Everything posted by chris r
Auckland CHRISTMAS Monthly Meet - 14th December
chris r replied to Threeonthetree's topic in Upper North Island Region
Got presents sorted and wrapped- 38 replies
- Secret Santa
- Dump your junk
- (and 3 more)
Sweet. I was wondering if less weight = less grip. Makes sense re tyre pressure
It did do good skids. Did you notice a difference with more/less weight in the back?
Double check your join again and maybe test them at the join with a battery.
Ecu was dropped off this morning . What a gc. It's even named. It has a standard type r integra tune until I get it to the dyno and we can tune it better. It'll be interesting to see how many killer wasps it has. I'll be disappointed if it has less them my c10. I updated the list with things left to do. Somehow it got longer?
Is everything new and or in good condition? Have you tested the car side with a test light? Yes you may have voltage with a test light but if there is a shit connection it may drop off with load. If the car side is good double check all trailer wiring.
I was too lazy to search. Thanks,ill have to bust out the post clips and tek svrews
Re batteries in the boot. What are the rules re the cable through the cabin? Does it have to be secured every x distance
Cleaned up the passengers loom and it's now retained and won't get eaten by the alternator pulley. Engine loom is ready to go in. The body loom that plugs into the engine is a tad long but I'm not going to shorten it and make another potential fault point
My cheap China bends turned up. Yes they may be bad but I'm going to end up butchering them with a arc anyway. This whole lot delivered was less than one bend from auto bend.
New (to the car) loom from zebra What a good position for a shift light... The old integra loom and battery cable routing.. I wonder why whoever did this went through the evaporator box instead of the drain/other two loom holes Pulled the old wiring and gauge mounting ply out, I have a aircon control to put in its place so hopefully that works. All I want to be able to have a windscreen demister so I might end up being rangi with the vents but thats laters problem There was a start button as the standard ignition switch was worn/haggard. I stole one out of the parts honda and it was also intermittent. Because I'm cheap I pulled it apart and put some solder on the contacts and filed them nice again, it works perfect now. I've finished this loom and taped it up, This is a part way shot. I have also put the battery jumpsart post in a easier to reach place I've ordered some bends so I can ditch the bigbore, Yes they are cheap sta ones but chase/autobend wanted significantly more for theirs. Probably quoted retail but nevermind. I'm planning on redoing the exhaust at some point in the future. All going well my ignition parts should turn up from rock auto this week. and I can then either fix the spare dizzy or this one. I have added and crossed some stuff off the list. I find the list good as I can focus on one thing instead of trying to do everything at once. Nearly onto mechanical stuff. I have pumped most of the stale fuel out of the tank so I'll have to remember to put some in before a test-drive. It has a puk clutch at the moment and some rumbly bearings. I have a lsd out of ness old integra, According to the internets I can use later model (hydro clutch) internals in this gearbag so hopefully it'll all fit
Loom is getting closer to being finished, I'll sort out all my photos soon. I've found a spare dizzy too which is on its way tomorrow. Hopefully that'll need minimal work to sort. I've got some (slightly) bigger injectors and the tuner has the ecu. I was testing the wiring before pluugging anything in and realised I had looked at the wrong side of the ecu plug. I got a bit pissed and chopped it off and hardwired it all in. Ive started to tape everything up and 3 rolls of tape later i'm not done. The list of things is getting smaller!
Yoeddynz and Hannah's HB Viva Wagon Discussion
chris r replied to Willdat?'s topic in Project Discussion
Well deserved that beer! congrats. I bet you are satisfied it passed -
I always admire your work,keep it up. Good luck for the wof -
Another boring picture less update. Engine side of the body loom is all soldered up except for one wire. Rad fan wiring all works and now turns off whith the key. Battery jump-start/positive terminal in the bay has been moved and tidied up. Horn no worky, though I had fixed it but had no power to test. I've got a list going and seem to tick off one thing and add another on it. Oh and got a new mount and brake master cylinder. The booster has flaking paint and there was sfa fluid in it. It's quicker and easier to throw a new master at it. Slowly getting stuff done
Willdat's this wasn't supposed to be a project Honda Beagle
chris r replied to Willdat?'s topic in Other Projects
Shuttles like to eat/kill the clutch pedal. Have a look at the pedal assembily and usually they fail on the outer pivot. There isn't a huge amount of power difference between the sohc and dohc on paper -
Spend 5 or so hours playing wiring today. I have the store key Fuse box in the Bay mostly reconnected and most of the replacement loom is soldered in on the drivers side. The reverse and brake lights should work now. The old engine loom is completely gone and so is the wiring for the gauges. I found a shift light behind the center vents too.
Dylan popped over the other day and helped me get the bonnet shutting and the stock lower mounts in the right place. Before the rad goes in I need to steal the loom from the parts beagle for radfans horn and air temp sensor. I'll need to pull the dash out to get it out. The engine loom is a mess of chopped up factory crx and integra. So so fix it I've got a sohc vtec loom from a eg civic. The reason I'm using that loom is its cheap from zebra and it has the correct Ecu plugs for a chippable tunable factory Ecu. First I de soldered the Ecu plugs from the beagle. Identified the feeds etc and soldered them on. I could chop the plugs up and solder directly onto the existing loom but I prefer to be able to remove it. The wires at the other side of the loom have been identified and labeled. Next step is to test what's left of the loom on the crx and find the required stuff.
correct me if I'm wrong but I don't think he will be using fuel to test them? Also would it be a idea to use a pwm controller for the fuel pump to help with fuel pressure/heating etc
This has some 'interesting' wiring going on but everything else seems ok. It looks like someone had fitted a later model hydraulic clutch setup put in in the past. It still has the factory belts etc in it. I got the bonnet off a guy who knew about its history so I'll ask him and see what he knows
I have the same complaints about my jazz too. Apparently k20s fit...
It was/is a factory ef8. They are quite fun.
Not that I have noticed. It has had a respray at some point. Is it a good or bad thing if its the car you think it is haha
Not quite shuttle related but I got another honda, Figured I'd keep them both in this thread. I missed my old crx so much I needed to get another. I had a look at this one earlier this year and couldn't justify spending the money. I texted the guy and he still had it and was interested in selling it. It needs a bit of work to be legal but its mostly straight and rust free. It has a b18c out of a integra type R. goes like a cut cat mayte. First thing to go was the bonnet, Alternator wasn't charging so I got someone to whip it out and tested it. I've replaced the regulator as everything else checked out ok. The wiring isnt the tidiest but thats easy enough to sort out. I have pulled out the leaky d2 adjusties and stuck stock stuff in for now. The wheels are on tardme as they are too big and i've put some on from my hoard. I have a stock radiator to replace the alloy one. Also have a muffler to replace the bigbore. Today I put the stock front struts in and a replacement bonnet catch panel. Surprisingly the one off my parts shuttle fitted (after a few pieces of encouragement from the hammer)
Aucklands I NEED A HAND working bee threads
chris r replied to Shakotom's topic in Upper North Island Region
That's a bit on the high side but not by too much . What's it like with a load on? Chuck wipers/fan etc on and re check. When I was auto sparkying I found the newer mantainence free batteries liked a higher charge voltage.
