Showing content with the highest reputation on 18/12/12 in all areas
  1. haha. id be more worried about being able to walk still.
  2. Carls Jr is mean. Thats all there is to be said.
  3. Haha cheers bros, Ahh next time Kurt! Yeah and not many if any Dave. Exhaust is still under a finger height off the ground. But the bent sill rails are just 55mm so I can't be bothered measuring anything lower cause I can't fit my hand under it.
  4. has to pass 5x 100-0 kph stops under 4.4 sec each time, total of 3 minutes to do the test driveshaft loop What sort of V8? another rover?
  5. Hey guys I got some 245-50-14 eagers for my wheels heres some pics and I will put them on and take a picture soon, Im half way through the manual conversion. everything seems to be working ticketiboo so loving that. Here is a couple pics also of my other loooong term project.
  6. i wouldnt worry, the steel ring gear will hold it together
  7. Finished off the back section of the floor, unfortunatly it had to have those sharp bends in it to fit the contour of the chassis and i couldnt come up with a different way to do it without cutting up the chassis which i definatley didnt want to do The seat sits directly over the top where the round part meets the square part so it should hide it I hope and carpet well do the rest Still gotta put some more bracing on the underside and drill and fit a few more brackets where it mounts to the chassis Planning on using this bench seat which im told is out of 1939 chev coupe, has a split folding back which lets the rear seat passangers get in and out, gunna take much modifying to get it to fit and work over the tunnel tho
  8. 1 point
  9. Made up the floor section that goes over the bell housing Managed to put in the compound curves without cutting or welding it using a shrinker/stretcher machine Worked better then i thought it would Made up a blank using cardboard then copied it onto some panel steel and came up with this Test fit, A bit more massaging and it fit not to bad Punched holes right around it for spot welding Welded in place, well take a few hours of grinding to clean up all the welds bit that can wait till later
  10. Pretty sure they match! Haha, had to go and check though! I wouldn't mind getting some more the same if I ever came across some cheap. Someone has done a pretty hory job of attaching these ones and it bugs me sometimes.
