Benno
Everything posted by Benno
  1. Also keen to get some recommendations on a good one. Can get them super cheap from here, but so many options and having something reliable and not a complete piece of crap would be nice
  2. Shit yeah, looks sweet. You don't need a speedo or indicators, I would just bin them. You should do some research into expansion chambers for these, a decent expansion chamber on it shouldn't be too hard to make/get made and will give you a decent power gain
  3. Benno
    ODBs V50
    Yeah, sounds like it's lean to me. Try a plug chop, run it up to decent revs then kill the ignition so it dies without idling. Does it run better with the choke on?
  4. Could be keen if I've got my new radiator sorted by then
  5. Going to get a cert and all that crap to get it legal or just run it and hope for the best?
  6. Tried pulling the wire at the tank end? Should drop down to below empty when completely disconnected. If so, it's the sender - new one would be easy to fit with the tank emptied. If that doesn't make a difference there is a fault in the sender wire or the gauge. Edit: I'm assuming that the fuel gauge works the same as the temp one at least, have never had any issues so no experience with fuel gauge issues
  7. There are a few oldschoolers in Christchurch. If you're down in these parts maybe we could organize something similar to that one on Wellington where a few people meet up somewhere?
  8. Yeah as above bike is definitely 12v. Making that into an electronic version would be the best solution. Sadly not particularly easy at the current rating necessary
  9. Whoever is organising this obviously hasn't driven those roads, even in a 4wd spec KP it's not going to be a great time
  10. Looking awesome man! No help with the wiring though sorry, I had all sorts of problems with it. Those generic scooter/motorbike 12V regulator units are regulator/rectifier so require an AC supply and don't work with the DC feed. Went to jaycar, turns out it's not all that easy to get a roughly 13V regulator at the right wattage. You will probably need to either fix/replace the existing solid state regulator unit or get something custom to replace it. Someone else might have some better advice though!
  11. Looks like a pretty good system, not on the cheap side though. How is your current dizzy? Not too worn out? I've got a kit similar to this for my escort, http://www.trademe.co.nz/motors/car-parts-accessories/ford/electrics/auction-838909952.htm which seems to go great. It essentially just converts the points and condensor to electronic. Might be worth considering something along those lines, a fair bit cheaper. Otherwise, yes it is negative earth and I wouldn't bother with advance.
  12. Also, my car is currently registered as an "Escort 1.3". I am wanting to change it to that standard just "Escort". Other cars aren't like that, eg it's honda "civic" instead of "civic 1.5" etc. Rang the NZTA, was emailed a MR16 form. However, I require "supporting documentation" to prove that is the case. Just showing evidence that other escorts are just as "escort" isn't good enough. I would even be happy if it was changed to "Escort MK2". Any suggestions or ideas? I don't have an original manual so can't just scan that and Avon City Ford were no help at all.
  13. Been continuing getting some work done on this. Got pretty much everything bolted on and was doing well when I managed to snap off an inlet stud in the head. Bit of a pain in the arse, but hopefully my mate can give me a hand to sort it with an easy out. Did a round headlight conversion on it today, pretty stoked with the outcome! Managed to get a grill pretty cheap off trademe, the buckets are universal between square and round headlight then just needed to get some retainers. BNT couldn't get anything, so went to palmside. They didn't have any new ones in stock so got some 2nd hand ones cheap from them instead which worked out well for me. Got some new crystal headlights off trademe. Pretty stoked with the outcome. One of the existing headlights had had moisture in it, so needed re-silvering or replaced anyway. The whole conversion round worked out to be pretty cheap too, very happy with it.
  14. A few of us were a little busy at goon haha http://youtu.be/1pHHjcqKaBc
  15. Good point. I was more coming from the angle that if the car is low and there are stock looking springs they might look a bit more carefully, wheras if the car is lowered and the springs are red/blue/yellow or whatever they wouldn't look twice at them. In saying that though, I've never had cut springs in my car so may be a complete idiot here.
  16. If you can find a PW80 engine or similar cheap they are a bolt in swap, 4 stroke 80cc
  17. That's what I was meaning, get it sitting nicely then just roll cutties for a while until he gets around to coilovers. Obviously not an ideal long term solution, but would be sweet for a while until he gets round to getting his coilovers sorted. Can't get much cheaper then free and cutties would be alright for a while at least.
  18. Also, my cobra super low springs (40-50mm shorter then standard) are just captive. I had some issues with a strict WOF inspector once where he claimed they were too loose as you could move them a few mm by pulling hard on them when car was on hoist. I fixed it by sleeving the bottom coil with some vacuum hose. In my opinion they were fine though, weren't loose or moving easily.
  19. Frankly, I'd advise cutting the springs. Perhaps get a spare set first in case you stuff it up. If nothing else, you can figure out exactly what height you want/need and then get some proper lowering springs, or switch to coil overs. Cheap, fast and easy. I would start by cutting half (or less once it gets close) a coil off at a time until you get the height you want. Make sure that each time there is enough spring left to stay captive. If you want/need to go lower yet, you can do so then look into either getting the existing shocks shortened or replacing them with some new shorter ones at the length necessary to keep the spring captive. I have proper cobra super low lowering springs in mine, and regret it. They have a higher spring rate then I want/need, so the car rides a lot rougher then it needs to. I have a mate who has literally cut one stock spring in half, then put half in either side of his mk1 and it rides nicer then mine does and sits at a nicer height. Depending on how low you end up going with the cutties I might suggest painting them a similar colour to legit lowering springs, then if you ever have any issues "No sir, they are legitimate king springs". Just a suggestion at least
  20. Sure do! So will also probably be busy Sunday at Rangiora
  21. Cheers. Not entirely sure about the full specs of the engine, know it has been fully rebuilt (top and bottom end) with a port and polish job, oversize valves and a bit of a cam. Yeah, haven't ruled them out at all for the future. Will get everything running sweet on the 32/36 to start with, then look into my options after my finances have recovered a bit. I got some stainless fittings from Hydralink in the end. They are a tiny bit small on the output end, but might be able to take up the slack with a hose clamp though. Won't really know until my hoses get here. Thanks though man!
  22. Moved to a new place where I finally actually have some garage space and can do some decent work. The starter motor on this crapped out about a month ago, sadly the one on my new engine is a honda one and requires bellhousing modifications so wasn't an easy swap. I got an average starter off a mate which lasted me a month or so, but once again it died. Decided replacing it again it was too much effort to fix so just pulled the engine out haha. Got Scott (brdflu) and Hogan (427carguy) to help, they stood on the strut towers with a strop and sway bar and just yanked it out haha. Bit of a mission, but got there in the end. Cheers guys. Then did a bit of work cleaning up and painting the engine bay. Just degreased, waterblasted and sanded it quite thoroughly. Then did a rattle can paintjob on it. Not perfect at all, but got it done in a day and looks a lot better then it did at least and should be easy to touch up if necessary. Decided pulling the old engine was a bit much effort, so got an engine crane to put the new one in. Thanks heaps i500gt. Cheers again to Scott (brdflu), Jonny and James for helping me get the new engine in. Still got heaps of stuff that needs done before I can attempt startup. Waiting for a heap of stuff to come from burton power, radiator hoses, gaskets, studs etc so will need to wait a couple of weeks for it to arrive. Pretty happy with progress though!
  23. So I need a new one of these for the new inlet manifold. Is for the water jacket. Small end is roughly 13mm, big one 16mm. Ideally a bit longer at the hose connector end. Any suggestions for where to look for one? Haven't looked hard yet, had nothing at the local repco.
  24. I've never painted a car using plasti-dip, but would not recommend it for anything further then some racing stripes or something. Firstly, it needs a decent base paint and once applied it really isn't that durable - a small scratch or scuff and it starts peeling off
  25. Finally got around to fitting up the carbs. Fucking stoked with how they run! Feels like a whole new bike! Currently running the standard jetting, which I am pretty sure is a little rich. When I pull the plugs they are a tad black and sooty, not excessively so though. At least it isn't lean, so will leave as-is for a while at least, may not be getting perfect performance out of them but they feel 100x better then the old ones did! I'm sure there will be a heap of small things that crop up, but now I have it running nicely I've got all the major jobs I wanted to do done on it.
