Found this on the side of the road.
Threw it in the truck and gave it a clean up.
Its swallowed half the air filter.
I cleaned the filter housing and threw some fresh fuel in.. pull pull nothing
Sparkplug was dry
Threw some start ya bastard in its neck
2nd pull it ran for 5 sec
Tried again, reved hard then began sucking fuel and ran like the vid..
At inlaws for dinner so will look at carb clean and reattaching throttle linkage after work this week.
  • Like 8
Thinking the pulsing is an air flow issue..
I did notice throttle did not affect the carb butterfly,so will check if the throttle linkage is not broken too.
What have I missed?
Interestingly the mower needed starting fluid each time, so could I expect a blocked jet..
Remove the idle mixture screw and blast out the hole it was in with carb/brake cleaner, should spray out a hole in the front of the carb as well as internally, they get blocked up a lot and give hunting idle.
Linkage doesn't directly control butterfly, I've had a couple that were either idle or max nang with nothing in between thanks to fucky governor.
Manual: https://drive.google.com/file/d/1wRpU92lMIv2fV60NJvffIEXbKN9gMfy7/view?usp=drivesdk
I forgot to print yhe manwell today.
Here was the state of the outside of it.
So it has throttle and choke butterflies?
How do you engage choke??
Full forwards on the throttle lever, then pull it back a bit once running to turn off.
Goeshard. Air filter is currently 2 pieces of news paper.
It goes real well after a carb strip.
New fuel lines
Maximum power thru ankle deep wet grass.
Thanks  for the advice
Bloody thing wouldnt start today.
Chucked acap of fuel down its neck and it went first pull then did myfront lawn and the other neighbours jungle.
We are now a 2 mower family
It's pretty typical for these.
Was told to try tilting it/lifting the back right up for a few seconds before starting when cold, might be a Barry tale but it always seemed to work for mine.
Will try it tomorrow!!
Thanks!!!
13 hours ago, V8Pete said:
I have two catchers to suit this mower if you want to somehow get them from Auckland :badgrin:
Thanks Pete.
I have a catcher but would love an intact mesh for the vents on the top if you have one.
Happy to pay
yeah I always turn my fuel off and run the carb bowl dry before putting away so it has fresh fuel in the carb every cold start.
also I usually pop the air cleaner lid off and give a squirt of crc 5.56 which is volatile enough to work as a safe starting aid for the single pull thrill.
Lawns done twice with this
New air filter reduced hunting at lower revs
Also it starts on 4th pull now with no WD40
My mower man was out of sparkplugs , but I will get a new one next week!
Chuck em in the back of the MR2, and bring them to OSN Peet.
On 22/08/2022 at 13:18, felixx said:
Thanks Pete.
Happy to pay
I keep forgetting to look
