  • Replies 94
Still waiting on the panel beater but had a bit of a play with some other bits.
Gave the rear window regulators a clean and replaced a couple of rollers. There was a ton of gunk to clean off. 55 years of grease and dust. I'll still have to ensure there is room for the inertial reels but otherwise they work nicely.
20231015_134903.thumb.jpg.2305b94f7504fbda3d61afdfe170e475.jpg20231015_134910.thumb.jpg.9a84ff819d979923aa8225dbdd24b5fa.jpg20231015_134934.thumb.jpg.6e3e47a91683ee5eadc776ec66adb93d.jpg
Also removed the pink batts from the rear seat base and inserted some packing foam instead. Still a bit agricultural but actually works to firm up the seat.
I'll probably have dynamat under the seat and an MDF cargo divider with underlay behind it so should cut a small amount of noise from the back of the car. I'll see how this turns out in the car once I get it back. Best give the panel guy a call and see how he's getting on.
Some extra boring bits getting painted.
Boot lid
other random bits, side 'vents', rear side markers, and the tail 'cones'.
image.png.c83528685d94c3ca8eb9d658411b1b19.pngimage.png.b2cb325c55727428b07fbbe9e4015474.pngimage.png.df457954734594dd1aa6902323a75137.png
  • Like 9
Got it home the other day, looks shiny and I kind of like it without the C-stripes. The front looks really high due to the slope in my driveway but it does sit high anyway on 'stock' (dobi sport I think) springs. I did measure the rockers at one point and it is actually slightly nose down so it is likely a wheel arch lip height thing. The whole car has been polished to match a bit better but you can still tell the difference between old and new paint. It also has a slight pearl which make it look like a fade in this photo as the front is in shade. Ended up being $15k so hopefully it lasts better than the previous job. I am now spotting more issues with the unrestored portion and seeing the lack of prep in the last paint job I know why so I'll ignore it till it cracks or I have money and am bored.
I am slowly getting into the refits too. The panel beater treated and cavity sealed my sail panels which I was going to do so I just sprayed in a bit of sound deadner but it looked like there was already some in there. I also sprayed some on the interior sail panel trim which is steel. Hope this works better than the pink batts.
 I also  started into the windows. The rear windows foul on the inertial reels so I played around with the spacing but the lock went off and now I can't extent the belt. The same happened on the other side but after 30-45min of swearing at it I freed it up. The drivers one though is still playing up so I removed it completely so I can work on the windows and fix the belt on the bench. Any tips for resetting the inertial reel would be appreciated. I'll leave it till last so if I fix it I can fit it and leave it the hell alone.
Track fitted
Fitted the window and adjusted
Chucked some ally tape on the panel, didn't want to scratch my new paint.
I need to do some googling as I now can't remember where the other track goes and the two bolts don't line up with anything but should be easy to find. Is a prick to get the winder in and slotted into the track.
Bent, fuckit. I think someone might have been trying to make room for the belts or they might have just bent when being wound while stuck on the belts. I'd persuade it back into shape but it is bent in so many planes that it is not really worth it.
  • Sad 4
I ordered some new regulators and decided to work on the trunk divider and parcel tray while I waited.
Cut some shape out of 9mm (I think) MDF. Some trial and error was required.
Covered the parcel tray in vinyl, Ados F3 and staples to hold it. Not my best work but not terrible.
The bracking and area behind the rear seat is not flat in so a flat piece of MDF would not work but slotted a rectangular part in with some glue, screws and ally tape. Cut the edges into smaller patches which are just taped in to place. Work on an aircraft skin at 400kts so should work here.
Lots of tape.
Another issue with the larger divider was it stuck out too far and the seat would not slot back in but this works.
Finished the parcel tray with some holes for the speakers and speaker cloth.
The corners look a bit average but I'll leave it till it annoys me too much and I'll just make another one.
Looks good with the seat fitted.
  • Like 8
Got the new regulator for the rear windows and I initially thought the originals were not too bad  until I sat them side by side. One of these things is not like the other one. The regulator on the other side was missing its rollers so easy to see why they didn't work.
Fitted the new regulators and gave them a test.
Windows go up, windows go down.
Annoyingly but hand is that they don't interfere with the inertia reels at all.
Tons of room. Handy as I can have windows and belts. Annoying as I pissed about for ages trying to gain more room for them and now have a locked LH (drivers side) inertia reel that is unusable when I could have left it alone, done nothing but fit new regulators and no problem bro. Fuckit.
Next step is the underlay and sound deadening. I took out the rear underlay and it has what looks like the factory sound deadening. Sort of a rubbery mat with hessian type insulation.
The underlay felt a bit damp from being there a while so is airing. I ripped out the sound deadener as I have new dynamat to use and the old stuff is degraded. I also wanted to check on the condition of the floor so up it came.
Peeled out really easy so it would have been doing something but not as effective as it should have been. The floors though are mint
Bit of brown in the seams but for what is probably 55 year old paint and no real rust in the floor. Sweet. Ideally I need the seats out to fully remove the carpet but I may just work around them as there is actually a double floor in that area, I assume that is the seam you can see left of the above pic. The nuts are in the upper skin through a small hole in the main shell but with long bolts so I need a really long reach socket to get over the bolt and get the nut off. A standard short socket like mine will never get them off.
Finished up on the sound deadening in the rear. Just worked with the carpet pulled back. Dynamat is much easier to use than I thought. Got it all laid nicely and then put the underlay back on top.
20231210_111256.thumb.jpg.78c50e6c96f760ac0c2c328fa2d79dd2.jpg20231210_111914.thumb.jpg.a982db8cc96e0485cdae1d64e66208c2.jpg
I then had a go at refitting the chrome trim around the drip rail. I used a bit of Dow Corning 4 silicon grease on the rail and it slipped on reasonably easily.
The right hand side did not play the game nicely though. I could get it on in places but not all the way and didn't want to smash it on. I think the thickness of the paint makes a bit of a difference I may try again later or just get my panel guy to give me a hand for 5 min. (or 30s probably)
Side with no chrome:
I also jacked up the car and measured the driveshaft. It is about 35-40mm between the spider and the diff yoke once disconnected and pushed fully forward (at ride height) which I think is about right. I just need to check if the driveshaft guy can make a new one minus the extra welds and dodgyness. With it up in the air it is less than 5min to get it out so easy job.
  • Like 8
Whipped the tailshaft out and got it to the drive shaft shop.
Below is the front yoke (with dodgy extra section welded in) I can't remember whether this is drooped or ride height.
The drive shaft is probably second hand and was probably fitted and possibly lengthened after the the car was un-lowered. It is a 3" tube with a 2 1/4" section at the rear yoke connected in via a rubber joint. I hadn't noticed it so didn't take a photo but the driveshaft guy pointed it out.
Chucked in a bung to stop loosing the fluid, thanks whoever made that suggestion.
Not sure what I'll end up with. It will need to be MASSIVE to take all the TORQUE from the 289 though. It will likely depend on what yokes and tubes the driveshaft shop can get. It was also suggested that we lengthen it by 15-20mm as he likes to only have 25mm extra gap at ride height. Hopefully I can drop down to 2.75" tube to save a bit of weight since I don't need 3" tube which is a bit chunky.
Finished the sound deadening.
There was a bit of red stuff under the drivers feet, and no original sound insulation. I'm picking there was a bit of a leak so they removed the insulation but didn't treat anything.
I gave this a wire brush and sprayed some rust converter. I didn't have any POR or Brunox so I just sprayed some primer and flat black. Didn't take a photo.
The passenger side still had the original sound insulation
Ripped it out again and this side was much cleaner than the drivers side
A couple of mats and tape and it is now all covered except under the front seats.
20231211_151621.thumb.jpg.1b682bb911cf87e39cbf5585a614112b.jpg20231211_152008.thumb.jpg.ebd248692faf32340628c6600781a8ee.jpg
Decided to use some spare time to replace the shocks. Should be easy I thought.
Car was on axle stands anyway and I had front spring perches and top bushes so I thought I'd remove the springs and do them at the same time.
20231217_143744.thumb.jpg.f3c21d7210d067604d6d12aabaedda97.jpg20231217_144809.thumb.jpg.762049514c2e449d62c0fc7ce986cb4e.jpg
Spent ages trying to compress the spring to get it out. Tried jacking the car to compress it so I could just hold it with the compressors but that just jacked the whole car. One hour of swearing and frustration and I was knackered, so I gave up on the springs and just did the shocks.
30min later both were done.
I then went to try the rear but I need a 1/2" long reach socket which I don't have so I gave up on that too. All the rear bushes need doing so I'll just get a pro for that.
