  • 4 months later...
  • Replies 97
Took the Mustang to work for a test run and it is running well with its new dizzy. Since I had it there I decided to play with the temp indication system. It has barely moved off C since I bought it. I have replace the sender and crimp with no effect. Measuring the sender cold it is 500ohms. Grounding the wire to the gauge puts the gauge off scale high so the wiring and gauge work fine.
Rummaging around in the drawers at work I found a 5k pot and soldered on some test leads.
Adjusting the pot I can get full hot, full cold and in the middle.
First time I had seen that. Measuring the pot at this point and it is 34ohms while the sender was around 50-60 idling in the garage after getting home.
Looking online I get conflicting info about the senders, either 500ohm or 100ohm. Looking to buy they don't state the resistance but there are pots for a gauge and for a light so maybe I have the one for a light? I'll have to check the P/N and maybe sway it out but if it is wrong then the original was too.
Carby info for later. You can just see it is an Edelbrock Performer 1404 which from the chart below is a 500CFM. Interesting that the throttle and venturi diameter diameter is the same as a 600.
I think some tuning can be done by replacing the step up spring which is easily accessible but without an AFR reading it is guesswork. I could get a TEMU or Ali express AFR gauge for less than $100 but anywhere else is much more and not worth it for me to experiment.
I got a aem wideband for around $300 for when I get my car back running, has a pretty similar setup to yours and seems to run super rich, I was looking at the ali express ones too but saw heaps of bad stories about them and them not actually being wideband sensors when they actually turned up so I bit the bullet and spent the extra $$$ figured it would eventually pay for itself in fuel savings (or atleast thats what i told the mrs haha)  ,   on youtube thunderhead289 and junkyarddigs has heaps of info and tricks for setting up edelbrocks on fords and getting them running mint, they make it look easy
Thanks. The chepos do have narrowband sensors as far as I can see. I have a WB sensor as long as the gauge can be connected to the same plug, where did you get the gauge?
BTW, the chat thread is here:
I found an AEM AFR gauge at NZ Air Filter.
I thought I'd give it a go as a science experiment. I had the O2 bung so I could fit the WB sensor easily
I thought the angle was a bit odd as it faces the outside of the car but I think the exhaust shop chose this to follow the speedo cable so I zip tied it to that. I managed to keep plenty of clearance to the headers.
20251108_132856.thumb.jpg.5a1cd1085dbdf2a0c86e95a4304eec1a.jpg20251108_134430.thumb.jpg.81e0a99fe7f341ba99baadd212de3b20.jpg
I had to split the grommet to feed the wiring through but someone had already fed a dodgy grey wire around the grommet so it ended up being an improvement.
The wiring under the dash is a 50 year old mess and the stereo install is just ok but I managed to tee into the switched power for that which should give me fused power.
I need to get a gauge bracket of some description but it works
20251108_153306.thumb.jpg.8190ed4aa1bbdd7e916981724ba4b956.jpg20251108_153408.thumb.jpg.8e7a77b7505824012ce21c4c76d12171.jpg
Ignore the numbers, it fluctuates like mad at idle but settles in once the revs come up. I assume the pulses mess it up. Not sure if I can set a filter to slow it down.
I got a we delivery from the Mustang Centre. I have been chasing the temp gauge for a while and worked out previously that the sender was the wrong resistance value to indicate on the gauge so I had to hunt around for the correct one, harder that I would have thought. While I was at it I ordered some other bits to make the postage worth it.
The sender is an easy swap but I did have to give the crimp a wee squeeze.
I also swapped in a new air filter. I thought that was a good idea since it was probably quite a few years old.
It was a bit of a pain. But old and new are 3" but I had to wind out the filter stud in the carb to get the nut to engage. Lucky it has a wee lock nut to tighten it in unlike others I have had which I needed to cut down some threaded rod.
I took it for a drive and got a satisfying indication on the gauge. Previously it hardly moved past the C line. It even went up after shutting down which is a good indicator it is accurate enough as the temp would rise with no water pump or fan operating. Drop as soon as the engine starts again and water flows.
  • Like 9
The AFR gauge looks a little better now. I'm not showing a picture under the dash, it's embarrassing. The gauge comes pre-terminated which makes installation really easy for a novice but leaves heaps of extra cable you don't need. The cheap plugs on it are not easy to replace so there is a big loop to hide out of the way.
Road testing the carb changes showed the needle change made more of a difference than I thought. Drivability was the same but AFR sat on 13-14 in cruise.
Gauge2.jpg.60dc785b6a121a51039ba30822b9acbb.jpgGauge1.jpg.97d6311d597c0b4ad49418a21e89973b.jpg20251211_122910.jpg.d225ba2403146ad2e786acb0cafb35ec.jpg
Nice having a temp gauge that works too. Was bloody hot but engine temps sat in the middle which I assume is good.
  • Like 9
  • 3 months later...
Finally got around to pulling the seats out. It's a bit of a pest as the floor is double skinned so you need a 1/2" long reach socket. Not a 5/8" the internet says, strange as google knows everything.
Have to pop some very old bungs out too. I could get new ones but I think they'll do a few more years.
Bolt is right up there and once 3 are out the whole seat moves making it a pig to keep on the last one.
4 nuts and bungs out. One of these things is not like the other one.
Seats look really good unless you look closely. What's the problem?
Oh, that..
Seat foam is toast too and a previous owner had jammed some foam in there to prop it up so will be good to get some comfort back.
Car is a bit empty without the seats too. Might take the opportunity to throw some more dynamat under the seat base while I'm at it. Oh, and give it a vacuum.
  • Like 9
With the seats out I wanted to use the chance to add some more Dynamat. Pealing the carpet back is easy enough but I was a bit lazy and didn't remove the seatbelts which may have been a mistake.
Got pristine 1960's Brittany blue under here, aways nice to see.
Now to cover it up and never see it again. I left some gaps where the seat rails go just to make it easier.
Underlay back in. not sure when this was first put in but it is in reasonable condition
Then the carpet back. It is quite wrinkled due to the abuse of pulling it back. I'll have to give it a bit of a roll out before I put the seats back in.
An in automotive archeology news, I found another durry under the carpet. Some previous owner must have had a habit.
