Everything posted by 64valiant
so i done some digging and some searching around with the rims. wasn't having any luck with finding one so the next step was to look at different swing arms to either modify or try fit in the rear of the bike. a Suzuki gs1200ss swing arm popped up for sale in tga. i have a mate local to me that has one, so i shot around to his house with my stock swing arm and got some rough measurements to see if it would work to modify and the common consensus was that its probably going to be the best option to make a swing arm work. so i hit the buy now and had @Mop Head pick it up for me. had a few people concerned that it wasn't going to work and that it was going to be a rather large thing to undertake but i didn't really have many other options if i wanted to fit this 5.5 rear wheel in. and after some comparisons and some measurements the 1200ss swing arm is rather larger and stronger. factory swing arm is 60.2mm tall and 3.2mm thick the suzuki gs1200ss swing arm is 74.9mm and it is 5.2mm thick time to chop it up. gotta trim it down a little bit on the width as well and removed the twin shock mounts off time to get more precise with the measurements chucked them in the mill and @Kimjon showed me how to do some things then we needed to cut some space for the rear shock like the stock swing arm. got it looking like this and i took them home to get them welded up and to do some more measurements cleaned my work bench and got busy again. worked out where the center of the swing arm is and done some basic math and made some brackets. factory mounts trace some out and draw them a bit of grinding and a stepped drill bit later and thats one side all sorted. the bottom side now, kim had already cut these out while i was doing other stuff at his house one day. i trimmed them to shape and chucked them in the bender (vice) and got to shaping them up and making them fit kind of a before and an after well during that time i did go to @flyingbricks house and steel this lathe to re make those peaces that go in the top of the mounts. we some how made the center hole to big. i reached out to josh to see if he could weld these up for me but some times he replies way to slow and often has stuff going on in his own life. so i also reached out to @Rhyscar to see if he wouldn't mind doing some welding for me. he said to pop over and we could run through it see if it was possible. next images can tell if you if it was or wasn't so happy with it. back out at kims again while i adulted with my daughter at my toes. time to try make this fit in. hey thats close enough, lets put the seats and plastics on before i go to see how it looks blue tooth chain but we still got a fair few things to do. daughter loves granddad garys motorcycle so she wanted to sit on her seat. and we are now up to speed a bit more. huge thanks to those who have helped out so much so far and kim for letting me keep it in his shed and use all his tools
- 33 replies
- 14
Was doing some reading and see even the suzuki GS 1200SS run a trail of 99mm. Interesting small bit of random information.
Quick break down on what trail is. Good little video. I'll measure it and see what it is now. Still got all the other stuff so might be able to work out what I did have before hand.
Yeah it'll be interesting to see how it handles over all. I'll have nothing to compare too been I hadn't really ridden it long distance or hard. Looking at this image of it with the fairing, with out the fairing and then with a zxr front on it. It doesn't look to much different But it definitely look stretched out over all been a naked bike now. Handle bar position is completely different to original and more styled like a gsx1400, bandit or a hornet.
back to where i left off. i had bought a few nuts and bolts between trips and in some of the above images now had correct hardware on them. when i was cleaning up and putting all the left over gsx parts in the car i saw it had a cooling block for the brake fluid. it meant that id still be able to run one hose off the top leaver and then down to this and split to each side of the calipers. quickly robbed that and had a brain storm, realized we could make it bolt onto the bike and be semi tucked away. que images @Kimjon mad another alloy block with some holes drilled in it, bolted to zxr triple clamp holes and then extra ones tapped out so we could bolt the gsx parts to it with some tube spacers. should hide well once the light is on. i flicked @Roman dave a message after kim thinking he had a 3d scanner to see if he could scan the rear cover of the dash. turns out he doesn't have a scanner but has said he might be able to draw it up for me so i could 3d print another one. it requires a bit of trimming to make it fit and id rather not cut this oem one up if i didn't have to. apart from the headlight a few other smaller things the front is 80% mocked up and im really happy with it. so onto the rear and trying to figure out what i need and how to make things work. I wanted to get the rear shock in and get that out of the way so we could then focus on more difficult things like the rear rim. turns out the shock wasn't an easy quest. few extra bolts than i expected but it turned out easier to take the rear swing arm off. while going through removing everything of it i found out my dad was a really good nz bloke and twist and tapped the rear indicator lights on x amount of years ago when he was still around haha three peace shock bolt and then we started making the 2023 GSX-S1000 shock i bought earlier fit. we trimmed the bottom mounting tubes 2.2mm each side. out with the masking tape for some guidance Like a glove next was making it fit the top mounting position. and this time it was easier to modify the shock than the bracket. out came the bush. again, some quick math was done and while kim spun the bush up in the lathe i played with the mill i took a total of 5.9mm over all off this. 3mm one side and 2.9 off the other side giving it some free space and not bind up on the other peace. a quick rattle can job and chucked it all back together. fits well and clears everything just fine. unlike the rear rim...... that was the next thing to do. try make that fit and do some basic maths. and it just straight out isnt going to work this time round. the width between the swing arm measures X wide (i think it was 220mm). which is the exact some width of the rear rim with caliper and sprocket on it. leaving no room for the bracket to hold the rear caliper on. i done some extra reading and i had mentioned earlier that a bandit 600 rim fits in with out to much modification, also a 5.5inch wide rim. so i might go see my local bike wrecker guy and see if hes got a rim for sale there that i might be able to trade mine with. mines going to be no use to me. the tire it self fits in nice and snug with room to play, so im happy about that. here is a comparison to the width difference ideally i just need to find a rim that is 20/25mm skinnier, tomorrows problem. we continued pulling things apart to see what else would require work. thought id check the front sprocket and see how much i can move that. and surprise surprise. look what we found im pretty sure that nut is ment to be up there holding the sprocket on. looking closer i can see why it hasn't been holding it on its got no thread in it! so another task tomorrow is to head out and buy a new nut for that and i done some reading about a sprocket others have used before. so ill see if a local supplier can get that while im out and about. till next time. tell me how silly i am for riding this bike home and doing skids on it with no nut on the front sprocket.
- 33 replies
- 13
cheers man, regarding those clamps im sure they wont be that terrible over all. just been impatient atm and want them here yesterday haha. plenty of other small things that will require work so i'll keep waiting.
Lets continue. i had a seat to get a feel of how things were going and if i liked how it was working out. photo credit from @Kimjon liked what i felt and nuckled down and continued making things and working things out. time to make the front brake calipers fit centered to the rotors. i needed some 4mm washers. digged around all the m10 washers kim had and came up with nothing. We found some alloy plate that was 4mm thick and kim got out a hole saw, cut some round circles with a m10 center in them. smashed all 4 of them on a bolt, chucked them in the lathe and I machined them down to the required size. said bolt was hot. 4 washers later and the front calipers are bolted on. while i was doing that kim made a mk2 version of the dash holder and extended the brackets out to the top you can see the miss matched bolts making things work while we mocked it all up. these locations of mounting points are factory points for the dash, good to use them and not modify it if i wanted to convert it back one day/probably never but better safe than sorry. you can see the factory zxr750 ignition hole in there in the top triple clamp. well we made that work with the factory gsx1100 one. Kim made a couple of little stepped spacers. able to drill some holes and counter sunk them and they bolted into the zxr750 part and then drilled and tapped the little spacer. Bolted the factory gsx1100 ignition to that and away laughing we went. chucked the dash back on mocked up the position the headlight would be, slapped a rough front guard on and rolled it out side to have a look. pretty stoked with how its looking over all so far. bars fell nice, front looks good, everything is mounted rather well a sturdy. not sold on the front fender as of yet, but it has been warming up on me. I think ill try get a better condition one which the local wrecker has. i see the later zxr ones are very sporty looking. came home later that night and started scrolling alliexpress for some extra parts. bought some headlight mounting brackets, indicator lights and a tail light. be interesting to see what they look like once they arrive as they are chinas finest quality of stuff. anyway im going out now. will update again later
- 33 replies
- 11
If you were keen with the eyes you would have noticed in the last post i had a rear tire on the rim again. I had cut the valves out of the rims to make sure they didnt have any air in them while we were up in the plane, so bought some new valves from boyds, spoke to a mate who works there and got a tire that held air for mock up. Shot down the road to NTB and borrowed the tire machine to sort it out. boy the rear tire was fun to get on. But managed to do it myself. back to stripping the bike, front first. the main stem wasn't the exact same so we got a bit tricky, done some math and made some things work. cutty cutty head to the scrap bin, machine some stuff up, work out how to cut threads on the lathe and we have this call in your mate @bobby1930 who knows how to weld and hot glue that together, that well you have to stand around for an hour while it cools down after that i headed to @flyingbricks house to use him for his tools. turns out his lathe will do the trick i need. the top triple clamp has the stem go through it and needed to be made a couple of mm bigger to now accommodate the factory Suzuki bearing and nut that you see in my hand in above images. he got all ocd and got out these really over kill machines to measure half a strain of hair tolerance. but we got the top triple clamp in his 4 jaw chuck and got playing with it. picture of nathan doing some work said nut now resting in the hole with some snug tolerances. and back to @Kimjons house to play with the bike. shocks in and the wheel in place. thats right, i made a 22mm spacer for the left hand side of the wheel to center it up as i dont have a speedo drive on it atm. had a play with the top tripple clamp and figured out that i was going to mount my bar risers directly off the top of that and drilled some holes and got into mocking up some more things. Kim had some mates over later that evening so i shot off and done some shopping. Headed back to boyds and this time checking out some bar risers and bars that might do the trick. i came out of the door with these after that i headed to miter 10 to check out there bolt selection and see if i could find some stuff to help do some more mock up. back to kims for another day of fluffing around. started with machining down these bar risers. taking the lump off them and making them flat. these worked really well. we made a bracket off the bottom of the bolts to hold the dash cluster in place as well. chucked the original ignition in the top tripple clamp and i think this is going to work.
- 33 replies
- 20
Hey. While i was in Japan i visited a few up garages and a couple of them had motorcycle section in them. I came home with some 04/05 Gsxr750 wheels. I grabbed these with out thinking as they were roughly $120 Nzd with the rotors and sprockets on them. I had been eyeing up some in nz and saw the basic wheel alone with nothing where asking anywhere from $150-$250 pending the condition. the front and the rear pretty happy with these. slight issue was getting them home for free. not the exact end of the world as so far my luggage was all carry on. but i had a weight limit to be under. following images are how i saved on some weight. thankfully @Kelvin had a knife on him and i was able to cut the tire off. wasn't going to try and get the tire removed the day before we flew out. had to cut it into 4 peaces and chuck the tire in the bin at a pa. I picked up this muffler and one of the other lads chucked it in there checked in luggage I think this was $25,000 yen and worked out to be around $280 nzd at the time, It is a WYVERN Sten muffler. Think it was for a Kawasaki of some sort if i remember correctly. got back to nz and just continued on the trade me hunt. Just to see whats available and if anything new pops up that i haven't seen. Came across some upside down forks out of a 1996 zxr750. They were 30mm shorter than the gsx ones and at an alright price. Hit up @Snoozin as they were local to him to see if he would mind picking them up on behalf of me and placed a bid on them. it was only a few weeks later they arrived at my home while richie was passing by. @Kimjon had suggested we make some things happen at his house as hes got allll the tools in the world. so i continued scrolling trade me for further parts. Had a wrecker locally that had a few zxr750s and 900s listed on trade me. Flicked him a call and got myself some zxr750 triple clamps and an axle to suit. Kim made a trip into town one day and picked up the bike for me and we made a start on disassembling it.
- 33 replies
- 19
Have been doing some more reading on a air-cooled suzuki forum and came across this bike. Pretty clean exam with newer forks on the front and a different rear swing arm in the rear. Definitely like how it looks. Bought a 2023 GSX-S1000 rear shock for 143 shipped. Same eye to eye length and the bike is only around 20kgs lighter than mine. should be a good replacement for the price. It currently has a weird air shock of some sorts in it and that's completely clapped out and even with 90psi it's still bottomed out. Even if this one's not the best it will be a good option and something I can base things off and should be good to role around on as well.
Yeah as i was doing this post originally i was reading a Suzuki forum about what people do with putting a fatter tire on the rear. there seems to be a really good option that works out perfectly from what i could find. Easiest way is a 600 bandit rear wheel, gs500 twin sprocket carrier, 530 chain conversion, GS500 rear caliper and hanger so you can use the OEM torque arm. Running all makes of 150/70 rear tyre you will have no issues , some manufacturers 160/60 will also fit you can squeeze a B6 front wheel in between the forks with just enough clearance with the B6 disc's, spindle sizes are different though. then you'll have to make a caliper mount bracket for what ever calipers you use. B6 speedo drive might be too wide so will need machining down a few mm so ill see what kinda parts i can find easily and i might go down this option as of now and see how i like it and if it works and go from there. trade me seems to have plenty of wrecked bikes of the parts i would need so should be easy enough to do.
Cheers dude. I should really just get some tires, rebuild the carbs and go over the brakes and just ride it for a bit. Ive got a bit of a pay day coming up and it's easier to spend money on a bike that I've already got to get it going than buy another complete bike. Be nice to ride it this summer if we have one.
Hello. This thread is about my dads Gsx1100. It was purchased new by my dad back on the 9/08/1985 after his friend Steve went out and bought a Suzuki katana 750 that was now faster than my dads bike of the time. It was the bike that my mum 1st meet my dad on after been asked to ride pillion on dads bike instead of his mate steves katana. To which previously my mum thought it was a big bike for a girl to be riding (dad had a huge plat). Turns out dad went fast with or with out a pillion and Steve didn't want to do that haha. as the love story goes, mum ended up with dad. they had me and the motorcycle was apart of my life growing up. me as a baby me growing up me having it as a birthday cake toy runs and so on. this image is at our house i bought off mum earlier in the year At this stage you can see why i might like motorcycles as an adult. as most of you know my dad passed away from cancer when i was 15, the day of his funeral i got to ride pillion on his bike and remember reaching 180kph+ it was also the last day i saw dads bike for many years, mum didn't want it around the house and she had lent to to peter who dad use to race with and was a really good family friend who also had the same bike as dad. over the years i had pested mum to allow me to have the bike and to which she said no. in fact one year i said if you dont allow me to have it i will go out and buy my own. she laughed, said i wouldn't. turned up home one 2005 gsx600 anniversary edition bike two days late. who's laughing now huh! she wasn't very impressed. years went on and i think she gave it to me for my 30th birthday but i wasn't allowed it at mums home as she didn't want to see it still which is fair enough. i ended up picking it up in February 2021 as i now had my own shed. i didn't know what to do with it, didn't have the money to spend on it and maybe wasn't also ready to ride it. so it just sat for a few more years. got a cool photo of myself and my daughter on the bike copying a photo i had of myself and dad. It continued to sit in my shed and when i moved back home i left it at @flyingbricks house up until recently. I have been spending a bunch more time with like minded bike people and had done cold kiwi 1st weekend of September which dad did meany of times. this sparked my interests in getting the bike going and on Friday i bought a new battery and 10L of gas, headed out to @flyingbricks house and we attempted to get it going. new battery turned it over a few times to get the oil moving around with out the tank on. then gave the tank a flush out with some fuel chucked the tank back on and put it back together including putting some fuel back into it. then realized we had no fuel coming through to the carbs. quickly unscrewed the bolts on the bottom of the bowels and got some fuel to them and gave it a kick in the guts. 1 hour and 15 minutes later and it was going. the next day @flyingbrick picked me up and we got some new fuel line on the way out and replaced that as the old stuff was a bit brittle, took my gear and rode it home. Gave it an oil change to make sure it had correct amount of oil in it and who knows how long that oils been in there. a huge win that we made it home. there are a few things that need to be addressed and the list has begun. but id like to put newer forks on the front with a wider rim, try get a wider rim and tire on the rear with out having to change swing arms and i will probably remove the front fearing and run with it as a naked bike. you might ask why naked and no front fearing. well i would idealy like a gsx1400 which looks like this and this is the gsx1100 with out the front fearings on it same same but different. I've gone down the rabbit hole pretty fast, which i'm happy about as if i don't i will probably loose interest in this bike and not ride it as much as i should. and here is a bike I've found that has a bit of both going on for some inspiration. talk among yourselves and enjoy watching me go down a rabbit hole as i leave you with dad doing a skid
- 33 replies
- 40
King Country Crusade 17th 18th 19th November 2023
64valiant replied to alfalfa's topic in Lower North Island Region
bummer, i get back from japan the day after. looks like ill have to wait till next year -
i brought mine from amazon and it seems they have stuff on their site and ships to nz
Yeah pretty sweet skill set to have. Becomes helpful to lest know my car in and out so when it does fall apart I know what to do.
- 138 replies
- 1
Cheers dude. Was a pleasure having yourself , @Shakotom and @GuyWithAviators come for a cruise that day. also cheers @yetchh for reminding me to update my build thread.
- 138 replies
- 3
So, back to doing nothing at work. Continued using the bus, caught up with some fellow vw people while another mate visited in his thing. And I thought it was about time I should get a wof. Don't know how long it had been out by. But probably to long been that the gearbox and engine had been out. It went pretty well, only failed on a but of rust. Not to big of a deal. Pretty easy fix if you're not a perfectionist and just want to keep the bus alive. Got my little helper onto the job. She done a pretty good job of it. Put the lid back down and no ones to know the wiser Acquired the wof and took it for a drive to raglan with the family. Brought a folding bike rack that doesn't require a tow bar which is nice. Must have gone to @sentra Dave's house for the weekend as I see bad news in the back of that image. Bus still going strong and we came home 3 adults, one child, bikes and luggage. Cruised along really well on the motor way. Well this didn't last to long. I was heading out to sort out some upholstery and my alternator light came on. Thought I'd lost the fan belt so quickly pulled over, nope belt is still there, oil is still in the engine as it's also the oil pressure light. Weird the light was going out when I was idling but as soon as I gave it some revs the light came on. so I limped it yet again to the job and home again. Spoke to Paul at the vdubshoppe and he said the diodes or something might have gone outa wack. Chucked a multimeter on the battery and thing was reading something around 16 volts and climbing when reving it up. So time for a new alternator, que greg pulling his engine apart again. Insert new alternator and call it done. Back to doing warp speed again. I lie, speedo is way the fuck out. This is 110kph, I ideally need to get this fixed. But not to stressed as I know what speed I'm doing. Random fact, fits a full sheet of mdf in it. It also fits a Honda Monkey in it. Rather well. Got some of the following eyes and Drilled some holes in the floor, chucked a 50mmx50mm 4mm thick plate on the bottom under the floor and slapped a nut on it. Good anchors for the strops and holding the bike still. Took the monkey over to tga for a motorcycle event as i really dislike trailers for one bike. Just continued to use the bus more and more, getting my full use of the vehicle. Back over to tga for Xmas and then up to Dave's house for new years. From here it become smooth sailing and just used the bus locally for a bit. Nothing exciting happened other than heading to garlic masters in it, while we had a huge storm. Driving conditions were not the best but the bus went well. Tune in for my next adventure in the south island for nats.
- 49 replies
- 31
- kombi
- volkswagen
(and 2 more)
Tagged with:
Thought id bump this as well so guys can tell me how silly I am for owning a vw
- 138 replies
Hi all, time for an update. Been a hot minute. It was a few days later and we loaded the bus up for a trip to palmy for swapmeet. Time to test this gearbox out. First stop is to visit sean @oftensideways Made it to plamy smashing the ground a bunch and showering @Kelvin in sparks. was good to be able to cruise at 100kph with out having to rev the guts out of the bus. This is the bottom of the beam and it use to have round bottoms to it, slowly getting flatter and flatter. Anywho continued to drive it for a few more days around town visited my dad and I was taking tayla for a drive in it to the vdubshoppe and it got stuck in gear. Wasn't budging and wouldn't move at all. So limped it to @flyingbrick work and got him to drop me back at home. Loaded The kombi up on the trailer and headed to the vdubshoppe with a broken vw. wasnt long and with a bit of inspection we had this result. Surprise surprise. don't think this is ment to be finger tight in the middle of my gear box?! Fuck, fuck and add another fuck to that. Had the buss together for a month and had driven to palmy north and back and this happens in town. Anyway that gets picked up and the wait begins again to how long it'll be till I get it back. Luckily enough he turned it around pretty fast this time and I had it back in a week. Time to smash it back together again. back together and into normality roles again. This was fixed by 8th of October. Well thats kept me occupied while sitting on the train this morning, will try update some more tomorrow.
- 49 replies
- 17
- kombi
- volkswagen
(and 2 more)
Tagged with:
hey @sluggy all your images come up dead on my phone as well as pc. just coming up with a circle with a line in them.
Oh man! Things were looking so good. Hope it's something so small that can be easily fixed.
Eastcapescapade #6 2022 November 11th, 12th, 13th
64valiant replied to johnnyfive's topic in Upper North Island Region
End of the weekend it had 3600kms, was brand spanking new haha. -
I just rang the hicks bay lodge to double check something. The office clerk/lady on the end of the phone asked. If a bunch of us intended on dining in there. If so could we get some numbers as I said I'd call back around 5pm and let her know a rough amount that would be dining with them. Chur.
