yetchh
Everything posted by yetchh
  1. So... Spent a good 4 days redoing the back deck. I guess it's because I always like to fuck things up for my future self.. This was another of my just throw it up and not really think about what I was doing jobs.. Old setup, Easy part was stripping it, took all of 30min. So as to make the underside dry and useable I decided to put some plastic with fall into a gutter between the house and deck, This is the last of the capping that goes under the deck, just extended it with treated ply which I then oiled. Gutter should pop out here, can see the ply which I also put fall on away from the corner. Main reason for this is its where we put our bikes. My seat sits where this junction is and my cracked seat gets wet which then wets my ass. Decided I should prob add these bits in here..
  2. I need to do this also so bought a 300x400mm plastic mirror from the warewhare.. Have yet to make them and mirror its still sitting on the kitchen table where I left it 2 months ago.
  3. Fuck yeah bro. My kind of mahi..
  4. You need to get your vaccine....
  5. By the time you've done all the hanging panels, the body of the car will be nothing.. Plus you'll have mastered paint application by then too.. It doesn't take that long and you then don't constantly have left over media appearing while you're painting. Keep it up.
  6. Shit to a blanket..
  7. Finished up the threshold, can see the addition but you always would.. Might stain the whole lot a bit darker.. Also put the trims up to hide the soffit joins.. Soffit before, they don't lol bad in the photo but there's some height differences and gap variation.. The photo has a wack bracing setup cos I didn't want to waste any timber on it.. Typical idiot I was getting a wedge out of a bucket by the front door and totally smacked my head on the cross bar knocking the entire lot down on my head.. Knob.. Luckily the trim stayed up glued by the 11fc, my initial thought was I had and I was spewing as once 11fc goes everywhere its a cunt to get off.. Makes exceptionally good glue tho. Tomorrow I'm gonna take all the spare timber down to store at my old lady's place, then make a start on the back deck..
  8. Also got up and had a look at the roof.. Not sure what to do if anything. Needs a paint tho. Also got to clean up this mess, but now have an extra 7 days..
  9. Made the surround for the califont yesterday and finished it today, has a 25mm gap all the way around so hopefully it's ok. Doesn't seem to get particularly hot anyway, even when it's been cranking for 10mins. Dowelled and lightly glued the sides on, Just 11fc'd the top on, also routed some slots on with side for the bottom cover. Then discovered I couldn't slide it in because the cap below was in the way..... Sanded some off so it just slides in. Oiled. Finally did the taps as well, wanted a brass plate against the timber but couldn't find one so used a brass nut instead. 100%? Yeah almost.. Just got to finish the threshold.. and... Put two bits of timber over the joins in the soffit above the front door (something else I forgot) pretty simple.
  10. Yesterday I made the gas bottle gate, spent to long extending the back door threshold and making a surround for the gas califont.. Gate, just sitting there as in my Haste last Tues I forgot to get hinges. Offending threshold, discovered it was actually rimu and not cedar which makes it easier. Rummaged around in my wood stock and found this mystery block from a ship in the early 1800s (came from an 1830s cottage in lyttelton we restored a few years back. Bloke who built it made all the windows and framing from timber he ganked from the ship repair Dock. Cleaned it up, pretty sure its rimu. Make it work, Epoxy the bitch in. Still gotta sand it as I forgot today.
  11. Three harley carbs.... Aren't they a 45mm?
  12. Yeah there's the other triple on there that's homemade but it finishes before the other one so there's no back up haha.. I find there seems to be a distinct lack of information regarding the zephyr 6 engine, especially since gale force went under. I want to do some porting and upgrade pistons/valve train but there is zero information..
  13. Spent a really long time fucking around with the hole repair in the deck, lucky its lockdown and I have some time to burn. Hole, Made a fake end to go in there, Cut out for the picture framing, Was bit of a cunt to get some nogs under there, got them in tho. Luckily l found some old bits of decking lying around that matched what was there otherwise there would clearly be a repair there. Missus oiled it while I had a cuppa. Cladding back on and finished. Gonna have a massive cleanup outside tomorrow and sort some heights for the driveway.. Edit* fuck.. Just realised I've got to do the gate for the gas bottles, surround for the califont and extend the back door threshold.. Just when you think your out, it pulls you back. If lockdown gets extended again I'm gonna sort the back deck which I could just leave, but if I have extra time why not waste it doing that rather than spinning spanners? Edit2*. Also have bring the taps through the timber at the bottom, luckily have all the gear to do this.
  14. OK, so now it really is 100% done, but. Rosie pointed out to me that I'd forgotten a bit of cladding, so I filled it with a fillet. This is the only example of why I went with the bigger corners. The reason I haven't done this one is I ran out of mac, well I thought I ordered 5.4 lengths of 150x40 but when I came to do them I realised they'd sent me 4.8s. Was a bit pissed. Have about 7 offcuts of 2.2m 150x40. Anyway,
  15. I'll just use yours..
  16. Back seat.. Thats where all dreams are made.
  17. Baited breath to see what's going on up the front... Knowing falcons..
  18. Hey @Benno what did you pay for those SU's? These triple zeniths have come up on the tard that I'm fairly keen on picking up. They're fairly pricey but then again they never come up. Talked to zep (galeforce zephyrs) a while back and he reckoned the triple zeniths had more initial punch than su's but its a struggle to get an air filter to fit under the bonnet..
  19. Yeah, they aren't cheap.. Even second hand like mine. Its missing a few things and I need a thinner riving knife as it jams with my thinner blade. I really want to get the dewalt thicknesser but then I need to find something to use it for..
  20. It all looks very woody.. My missus did suggest a similar style but with Corten. After I priced up 6mm I decided it wasn't worth it. Would've looked good tho. Oiled it, This is the view that would have suffered had I lifted the landing up to the threshold . This looks neater to me. So that is now almost the the entire outside finished. Just have to fill in around the other side where I got too vigorous on the deck with the saber saw and she's 100% done.. Phew, thanks lockdown.. Or covid..
  21. That was yesterday, Today I mounted it, bottom is held on either side with a 12mm dowel the locates the bottom. Corresponding 12mm hole in the bottom rail. Then at the top just angled a 100mm x 14g batten screw both sides. She's pretty sturdy, I was a bit worried it might flex. Capped it off with a 50x100 left over from the the bottom of the house.. She ain't moving now. And again, just managed to get my driver in between the uprights.
  22. Cut the mac up that came off the front corner of the house, a bit of wastage but the only other thing I could have used it for would have made as much waste and more unusable.. But, meh. Ripped the top and bottom and drilled some holes.. Screwed it together.. Photobomb.. When you rip them through the table saw it leaves a clean shiney finish that doesn't hold the stain very well so I glued some 40 grit to a board and made fake bandsaw lines.. Came up good. Enlisted some oilers..
  23. Got the balustrade and the front step done today.. Hit it with some oil.. I did originally want to have the landing at the same height or just below the threshold with the step by the post. Problem was the then the line of the house/cladding looking from the road would be wack. This way isn't ideal but it looks a lot cleaner.
