondering if you guys that have done them can give me some tips, am also wondering if I should factory ecu or not thanks
wee update no rust in her anymore,lowering blocks and 205/60/13 yokos
kp discs are actually smaller then factory ke2# so there kind of downgrade
can anyone recommend a decent panel beater or panel shop in christchurch
these things come out with 88hp at the flywheel from factory because its a 3kb with twin carbs and a boosted compression ratio from factory and also had 30mm intake ports rather than 25mm tapering to 30mm at the valve ill take a photo if u want to see the difference in port size
haven't made much progess but I got the dash and heater out also found some of the old owners rust repairs that aren't to bad
yea its not gonna be easy to push that much out but I thought why not make it a challenge to push out some decent power considering im an apprentice mechanic and hopefully get some advice of some race car engine builders that I know
its going back to the factory red and its getting a 3k with a few little bits done to it to hopefully push out 90 to 100 rwhp
awesome car I personally like worked originally motor and the triple carb and straight cut gears would make it sound awesome, and what was your panel beater like as im looking for a decent one in christchurch
Hey guys this a discussion thread for my ke25 project Thanks Build Thread: //oldschool.co.nz/index.php?/topic/39522-krazys-ke25-sr-coupe/
hey guys ive had this thing for a while but never really did anything while I was saving and collecting parts but its time to get onto it, im getting the rust done soon and then im gonna strip it for panel and paint and building the motor.
