  • Replies 57
12 hours ago, fletch said:
A long time ago just before either parked it up to go overseas, the speedo stopped working. I always thought it was the dodgy speedo drive I modified. Turns out it was the cable
Spend too much time wound off the end of the speedo?
  • Haha 2
It goes past 180 and keeps going to the zero stop. Maybe that one time I went to Mexico and spent some time there, it loaded up the cable too much.
Spent the last few nights in the shed on the premise of getting a datsun ready to go to nats, but got a bit sidetracked on this.
Speedo fixed
Then I removed the driveshaft to swap for the less 2nd hand one I have in stock. While I was in there I noticed the rear diff cover had been leaking and was covered in shit and thought I better do something about it now rather than later when it runs out of oil.
I whipped the back cover off and spent hours with a Stanley blade shaving the original paper gasket that had set like rock.
The drain plug magnet was broken into a few bits so that got replaced with a donor from a smashed gearbox.
Then I needed to replace the centre bearing on the driveshaft. It's a cnut of a job.
  • 1 year later...
Further disassembly.
The caster/tie rod bolt was stuck on one side. There was no room to swing a hammer to knock it out as the engine was in the way. I thought I'd be a smart arse and cut the head off and drive it through.
Unfortunately the bolt had a taper and would not go.
After a few beers and some swearing it came out.
I remember now having an issue with the drivers side one 15 years ago. Looking at it now, I see the trimming I gave it to make it fit better and actually be adjustable..
Anyway, remember that bolt I cut the head off?
Lol. WTF.
I'm off to see a wrecker mate this weekend. Dammit.
  • Sad 7
A customer who was painful to deal with came back for the 4th recheck and he had stripped the thread on that bolt, I thought to save everyone headaches I'd just wang a new bolt in but found as you have that it's a wierd one
I ended up spinning up a top hat spacer (12mm id 14 od?) and using a 12mm ? bolt
Paets turned up so I picked out all the good bits and assembled the hubs and J arms.
Many parts, lots of creative pressing to get bearings in.
  • 9 months later...
