Everything posted by SOHC
Yes dont remove that alloy plate untill you remove the carbs in one lot
Must be a stuck float or dirty float needle valve? You have to be pretty brutal to get carbs off, pull one side up then the other, sometime you need a pry bar, and put some rubber grease on the boots when you refit them
I have found it dose not really matter where the seam is, but schedule is important, I bent the frame on the red bike using a shitty pipe bender, its made from 27mm OD no problems with nice bends, just have to make sure its a nice fit in the swage
I have ground and filed the 3/4" swage to 7/16" its now a snug fit and supports the sides of the tube. The 1" swage should measure 25mm but it measures almost 35mm
I am going to do everything in 7/8 on my frames, they will not be trutest copy's, but yes please tell everyone there will be wheels at some stage. It might cut through it, there is tremendous pressure
The pipe I made the red bike out was 27mm with about a 3mm wall. I also filled it with sand. I have noticed with the swages for this bender it has the pipe size cast into them but the pipe is way too lose, I want to bend 7/8" and 1", I will take the swage that is the next size down and machine it so the next size up pipe is a tight fit if you know what I mean? With thees benders you should never expect good results with out modifying the swages or filling the pipe with sand
I have the lone of some TruTest alloy rims I am going to copy and cast, I am thinking I can pretty much make a frame for the cost of the steel and my time, the wheels will cost a bit to make but I already have a few people who want them,
I bought one of thees just now from a guy down the road for $100 brand new unused, I plan to make X4 normal size minibike frames with forks.
LOL it will boil a kettle no problem
I need a bigger pulley on the alternator, its about 4:1 at the moment, its causing the belt to slip and past 12,000 rpm they don't make any more power.
Yes but its much older than the one in this pic^ and dosnt have mismatched pulleys Never use Dennis Carpenter gaskets for fucks sake
it seems to b loosing a spoon full of water every 12 hours, they are comming out and going in the bin and they will be replaced with KLINGER Statite paper.
I got some new water pumps and they came with gaskets, I fitted the gasket with silicon on both sides but water is seeping through the gasket paper and coming out its edge. I thought this is really shitty, its .002" paper and seems to be the asbestos type
I might not be aloud out at night
What about your bubble boot car?
Do you want me to come?
LOL i am about to blow my trousers off with everyone's sarcasm
Tortron's 3.8 Mayte fair dinkum Mitsi Ute
SOHC replied to Threeonthetree's topic in Project Discussion
I saw a red l200 ute the same as your one in Massy, it had a holden v6 in it to -
What are you making?
gearing + rimsize + max rpm = just under 30 mph, it gets there very quickly
SOHC replied to johnnyfive's topic in Upper North Island Region
Thats the one, his name is Mike and he runs Not a motorcycle shop in upperhutt you can find it on face book -
SOHC replied to h4nd's topic in Other Projects
I slip cast them in roofing silicon and plaster, its now all in a hole in the driveway, -
A friend of mine has a Nzetta witch he has put a KTM SX300 motor in
