HumberSS Posted January 17, 2024 Posted January 17, 2024 Phoned Repco, no listing, am hoping someone can advise part number of the thermostat for one of these? Or even the temp range and I could try get them to match something to the hole? who are the Century frothers? Quote
HighLUX Posted January 17, 2024 Posted January 17, 2024 japan-parts.eu is your friend for looking up parts #s Looks to be 90916-03064 is discontinued but found ebay link saying gates 33049 will fit and a quick look on rockauto https://www.rockauto.com/en/moreinfo.php?pk=100506&cc=0&pt=2200&jsn=3&_nck=Ekt6BqBF1pwlXdx0gYlm1esw98pF26vehMm%2FGG3C%2Fl2QOXSJubi7WaPjz7KO9EMWpQ6zyi91q6qBHaSNhSV4y%2FVqpepcL5uR%2FyX2AZC2uSYCrJVdlcmau99sX7x9P5Tpjvq8vjvqgShB9cD%2BMfWP3su%2F1%2BaIGXQlT4ScphTkT3%2BquwNQgjyx0zqbYm7Czalmw2l5S9HSR1FN8hTu%2BuM62oohD9zCh5o1FIRPjOHVuXhWrI0TEnYuiiF221EOhsF%2Bak65d7klkBtYtofeViW%2FXds44M4f3%2FIoUylhUtvQlA4f2a8HtCu9%2Bv29MkRdEvfn0Y2dnYZDP7DrrKE4f3WFGA%3D%3D 1 Quote
HighLUX Posted January 17, 2024 Posted January 17, 2024 More googling says Gates 33049 is to fit a 4L petrol landcruiser up to 1992 so maybe try that EDIT:https://www.repco.co.nz/parts-service/cooling/thermostats-housings/dayco-thermostat-73mm-82-degrees-c-dt23a/p/A1182738?kwSearch=thermostat 1 Quote
HumberSS Posted January 17, 2024 Author Posted January 17, 2024 3 hours ago, HighLUX said: More googling says Gates 33049 is to fit a 4L petrol landcruiser up to 1992 so maybe try that EDIT:https://www.repco.co.nz/parts-service/cooling/thermostats-housings/dayco-thermostat-73mm-82-degrees-c-dt23a/p/A1182738?kwSearch=thermostat fucking excellent. Thanks bro. Quote
HumberSS Posted January 17, 2024 Author Posted January 17, 2024 3 hours ago, Bling said: More car details? See my v8 camper build thread Quote
HumberSS Posted February 4, 2024 Author Posted February 4, 2024 @HighLUX I think I'm retarded. Can't work japan-parts.eu ... Need to find plug leads part number also... Hints on how to use search function or direct me part number to if you are feeling inclined.. chur Quote
ThePog Posted February 4, 2024 Posted February 4, 2024 ^ I can vouch for the level of retardation, I bet he couldn't breathe while he typed that. Quote
Bling Posted February 4, 2024 Posted February 4, 2024 Try https://www.amayama.com/en/catalogs/toyota?_s=h you'll have to work out roughly what the engine came from and go from there. Quote
HighLUX Posted February 4, 2024 Posted February 4, 2024 22 minutes ago, HumberSS said: @HighLUX I think I'm retarded. Can't work japan-parts.eu ... Need to find plug leads part number also... Hints on how to use search function or direct me part number to if you are feeling inclined.. chur Select japan since it was a jap market car then year and model then engine type 1 Quote
