kseries.rookie Posted April 24, 2019 Author Posted April 24, 2019 The Hyosung was beginning to take it's time to start, sometimes first click of the start button but sometimes a few goes.. My current house has a little hill on the driveway which would allow me to bump start it which worked every time but less than ideal.. Easter break meant I had some time to do some things which meant whipping off the carbs, giving a clean and replacing the jets During this process I also noticed two air leaks. Fixed those, replaced jets/sealsĀ and gave it a kick this morning and it was an instant start up. Job done, pic for thread 5 Quote
kseries.rookie Posted May 12, 2019 Author Posted May 12, 2019 New exhaust, guards and tail light on the GN Also, first time riding with the GB and GN 1 Quote
datlow Posted May 13, 2019 Posted May 13, 2019 Oh new exhaust for the gn or?Ā Iām looking for a muffler for my hondaĀ Quote
kseries.rookie Posted May 13, 2019 Author Posted May 13, 2019 14 hours ago, datlow said: Oh new exhaust for the gn or?Ā Iām looking for a muffler for my hondaĀ Yeah man, went from 'cone' style to a straight pipe style. The cone was getting hella rusty. I don't have a photo of the state before I took it off but this was a month before hand so imagine double thisĀ to this I picked that one up from trademe for something like $60. It's literally a straight pipe, no baffles so it is loud but it's still within being able to pass a WOF AliX have some cheap mufflers, you just have to wait 4 weeks for it to arrive and most likely re-paint it because it's been damaged along the way. You could always try on my cone shape to see if you like the sound/style? I'm in wellington and love any excuse for motorcycle bants 1 Quote
datlow Posted May 14, 2019 Posted May 14, 2019 Ah I was hoping it was smaller Iād than the usual ali ones as my bikes a twin cylinder 125 so theyāre only 27mm ID each (twin pipes)Ā havent found anything thatĀ costs less than what I paid for the bikeĀ Quote
kseries.rookie Posted June 8, 2019 Author Posted June 8, 2019 GN was due a birthday and with me moving house next weekend my shed is pretty much packed up so I hijacked my mates workshop/knowledge today Plan of attack/parts list for the day includeĀ - New cam chain - New guides - New drive chain - New sprockets - Oil and filter - Headlight mesh install - New bars - New mirrors (I didn't like them so went back to bar end, as they looked like a bloody praying mantis) - New spark plug It was actually pretty clean inside Yeah so this is what the new bars look like It's much more of an upright riding position, it's cool but I personally prefer the down low vibes Mrs is unsure, so she can ride it for awhile and see if it's just a case of getting used to No more ticking engine, it sounds like a GN should Che 1 Quote
kseries.rookie Posted September 28, 2019 Author Posted September 28, 2019 Had an interesting situation with the Hyobanger last week.. Starting the bike in the morning as per norm but when I pulled my hand off the starter button the starter motor didn't stop I hit the kill switch.. Was still going Turned the key off.. Was still going So I had to disconnect the battery real quick cause I didn't wana burn out the starter When I put the cable back on the battery the starter would engage..Ā Yep, so the starter is getting constant power regardless of the key situation/kill switch situation I pulled the fairings off and checked all the cables, they all looked fine. Pulled apart the RH Switch block to see if there was any shorting there but that was all good Disconnected some stuff to see if that made a difference (ignition, switch block etc).. nothing I sent a snapchat out to the boys to see if anyone had any suggestions which some replied with some helpful knowledge but nothing I hadn't already done Bit the bullet and loaded the bike up to take to an actual motorbike mechanicĀ Unloaded the bike, explained the situation I got in the car and I got a snapchat from a mate. I nearly didn't check it and thought fuck ill check it at home, im hungry I wana leave but he said "sounds like the solenoid is stuck on bro.. Give it a wack or two" I had done this.. but obviously not hard enough Surely enough.. Gave it a couply decent love taps and it was fixed.. Loaded bike back on and head home. I dunno if I need a new solenoid but they're cheap enough to replace so I will order a new one in a minute but yeah.. No big bill from the motorcycle shop so thats a win 4 Quote
datlow Posted September 28, 2019 Posted September 28, 2019 Yeah the insides of the solenoid will be pretty shitty and prone to doing it again/ could go the other way and not engage properly too either pull apart and sand contacts smooth (prob a cheap cast plastic unit tho) so yeahĀ buy a new oneĀ 2 Quote
kseries.rookie Posted September 29, 2019 Author Posted September 29, 2019 On 28/09/2019 at 15:59, datlow said: Yeah the insides of the solenoid will be pretty shitty and prone to doing it again/ could go the other way and not engage properly too either pull apart and sand contacts smooth (prob a cheap cast plastic unit tho) so yeahĀ buy a new oneĀ Yeah, I ordered a new one. It was only $35, it should arrive in the next couple of days. Cheers for the advice/confirmationĀ Quote
kseries.rookie Posted April 10, 2020 Author Posted April 10, 2020 I realised I hadn't updated this in awhile.. Not much has changed really. My GB's tank was poked, the seams leaked so I picked up a new one which was internally mint but externally a bit fooked. I fixed the dents, Por15'd the crap out of the inside to avoid leaking in this one, painted it myself in a glossy winter greyĀ and added some cool racing stripes for additional HP. Pretty happy with how the colour turned out with the stripes.. Went for that same colourway with gloss black and matt black. Just need to put the drivers side mirror on and it's ready for a warrant check after lock down.. It mightĀ be time to flick this one off.. I also picked up a GD250n that had a blown motor.. Got a new motor in it and did a tail tidy.. It had problems with the TPS which I got fixed and went for a WOF. Failed on brakes and fork seals..Ā Replaced those/got them fixed and rode to work a few times before the mrs decided she liked the look of it and started to ride it Shes hapu so her riding days are over for awhile so this will be going up for sale once lock down is over. A couple monthsĀ before lock down I nabbed another GN250 that I couldn't pass up on. I intend to fix and flip this. Needed some love/work. The electics were on the piss, the brakes were shot, fork seals were well and truly shot and was just lacking.. well, basic maintenance. Ordered a bunch of parts and it sat in the shed until I could find time to do anything about it.. Low and behold, had some time over the last couple of weeks to tinker with it. This was the state of arrival.. After new brakes, spoke wheels, new bars, new grips, re shaped seat, wiring all sorted,Ā and a whole lot of elbow grease and love.. this is how it looks After lock down i'll go for a warrant check, fix whats required if anything is required (seems OK to me) and flick it off.. The red Hyo is in the shop for a WOF..Ā It failed on tyres and exhaust had a hole in it, so that's locked up at a workshop currently not being worked on which is all good. Thats really it I guess.. Ā 7 Quote
tortron Posted April 11, 2020 Posted April 11, 2020 What did reshaping the seat involve? Just shave some off and reuse the of cover? Looks good Quote
kseries.rookie Posted April 12, 2020 Author Posted April 12, 2020 19 hours ago, tortron said: What did reshaping the seat involve? Just shave some off and reuse the of cover? Looks good Thanks, yeah exactly that man! I popped the original staples off (most were rusty so had to file them flush after they snapped) and attacked it with a bread knife and very gritty sand paper.. Even better if you have an electric bread knife! I did use a new seat cover (i'll link it below) because mine had a rip in it but at long as you're gentle with your original I can't see why you shouldn't get away with using the original but for the sake of $35 you'd have a fresh looking cover.https://www.trademe.co.nz/motors/motorbikes/parts-for-sale/seats-seat-parts/listing-2596776032.htm?rsqid=9a91f7625c4f428bbfdd7e4eb511a81f-001 Quote
japawagons Posted April 12, 2020 Posted April 12, 2020 That GB is looking temptingly good. Floats my boat in all the right ways. The tank colour is rad. Quote
kseries.rookie Posted April 12, 2020 Author Posted April 12, 2020 Just now, japawagons said: That GB is looking temptingly good. Floats my boat in all the right ways. The tank colour is rad. Thanks man, appreciate it! I hoped it would be a little darker to be honest but it has grown on me and I am happy with the outcome! I am going to sell it after lock down so ifĀ you're genuinely interested, slide into my DMs and we can chatĀ Quote
Popular Post kseries.rookie Posted May 24, 2020 Author Popular Post Posted May 24, 2020 Picked up a new set of wheels recently 2013 Thruxton 900 with plenty of goodies 10 Quote
kseries.rookie Posted June 6, 2020 Author Posted June 6, 2020 Completed the Ride Forever Gold course today with Two Bald BikersĀ and had a blast 10/10 would recommendĀ Ā 5 Quote
kseries.rookie Posted August 28, 2020 Author Posted August 28, 2020 Did some shed stuff today Removed integrated tail light as WOF man says it's a no no Reverted rear mud guard back to standard (removed chopped one).. Added round bullet indicators and lucas tail lamp for that era specific vibe Also installed new valve starter set, manifold gaskets, put OEM air box back in, changed jets, played with air/fuel ratio, removed old gas, added new gas and tuned to a perfect idle. First time it's idled without pops and splutters. I will never go aftermarket air filters on a carb bike again, if I can help it.. About 10 different jet test runs and I could never get it running right. I might even take it for a hoon sometime this weekend to blow the cob webs off before going for a WOF Ā 1 Quote
kseries.rookie Posted October 25, 2020 Author Posted October 25, 2020 Watermark signs back at it again with producing the decals - This time a tail piece for the cowl, the lines and also the number I also slapped on some yellow tint on the headlight. It really irks me how I spend hours on polishing the headers to a mirror finish and after a 20 minute ride its back to dull.. 8 Quote
kseries.rookie Posted December 4, 2020 Author Posted December 4, 2020 Spent some time here and there on the Thruxton over the last week New parts put on are Clip on handle bars Triple tree clamp off an older model Thruxton, powdercoated gloss black front fork boots BCC Headlight brackets Round mirrors (only had one mirror previously) And then after I went for a shake down ride, I got home and my Motone Microblade aluminium screen turned up with a few bits of dress up bits. I couldnt resist putting the screen on but will get some proper pics when i've made some more changes 4 Quote
