CarolsHusband Posted May 27, 2020 Share Posted May 27, 2020 Dub advice needed from dubbers plz, paging @63Ragtop & @64valiant maybe ? My shortened floorpan that I'm using for the Beach Buggy is originally a ball joint front end, my donor beam is a link pin type. In my innocence I assumed that I could just swap the beams but a mate has put a doubt in my mind. I can't find an answer on that internet (though I may not be using it correctly). Anybody know facts ? If they are a different fitting is it possible to adapt ? Chur 1 Quote Link to comment Share on other sites More sharing options...
63Ragtop Posted May 27, 2020 Share Posted May 27, 2020 Yeah nah, the torsion tubes are different a spacing so nothing will fit between link and ball. The good news is ball joint cars handle better, unless you want to go off roading? Because link pin has more travel. 1 Quote Link to comment Share on other sites More sharing options...
CarolsHusband Posted May 27, 2020 Author Share Posted May 27, 2020 Thanks man Was planning to give it a bit of stick off road, not much point in living at the beach and not using your beach buggy. Sooo..... Looks like I'll be getting my current pan shortened, or starting a new plan. Quote Link to comment Share on other sites More sharing options...
63Ragtop Posted May 27, 2020 Share Posted May 27, 2020 Swaping the pan head is possible, as long as it's all straight and strong. 1 Quote Link to comment Share on other sites More sharing options...
GuyWithAviators Posted May 27, 2020 Share Posted May 27, 2020 @Shakotom ? Quote Link to comment Share on other sites More sharing options...
CarolsHusband Posted May 27, 2020 Author Share Posted May 27, 2020 Or I could buy these.... https://www.ebay.co.uk/itm/Saco-Billet-Aluminum-Ball-Joint-Frame-To-King-And-Link-Pin-Axle-Beam-Adapters-/283478593188 1 Quote Link to comment Share on other sites More sharing options...
63Ragtop Posted May 27, 2020 Share Posted May 27, 2020 Looks like that will push the beam out a inch or so, no good for a sedan but might be okay for a buggy? 1 Quote Link to comment Share on other sites More sharing options...
CarolsHusband Posted May 27, 2020 Author Share Posted May 27, 2020 Yeah, that's what I thought. Seems like a good fix. Saw some fabbed out of steel too, but it doesn't need any more rustable parts. Quote Link to comment Share on other sites More sharing options...
