Nominal's Wooden (Wood knot) Cars
Nominal
  • Replies 100
  • Nominal
    101
Took it for a WOF on Tuesday, was all good except for the brake lights not working. After a bit of a hunt I found the brake light switch tucked up above the engine crossmember and managed to get it out after a struggle.
Apart from replacing that I spent the next three days working on son's Pajero. Made some mounts to bolt onto the custom tent rack to hold the pull-out shelter thing, and knocked up some (slightly rough) drawers on roller skate bearings.
So, after a damp Whagnats I was a disappointed to find some varnish issues.
This first patch was where it was damaged by falling over in the garage, so OK, but the water got a lot further under the finish than I liked.
This piece was not so good, where there was a pre-existing crack in the wood.
I sanded back the damaged areas where I could and re-coated, but I'm going to have to take the doors apart again soon and re-do them better.
I had a chat with my BiL who is a boat man and he recommended this book. Brightwork is what they call unpainted wood in the boat world.
It's helping me be more philosophical about dealing with wood.
Things got a bit clunky out the back, might have been the extra wine?
When we got back I found that the rear exhaust mounts had sheared off on one side, and nearly on the other. The design wasn't too good as the mount was in shear (would be fitted vertically compared to this pic) and bound to fail again, even if I could find an exact replacement.
So I made a couple of different ones using these common hanging mounts - I think they are a Commodore part
Holds the weight vertically in tension so shouldn't be an issue again (I hope)
Part of the reason for the banging is that it has always had a bit of a lean down on the drivers side.
A bit of measuring pointed the finger at the leaf springs. Also the WOF man had mentioned that the front spring mount pin looked a bit loosey goosey
So, got some new U-bolts made (the threaded part was quite bent from some sort of ground contact on one side), cost about $120 from Archers.
And some new pins/bushes from the USA. When they arrived though they were made in China and didn't look as good as the Ford ones, so that was money wasted.
