J2Racing Posted June 6, 2017 Share Posted June 6, 2017 I have a customer looking for a bolt on brake upgrade for his 1983 MS112 crown. He is aware it will involve a cert as he is fitting a 1JZGE Yes I am using this as a reason to be on old school while at work. Quote Link to comment Share on other sites More sharing options...
rich1179 Posted June 6, 2017 Share Posted June 6, 2017 What style uprights? Post a photo if they are similer to the mitsubishi cab make custom plates to bolt caliper on Quote Link to comment Share on other sites More sharing options...
J2Racing Posted June 6, 2017 Author Share Posted June 6, 2017 unsure of the style they are factory ones. Will try and get a photo Quote Link to comment Share on other sites More sharing options...
Spencer Posted June 6, 2017 Share Posted June 6, 2017 It should have vented discs already? should be plenty for a NA 1JZ??? People steal the front and rear disc brakes from these for older crowns. I have seen people swap old 50/60/80 series crown solid disc front ends to Holden HQ gear but its a pretty shitty upgrade. Quote Link to comment Share on other sites More sharing options...
Spencer Posted June 6, 2017 Share Posted June 6, 2017 Its a pretty standard double wishbone stub axle arrangement, you could build caliper brackets for near anything you want once you find a disc you want that works on the standard hub/stub. Quote Link to comment Share on other sites More sharing options...
KKtrips Posted June 6, 2017 Share Posted June 6, 2017 Disc brake rear end and appropriate master cylinder would probably be sufficient upgrade. Quote Link to comment Share on other sites More sharing options...
Spencer Posted June 6, 2017 Share Posted June 6, 2017 Depending on the model most of these had disc rears already K-tripper. Most likely it has vented fronts and disc rear, these some of the best factory crown brakes that exist (something like 250mm vented fronts), they are similar all the way into the 2000's and not that much bigger/different for factory 1UZ and 2JZ crowns. 2 Quote Link to comment Share on other sites More sharing options...
KKtrips Posted June 6, 2017 Share Posted June 6, 2017 For reference, I have 290mm vented front rotors and 280mm solid rear rotors on the Commy with similar HP to an NA 1JZ - probably weighs the same as a Crown and it pulls up pretty reasonably. Quote Link to comment Share on other sites More sharing options...
Bluebear01 Posted June 8, 2017 Share Posted June 8, 2017 Lol small world J2Racing, I think it was me you were hunting out brake info for . Thats some really helpful info, thanks guys! It's getting a 1uz, but it's good to know the factory brakes may cut it. She is running drum rears, but i have a disk rear end to pop in. The fronts are vented, but I do remember seeing some slotted rotors to suit a ms112 on trade me a wee while back. Might not be worth it though? Quote Link to comment Share on other sites More sharing options...
Seedy Al Posted July 24, 2017 Share Posted July 24, 2017 @Bluebear01 Hey man. I some how missed this thread, but to let you know my ms112 with a 2jzge passed cert with the factory brake setup and they actually work really well. I had an emergency stop and went for a drive over a 30km hill road and had zero issues what so ever. 2 Quote Link to comment Share on other sites More sharing options...
Seedy Al Posted July 24, 2017 Share Posted July 24, 2017 Also @J2Racing Quote Link to comment Share on other sites More sharing options...
