Tyla Posted March 6, 2018 Share Posted March 6, 2018 Quote Link to comment Share on other sites More sharing options...
yoeddynz Posted March 6, 2018 Share Posted March 6, 2018 Impressed that it manages to fit in without chopping holes. For some reason I always thought they needed clearance around the front but I might be confused with the Toyota V6 swap. Barry Dowler is nice to deal with eh. Pretty chilled. He, probably like most certifiers, doesnt like peaked cap, tall black sock and jandal wearing Redbull drinking yoof telling him he is wrong and they are right. So glad you've kept this looking stock. You'll have some fun surprising folk! Just dont end up backwards in a hedge- like I did many times in my Aw11 when I ran out of talent 1 Quote Link to comment Share on other sites More sharing options...
flyingbrick Posted March 17, 2018 Share Posted March 17, 2018 I know a few people that have done this swap- with great results. I bet its GREAT to drive. A few relatively simple additions and you could have a 12 second car pretty quickly 1 Quote Link to comment Share on other sites More sharing options...
Tyla Posted March 17, 2018 Author Share Posted March 17, 2018 The engines run by a link g1 ecu and has made good power when it used to be in a sw20, but I've been having trouble getting it to make full boost, I've only been able to get 12-14psi out of it which is still alot of fun 1 Quote Link to comment Share on other sites More sharing options...
yoeddynz Posted March 17, 2018 Share Posted March 17, 2018 Good torque too- in a lightweight car. It ramps up on the torque really quickly from 3000 to 4000. Right in the rev range you'd be at when cruising along in 5th. It must be awesome at easily passing cars without breaking a sweat! 2 Quote Link to comment Share on other sites More sharing options...
Tyla Posted March 17, 2018 Author Share Posted March 17, 2018 The torque is awesome, 5th gear when overtaking is normally more than enough, very different to the 4age 20v which was in it, though the 20v was alot of fun aswell 1 Quote Link to comment Share on other sites More sharing options...
flyingbrick Posted March 17, 2018 Share Posted March 17, 2018 The secret to going fast (if i remember correctly) is a steel wheel ct20b. That + downpipe and boost controller was enough to get my old flatmate (alsw20) doing 12.7 down the quarter and 4.2 seconds to 100 (again, from memory) in a full weight sw20. I got to drive that particular car on the street and it was just awesome... You could be boost limited by the little turbo thats on there..they are pretty average. 1 Quote Link to comment Share on other sites More sharing options...
Tyla Posted March 18, 2018 Author Share Posted March 18, 2018 It has a ct20b and 3inch downpipe but the exhaust is crap after that, I drove it around open downpipe not too long ago and got it to flow 18psi which was awesome but it was still acting a bit weird and not hitting its boost target until 6k+ rpm, I think the main thing for me to do now is put a proper exhaust on it and then see how it runs 1 Quote Link to comment Share on other sites More sharing options...
Tyla Posted March 18, 2018 Author Share Posted March 18, 2018 Also electronic boost controller, I tried a manual boost controller but it was just the same so I don't think it's the boost controller Quote Link to comment Share on other sites More sharing options...
flyingbrick Posted March 18, 2018 Share Posted March 18, 2018 Weird. Leaking wastegate? 1 Quote Link to comment Share on other sites More sharing options...
mjrstar Posted June 10, 2018 Share Posted June 10, 2018 The way it's staircasing the boost plot I would suggest the ecu is pulling ignition timing based on more load in the taller gear. 2 Quote Link to comment Share on other sites More sharing options...
Tyla Posted June 10, 2018 Author Share Posted June 10, 2018 thanks i'll try and see if i can log the ignition advance, i'll also check that the ignition timing is synced for the ecu. i'll let you know how i get on cheers Quote Link to comment Share on other sites More sharing options...
yoeddynz Posted June 10, 2018 Share Posted June 10, 2018 I saw you hooning through Nelson in this I think two Fridays ago? Looks good. So small against all the bland blob cars around it. 1 Quote Link to comment Share on other sites More sharing options...
